New dyno numbers - SR20 Forum
Old 01-20-2004, 06:34 PM   #1 (permalink)
VE powered
New dyno numbers
I just returned home from the dyno with the latest numbers. The last time I had just added a 2.5" exhaust to replace my HKS and put down 178.0 hp and 140.7 lb-ft. This time I installed a test pipe and put down 183.0 hp and 146.9 lb-ft (SAE corrected, the uncorrected numbers were 193.9/155.6). This was on a Dynojet 248.
Eric, I have a copy of the data files so if you PM me your e-mail address I can send them to you.
My mods are: stock SR20VE, 3" PR CAI, Fujitsubo header, custom "Chase Race" 2.5" exhaust with Magnaflow muffler, 2.5" test pipe, JWT ECU, JUN lightweight flywheel, autocross alignment (-2.5 deg camber, 1/8" toe out).
Steve
autoxer7 is offline   Reply With Quote
Old 01-20-2004, 08:17 PM   #2 (permalink)
Jah Rastafari
Feedback Score: 61 reviews
Steve
I have a set of Blue Valve Cover 175 hp SR16VE cams which will give you another 8-10 more WHP. If you are interested I want $400 for them.
Old 01-20-2004, 08:41 PM   #3 (permalink)
SE-R BUM
NICE NUMBERS! I wonder how it would be if you had a 3 in catback and sr16ve cams...you would gain a lot of ponies... but anyways congrats on your dopea$$ motor!
Old 01-20-2004, 09:02 PM   #4 (permalink)
I need me SE-R
Feedback Score: 3 reviews
what. sh*t must be like...wooooooooooooooooooooo. i just got my jun flywheel today! you wouldnt happen to have a pic of it would you? i just wanna make sure its the correct one .
nice numbers. maken me jealous!!!!!!!!!
mYseRgOesvrOOm is offline   Reply With Quote
Old 01-20-2004, 09:06 PM   #5 (permalink)
Feedback Score: 12 reviews
Steve
Good numbers. Must have been nice and cold for those corrected numbers to be so high.
Steve
06 G35 6MT
Old 01-20-2004, 11:55 PM   #6 (permalink)
VE powered
I've been thinking about getting a set although since I'm burning a bit too much oil I'm thinking I'd like to get my bottom end rebuilt first with your 90mm overbore kit... possibly even buy an SR16VE with your built bottom end and 86mm crank. Let's talk after you get your killer VE motor done.
Steve
Old 01-21-2004, 12:00 AM   #7 (permalink)
VE powered
Sorry I don't have pics. AFAIK, the regular JUN lightweight (10.5 lbs) is solid and the ultra-lightweight (9.5 lbs) has holes drilled at the perimeter.
Steve
Old 01-21-2004, 12:01 AM   #8 (permalink)
VE powered
54.3 deg F, 30.26 in Hg, humidity 53% = SAE correction factor of 0.94
Don't worry. Your numbers are still better!
Steve
Old 01-21-2004, 08:27 AM   #9 (permalink)
Steve
LOL. That is not the thing.
Those are good numbers. It's just interesting to me that pretty much everyone with the same basic setup is running the same basic numbers within a 3whp of eachother with the same basic setup on the same basic dyno. sr20 cams and I/H/E = about 180whp give or take a little on the dynojet. You are actually ahead of me when I had those cams. Can't wait to see you guys start doing cams and stuff. With a little love and attention I am sure several of you guys engines could hit over 190whp with the same basic setup as mine. I am basically done with the VE. I have started the 240 project and that is were my money is going next. I am convinced the sr16 cams can yield over 190whp with just a little love and care.
Old 01-22-2004, 03:44 PM   #10 (permalink)
Infiniti Parts Guy
Sweet, Nice numbers!
I can't wait to see the dyno graph, to see where your setup makes its power. It makes a few more hp than mine, probably due to the lighter flywheel (mine's about 13lbs) and the fujitsubo header, but otherwise sounds very similar.
You make more hp, but slightly less peak torque (than I did) which leads me to think your header probably allows more top end power, where my HS header gives more mid range power. It could just be the cam switching rpms too though, that did affect my torque peak a little bit, due to how it falls with the cam switching rpms....
Justin McClanahan
2008 Mazdaspeed3
1999 GSX
Old 01-22-2004, 08:29 PM   #11 (permalink)
eric96ser's Avatar
Feedback Score: 29 reviews
I've noticed the Fujitsubo killed some of the low end power, but the car still pulls like mad to 8,000. I haven't dynoed yet, and I'm still using the crossover points that worked best with the HS header. I think the longer primary runners are why the lowend torque went down, but it sure does flow better. I have a copy of his dyno chart, I'll email it to you sometime Justin.
The community is here.
Old 01-22-2004, 09:24 PM   #12 (permalink)
I doubt you lost any low end. My guess is the upper range is soo much better that it just feels that way.
Old 01-22-2004, 11:20 PM   #13 (permalink)
Feedback Score: 6 reviews
Drooool
congrats. nice enough #'s to give DAN the incentive to finally swap in his "dust collecting" ve?
SR24VVL PWRD 97 SE-R
Teal97 is offline   Reply With Quote
Old 01-22-2004, 11:34 PM   #14 (permalink)
VE powered
When I swapped my HS3 for the Fujitsubo I still had the HKS exhaust and cat, but I didn't experience any difference on the low end. However, when I swapped the HKS for my 2.5" exhaust I noticed a definite improvement in the low end. Adding a test pipe also yielded a measureable improvement.
Steve
Old 01-23-2004, 03:10 AM   #15 (permalink)
BAD FKR
Steve
Nice numbers
91 SE-R w/VVL inside
Car in TX sleeping for now and I am in ND
san-man is offline   Reply With Quote
Old 01-23-2004, 11:09 AM   #16 (permalink)
Feedback Score: 9 reviews
Yup, we're shooting for the weekend after next. You still going to be in NY around then?
Dan_93SER is offline   Reply With Quote
Old 01-23-2004, 12:40 PM   #17 (permalink)
yup, unfortunately.
Old 01-23-2004, 12:46 PM   #18 (permalink)
eric96ser's Avatar
I might be dynoing tomorrow, so we'll see then. I really wanted to have more RPM pills before then, but this was a last minute decision.
Old 10-16-2005, 05:56 PM   #19 (permalink)
done
Feedback Score: 7 reviews
LOL, i know this thread is old, but i was just looking around at VE stuff, found this thread... ITs funny but I have this dyno sheet layin around here somewhere. I dyno at the same place this guy did. Its a pretty nice curve I must say.
yes i know this thread is really old...
Old 03-14-2006, 07:30 PM   #20 (permalink)
damn i was actually looking at some ve stuff too didnt even notice that it was an old thread!! number look good! wish i could see the graph!
anomaly is offline   Reply With Quote
