hesitation problem - SR20 Forum
Old 03-13-2011, 09:54 PM   #1 (permalink)
hesitation problem
finished up my ve swap. below 3k rpm i have a really big hesitation and bogging. any ideas?
johnnymak is offline   Reply With Quote
Old 03-14-2011, 05:07 AM   #2 (permalink)
Feedback Score: 17 reviews
Some more information would he helpful.
How is your idle?
What plugs are you running?
What ECU are you using, and what is your timing setting?
Old 03-14-2011, 06:43 PM   #3 (permalink)
How is your idle?
idle +/- 1000 rmp
bkr6e-n-11
calum basic
i've been playing with the timing after grinding off a bit of the distributor, i've found the hesitation goes away between around 13-14 degrees but the idle jumps to 1200rpm. above 14-15 degrees the idle fluctuates and stalls.
Old 03-15-2011, 12:18 AM   #4 (permalink)
you circumvention circuit might be out of synch <- this is a troll
this engine has sensors that are eager to be read. and an ffing ECU
richardwbb is offline   Reply With Quote
Old 03-15-2011, 07:28 AM   #5 (permalink)
Thanks for the extra information. It doesn't make much sense that the engine would stall at higher base idle settings. Where did you get the bin for the Calum ECU? Also, have you checked the Throttle Position Sensor specification?
Old 03-15-2011, 07:45 AM   #6 (permalink)
Feedback Score: 9 reviews
I have had a similar problem with my VE engine. I discovered that the TPS was within specifications for closed and open throttle, but the voltage sweep between closed and wide open throttle was not linear.
Yesterday I replaced the TPS and the problem seems to have gone away, plus the throttle response across the spectrum has improved.
MegaSoreAss is offline   Reply With Quote
Old 01-21-2012, 12:54 PM   #7 (permalink)
What did you use to read the voltage changes?
2002 SE-R Spec V
1992 SE-R
Nissan_Convert is offline   Reply With Quote
