Originally posted by ScarCrow28
how exactly does that work? are you using an auto? do you have to go under the hood to change, or can you toggle switch in from the cockpit?
5 speed. The MSD triggers have a wire that tells them what rpm the engine is at. You can adjust them to trigger at different rpms. They send a current to a relay which triggers the cam solenoid. This activates the second cam stages.
how does it smooth out lower rpms?
It fires a constant spark at less then 3000 rpm instead of a series of multiple sparks. Above 3000 rpm their is no difference IMHO.
so your saying the sky high 8000 rpms are low?!?! most engines blow up at this point.
The VE is good to about 7800 rpm is what I am told. That really isn't that high. The DE can rev safely that high also. I will never use the 8000 rpm limit. The MSD cuts spark instead of fuel. When you cut fuel you can introduce a potentially lean condition, when you cut spark you can introduce a potentially rich condition. I would rather go rich then lean any day of the week. I used to never hit my rev limiter. I actually bounced off of it 4 times the other day exiting a corner in first gear. The car lost traction in first and spun up so fast that it went BAM X 4 real fast. The MSD cycles much faster then the JWT does. This is a good a bad thing. You don't want to be hitting it like that on purpose. It was so soft I didn't even notice it at first.
is this car to be used for racing? can it be daily driven?
sorry for all the questions, but you really got my courisity. did i spell that right?
It's my daily driver and is fairly docile. I use it for work and even take kids I work with down the local dragstrip as a reward for good behavior. I am a counselor and the kids I work with love it. Primarily it is a autocross and drivers school car NOT a drag car. I still think drag racing a FWD car is weird without slicks. I have no plans to ever buy slicks.
