Old 05-17-2004, 08:18 AM   #1 (permalink)
www.FAIRTAX.org
paNX2K&SE-R's Avatar
Trader Rating: 66 (100%)
VE maf vs. Maxima maf vs. bored DE maf
Is there any power advantage to using one over the other? It would be easier for me to stick with the bored DE maf since I won't have to change to a b14 connector or get a new maf adapter. But if I would gain power by using the VE or Maxima maf then I would switch. I'm asking because I need to tell JWT what maf I want for my ecu program.
91 SE-R w/DET
02 G20 Sport 5spd
94 Miata "homobile"
93 240SX Family Project
Old 05-17-2004, 08:40 AM   #2 (permalink)
retired
Re: VE maf vs. Maxima maf vs. bored DE maf
I'm thinking maybe the Maxima and VE/Pathfinder MAF may have power gains, 75mm(3") maf vs. 54mm. They can also both measure more air. I redrilled my MAF adapter. Just a little info to help.
-Nate
NOT SR20 POWERED
needs.
Old 05-17-2004, 11:31 AM   #3 (permalink)
WASHED UP
No power gains under 190 hp. around that hp the bigger maf gains 1-3 hp because its more free flowing.The ve maf also good for more HPthan stock sr20.
Old 05-17-2004, 10:54 PM   #4 (permalink)
VE junkie
also i dont believe any power gains unless you have a 3 inch intake and larger tb.
Old 05-18-2004, 07:15 AM   #5 (permalink)
www.FAIRTAX.org
Well I plan on getting the HS Gen 6 with VE flange, 3" exhaust, and the cams. I'll prob add a 50 shot at some point too.
I have a HS cai which is 3" in diameter but I havn't changed the TB.
Old 05-18-2004, 12:23 PM   #6 (permalink)
eric96ser's Avatar
Trader Rating: 16 (100%)
I'm using a VE(Pathfinder) MAF, becuase I got it cheap, my ECU was being programmed, so that saves money, and my DE MAF was bad. If you are getting a JWT ECU, and can get a Pathfinder MAF for cheap, do it. You will also need a bigger coupler for the CAI, and a Maxima MAF adapter from PlaceRacing. Hotshot doesn't make an intake for the Maxima, so they don't have it.
1991 Sentra SE-R
The community is here.
Old 05-19-2004, 08:01 AM   #7 (permalink)
www.FAIRTAX.org
Does it matter what year maxima for the adapter?
Old 05-19-2004, 10:27 AM   #8 (permalink)
eric96ser's Avatar
I got one for a '95
Old 05-19-2004, 10:40 AM   #9 (permalink)
WASHED UP
i posted this in anoth threat but here it is
Ve maf on 91-94 car needs ve maf pigtail
maxima maf on 91-94 car needs maxima pigtail 92-94
ve maf on 95 up se-r plugs into stock harness
maxima maf on 95 up needs maxima pigtail 95-up
maxima maf 95-98 is for 95 up se-r .
maxima maf 92-94 is for 91-94 se-r.
Old 06-23-2004, 06:44 PM   #10 (permalink)
www.FAIRTAX.org
I picked up a 96 Maxima maf with pigtail today for $40. I just called JWT to do the chip swap. I need to free up the bored de maf for my se-r so I can upgrade to the 4-bar program
I was going to order one of those cheapo Maxima filters from Ebay that have a maf adapter then comes with them. Anyone gotten one of them before?
Old 06-23-2004, 10:13 PM   #11 (permalink)
Where'd you get it from?
Dan_93SER is offline   Reply With Quote
Old 06-23-2004, 10:20 PM   #12 (permalink)
www.FAIRTAX.org
All Foreign Auto Parts here in Pittsburgh. They had a few more too. http://www.allforeignautoparts.com
