Old 05-19-2004, 11:24 PM   #1 (permalink)
Out of business
Trader Rating: 44 (100%)
FAns wont shut of
did a double VE swap, my friend and i did both of our motors this week, we started his up first,after 5 minutes the fans came on, then they never seemed to go off even after 15 minutes running. he used his DE thermo switch, and i used my ve thermo switch
****when i say thermo switch, it is the one behind the intake manifold next to some valve
same thing when i started up mine after 5 minutes, fans came on then would not shut off
need some feed back
In Loving Memory of ZAD,We LUV Ya ta Death, Save us a Spot Next To Ya Up There, we'll see you soon
He can make 200,250 or even 300whp! Because at the end of the day, He's not going no where but up and down Liberty Avenue stuntin for the rest of his fellow Indian friends!
If ya want JDM go the fu_k to Japan
4Doors and not 2 are the real Sunny's
RE-Spect is offline   Reply With Quote
Old 05-19-2004, 11:31 PM   #2 (permalink)
eric96ser's Avatar
Trader Rating: 16 (100%)
Re: FAns wont shut of
AC on? It sounds like the ECU might be in fail safe mode. If it thinks the temp is too high, it will turn the fans on. You did hook the ECU temp harnes up, right?
1991 Sentra SE-R
The community is here.
Old 05-19-2004, 11:55 PM   #3 (permalink)
VE junkie
also you may have had lots of air bubbles in the system at that point and the ecu thought the motor was hotter than it really was, causing the fans to stay on. remember, there is a bleeder screw on the top of the thermostat housing.
Old 05-20-2004, 09:16 AM   #4 (permalink)
Godzilla
need some feed back
Did it overheat at any point in time?
IN BOOST WE TRUST.
Specialist-V is offline   Reply With Quote
Old 05-20-2004, 10:45 AM   #5 (permalink)
Out of business
both cars do the exact same thing , no overheating at all,
something funny happens with the needle, with the old motor, when warming up, the needle wil go up slowly<temp guage>, but now it will warm up for 5 minutes the fans will come then 2 minutes later the needle will shoot the the middle and stay there, well i mean not the middle just a little under the middle
i know your needle should start moving before your fans come on
Old 05-20-2004, 10:51 AM   #6 (permalink)
Charlie Brown look alike
Trader Rating: 23 (100%)
Did you change the temp. sending unit?
Peanuthead is offline   Reply With Quote
Old 05-20-2004, 01:15 PM   #7 (permalink)
WASHED UP
Ask the same guy who installed your sr16ve cams .He good at figuring out these things.
Old 05-20-2004, 01:50 PM   #8 (permalink)
Out of business
i used the ve temp sending unit, was i supposed to use the de one
Old 05-20-2004, 01:58 PM   #9 (permalink)
im a humble cyclist
TuNeDseR031's Avatar
YO YO who you talking bout Tim ?
Just simply a Nobody .
TuNeDseR031 is offline   Reply With Quote
Old 05-20-2004, 03:19 PM   #10 (permalink)
Infiniti Parts Guy
If you have a DE ECU, yes.
Justin McClanahan
2007 350Z
Old 05-20-2004, 11:11 PM   #11 (permalink)
Out of business
got the fans to come on and off regularly, just bled the system, and it was all good
but the temp guage is now reading quarter way, when it used to be a little under half, will play with it tommorrow
Old 05-20-2004, 11:45 PM   #12 (permalink)
VE junkie
use the de coolant sensors bro. the japanese ones work differently....the ecm reads inputs in different values. de sensors will fix the problem. the imperative one is the two prong one that goes to the ecu. the one for the gauge will correct the funny gause problem.
Old 05-21-2004, 11:22 AM   #13 (permalink)
banned
Hey I know Tim. He's pretty good, Yo i'd say it's your ecu what are you running the de ecu, 1.6ve or 2.0ve?
Urbanracerone-old is offline   Reply With Quote
Old 05-21-2004, 11:29 AM   #14 (permalink)
qr25 tester
I am running a de ecu and do not have this problem with it. I never swaped it out.
-Bobby-
nx2krider93 is offline   Reply With Quote
Old 05-21-2004, 03:02 PM   #15 (permalink)
im a humble cyclist
hEY KESI24 WHY DON'T YOU GIVE RE-Spect your number so he can ask your advice!!!!!!
Old 05-27-2004, 07:21 PM   #16 (permalink)
Gone!!!
Trader Rating: 24 (100%)
but the temp gauge is now reading quarter way, when it used to be a little under half, will play with it tommorrow
Sounds like it's working just fine. I'd rather my gauge read 1/4 than 1/2.
93 NX2000 VE
08 Frontier Se
BORNGEARHEAD is offline   Reply With Quote
