Does anyone regret having a VE or wish they had a DE w/ C3 cams for track use?
Do you regret or wish you had chosen a DE motor w/ something like C3 cams? Just curious. I'm going with a VE for my track car and was just wondering if other people went back and forth like I did. Thanks.
Re: Does anyone regret having a VE or wish they had a DE w/ C3 cams for track use?
Why? The SR16 cams are very close to the C3s. The C3s don't have the low end power the SR16 cams do. Its like having stock cams for just driving around, and C3s when you want to drive hard.
1991 Sentra SE-R
About the same pricing. Within about $200 if that. Here is what I figured:
Sr20ve motor - about $2000 shipped w/ 175 whp w/ bolton's
Sr16ve cams (if you want them) - about $400
Sr20de motor - $500 shipped
New C3 cams - $550
New springs, retainers, adjustable cam gears w/ installation - about another $750 if not more($500 in parts and $250 in labor)
After all of that is done maybe 170 whp. That is according to Mike K. and that is also assuming you have the new VE header, 3" exhaust and the other basic bolton's.
You have now just taped out (or near it) the power of a DE motor staying if you stayed all motor. The VE motor on the other hand has 175ish whp with basic bolton's. Add the new cams from JWT and it is possible that you could hit 220 whp with not too much money for the HP increase. Not to mention that the VE would be more streetable. I am only using it for a track car so streetability doesn't really matter to me other then the ocassional autox.
A VE with SR16 cams and other basic bolts ons, will be in the 185whp range. The cooling system on the VE is much better than the DE also, for track usage. The VE doesn't suffer from water pump cavitation, like the DE does.
I'm in agreeance with you Eric. Not saying a DE is better then a VE, just wondering if anyone had second thoughts or if they would have done anything differently. I only stated "The VE motor on the other hand has 175ish whp with basic bolton's" not including cams. Adding cams would be an added benefit to the equation. Just comparing a fully decked out DE or a "low end" VE. It was just for comparison.
The VE will need an oil cooler setup for road course use. DE's don't seem to heat up the oil as much (but the VE's probably run cooler because they use oil to cool in addition to the coolant)?
Do we really know that for sure? What about a C3 car that is reving to 8K? Who has tested that on the track for 30 mins and reported back to us?
With the new discoveries about the mid to low end gains on the C3s, they are looking like the cam for me. I am currently building up a motor witha stock 9.5:1 bottom end, ported head w/ 3 angle valve job and ported JDM intake manifold, thermoblock spacers, 3 inch short ram CAI, UR pulley, no powersteering, no belt driven water pump, 2.5" Formula BMW side exhaust. It's going in my hardtop NX1600 with no power anything. The combo shouldweigh around 2100 pounds without driver. Unfortunately it will have S3s, and HS gen 5 until next winter when it will get the gen 6 and C3s. I think it will make for one killer track car. It should be on the road within 6 weeks
No regrets here, it is all in what you want and what you are willing to pay for. With the VE you have the best of both worlds being that you are able to keep the driveablility for daily driving and the power for when you need it.
91 SE-R w/VVL inside
Car in TX sleeping for now and I am in ND
I was regretting getting a VE, only because it wasn't any faster than my DE for some reason... still don't know why. But it sounded way cooler . It's dead now, of course (see sig).
Not following the FSM while adjusting timing = engine go boom. Now I have a Mazda 3 hatch. Can't wait for a header!
I revved the piss out of the C3 cams back when they first came out. I was at racing school and beat on them very hard in 100 degree temps. No over heating at all. The car had all the bolt-ons and the C3 cams.
1998 SE-R, 2008 ITA Champion, SoPac Region
2002 Toyota Tundra V8 SR5, tow truck, 207 hp, 271 lb-ft
2006 Apex Silver Mitsubishi Lancer Evolution
If you blow a VE on a track car your out $2,000; if you blow a DE your only out $300. That is my biggest worry about a VE engine in a race car. I blew up an engine in my race car and simply went out and bought TWO for $275 each. I still have the spare one in my garage.
If the price of a VE drops to around $600, then it will be more cost effective to put a VE in a race car.
