Hey guys, i need some advice, my VE span a con rod bearing. Car never saw any RPM pass 7200, using stock DE everything.
DE ECU
DE INJECTORS
DE MAF
Anyway i want to rebuild engine, called the local Nissan dealer, said they carry the bearings but i need to know the specs on the VE bearings, he said it would be (reference number) marked on the CON ROD or the cam shaft cap, can anyone tell me what (specs\gauge\number he is taking about), he said something about gauge (0\1\2 or something like that).
Are the VE bearings the same as the DE?\
Should i change the main bearings as well?
I was driving in morning traffic when this happened idling and blowing AC, what oil do you guys use?
