Old 04-02-2008, 01:06 AM   #1 (permalink)
on 7th day God made SR20
SR16 to 2.0L vs SR16 with N1 Cams
I know there are a couple of threads similar to mine but:
I have Pulsar with stock Sr16 and considering 2 options:
1. Add N1 cam only
2. Stroke the current motor to SR20ve
Which will be better investment (hp per $ spent)?
What gains can I expect with both?
In both instances I plan to use sr16 stock ecu, stock injectors and may add headers and CAI. The car already has 2.5" exhaust.
Don't want anything complicated or expensive. Don't want to use a piggyback device (if i can avoid). Looking for reliability. It's a daily driven car
If I were to with option 2, my main concern is type of piston - Compression ratio - since the best pump gas we have is 90 octane.
What is the simplest way to achieve option 2 and what parts do i need - I assume I'm gonna need sr20 crank and rods but specifically what pistons so as not to have a very high CR (remember 90 octane!)
thanks for your input.
2000 Sr20ve Powered Pulsar VZ-R
SR16ve Cams & Ecu, Greddy Emanage (Blue), Apexi RSM (SCD), 60mm Exhaust, JWT Pop Charger Air filter, Tein HA coilovers, 15" Wheels, ACT 6 Pad Sprung Center Clutch w/ Heavy Duty P/Plate, Prothane Motor Mounts. 175whp, 134ft-lb Torque, Top speed 140mph (so far) To come: Noise!
Raggy is offline   Reply With Quote
Old 04-02-2008, 01:13 AM   #2 (permalink)
Broke Ass
jer_760's Avatar
Stroke. Leaves more room for improvement.
95 200sx
sr20ve
Old 04-02-2008, 01:27 AM   #3 (permalink)
Thanks. What hp gains I am looking at with this mild improvement?
Old 04-02-2008, 01:39 AM   #4 (permalink)
Broke Ass
jer_760's Avatar
From the factory:
SR20VE 187hp/145lb tq.
SR16VE 173hp/119lb tq.
Old 04-02-2008, 02:18 AM   #5 (permalink)
Enemy of the stupid
You should be able to put down 180hp to the wheels with the 2.0 motor and SR16 cams. Might be even 186 with SR16's pistons in there too.
91 NX2000 VE forsale
http://www.drag240sx.com/
Old 04-02-2008, 10:59 AM   #6 (permalink)
20ve pistons will be too low and 16ve pistons will be too high so I'm a bit undecided here. Dont want to having to shave off portions of the 16ve pistons. The highest octane I have availbable is 90.
How safe is this 16/20 set up without management?
Old 04-02-2008, 11:04 AM   #7 (permalink)
From the factory:
Those numbers are crank hp so I guess the 20ve should translate to about 158-160whp.
But my thinking is that 2.0L with 16ve head should give more hp than stock 20ve so i am expecting somewhere in the region of 175-180whp
Old 04-02-2008, 11:13 AM   #8 (permalink)
SR20DEviant
Trader Rating: 23 (100%)
You can always get a calum real time ECU and tune it with a laptop computer. If the highest octane you can get is 90, how does the car run now? Because if you use the same pistons you are using now with the SR20 crank to stroke it, you shouldn't change the compression from what you are running now.
As far as power goes, you'll have way more room for improvemtent if you stroke it. Consider that:
1) N1 cams can always go in at a later date
2) Stroking the motor will provide more torque, making the car feel much faster
3) Running SR16 pistons with a SR20 crank will yeild even MORE power
4) A good ECU tune can pull even MORE power from a larger motor
Something to chew on a bit. CHime in VE gurus...
Originally Posted by Serban View Post
1991 SE-R -- SR20VE - Hot Shot intake w/ Pop charger, Megan cat-back exhaust, SSAC headers, 2000 SE disc, ACT HD pressure plate, B&M shifter, ADV22 brakes w/ SS lines, FSTB & RSTB, ES sway bar bushings F/R, & Prothanes
PhorB13 is offline   Reply With Quote
Old 04-02-2008, 12:27 PM   #9 (permalink)
@Phorb13,
I dont have a fuel issue now but I am sure that with change of con rods, then the CR will go up. I cannot afford to run anything over 11.5:1 on our fuel.
Do you know the formula to work out CR?
Thanks
Old 04-02-2008, 12:48 PM   #10 (permalink)
Your dead Twinkie
Benito Malito's Avatar
Trader Rating: 32 (100%)
If you don't have a header or cai you are kind of putting the cart before the horse. Why not get those and start preparing for the 1.6-2.0 conversion?
1992 SE-R 'Fasty' Mods and more mods. Ready for more boost. Soon.
1992 NX 'Peggy' Intake, exhaust, suspension.
Old 04-02-2008, 01:06 PM   #11 (permalink)
Point taken.
The CAI can be added when the upgrade is being done. Header? Well if I cant get a decent one (made for the ve) then I will stick to the stock manifold. Dont want to use a sr20de manifold that I will have to convert.
Peace
Old 04-02-2008, 01:17 PM   #12 (permalink)
Your dead Twinkie
Originally Posted by Raggy View Post
Point taken.
Peace
Then you are left with the Fujitsubo header and the 20V manifold from the 204hp VE engine as the options. The SSAC does do the job though its not like you have to weld to make it work.
Anyway I just thing that changing the crank and rods is a lot to go through. Will the cams hit the pistons if you do that with 16VE pistons/cams? I forget... Also that will put your compression pretty high. Might be tough for you on 90 octane fuel.
Old 04-02-2008, 01:20 PM   #13 (permalink)
Your dead Twinkie
Also what is the measure of the octane? Does it say MON or RON on the pump. One of them slightly exxagerates the actual octane. You could be dealing with 87
Old 04-03-2008, 08:50 AM   #14 (permalink)
It's not true that the C:R will not change. The C:R is the difference between volume at BDC and TDC. I haven't calculated the SR16 going to SR20 combination, but I have calculated the SR20DE with N1 pistons vs. SR20DE w/ N1 pistons and then de-stroking the engine to SR16VE crankshaft. Taking into account same head gasket thickness, head volume, etc. the "SR16DE" hybrid engine would make less than 10:1 C:R, and with the N1 piston in the SR20DE it would have been 11.75+:1. Don't recall the exact numbers as I don't have that spreadsheet in front of me but don't make the assumption that increasing the stroke will not increase the C:R. If you have only 90 octane to work with put the N1 cams in and leave it there, unless you want to do custom pistons or SR20VE pistons to keep the C:R under control.
I have a spread sheet if you want to try and calculate where your C:R will end up. PM me with an e-mail address and I'll send it to you.
Rob E is offline   Reply With Quote
Old 04-03-2008, 10:37 AM   #15 (permalink)
Rob E,
U are right. I was never of the opinion that the CR would not change. As a matter of fact the change in CR is my main concern. I would never use the 16 pistons. I am considering using the 20ve or 20de pistons but not sure how low those would take me.
Old 04-03-2008, 06:53 PM   #16 (permalink)
Is there a part number for the SR20VE (20V) cam? Is this a US buy or Japan only? G Spec does not list this cam. It seems to be the best cam for street performance.
Don Kadunc is offline   Reply With Quote
