Put your cam switching points here - Page 2 - SR20 Forum
Old 05-25-2004, 03:37 AM   #21 (permalink)
VE powered
Re: Put your cam switching points here
Exhaust: 4000 rpms
Intake: 4600 rpms
Yes, exhaust before intake. Dyno shows about a 1-2 hp benefit from 4000-4600 rpms with these points. I know of one other VE that also found better results switching the exhaust cam first.
Steve
autoxer7 is offline   Reply With Quote
Old 05-25-2004, 03:59 AM   #22 (permalink)
SE-R BUM
Originally Posted by eric96ser
Beast, with a better flowing header than the Gen 5, if I switch mine any lower than it is now, the power falls off after the big cams come on, then jumps back up. Try moving them much higher.
thanks eric... i thought i was running kind of low... but this is exactly what i was looking for from this post "help from each other" good job guys and your very welcome!
autoxer7.... what kind of headers and size exhaust are you running?
(New all motor) 96 B14: Sr20VE JWT ECU, Msd switches, ES mounts and Bushings,2.25 stomung exhaust, KYB shocks, Eibach Sportlines, NGK Plugs/wires, ACT HDPP & Street disc, Hotshot CAI & Headers gen. 5,N-1 intake mani/TB,thermo spacers, B15 LSD trans, AEB1 GEN. 1 Header...
Old 05-28-2004, 09:05 AM   #23 (permalink)
Originally Posted by Mr_VVL
i am at 5500 with sr16ve cams and 2.5 inch catback hks hi power thats not dyno thats how i think the car feels the best
leo, are you using the sr16 ecu? what are u using to switch the cams?
a VE, still a dream for now...
b12sr20ve is offline   Reply With Quote
Old 05-28-2004, 09:42 AM   #24 (permalink)
Old School
Has anyone played with cam phasing? Perhaps advancing the intake cam to increase overlap will be beneficial.
Lew
lshadoff is offline   Reply With Quote
Old 05-29-2004, 03:57 AM   #25 (permalink)
VVL founding father
5,200 both
212.6WHP SR20VE-N1 TB, N1 cams,JWT cam gears,N1 retainers,N1 valve springs,SR16VE M/T ,Nismo radiator(w/cap),AEBS GEN1 HEADER,N1 intake manifold W/TB , cobra maf,3" exhaust w/N1(APEXi) muffler,Greddy MSS for cam switching,Autolight gauges,Tein HA's,Cusco under cariage brace and F/R STB's,N1 sway bar,Momo ,wheel and nob, N15(zenki) lights and grill,and a system that makes my but knumb!
Silver Jon is offline   Reply With Quote
Old 05-29-2004, 08:10 AM   #26 (permalink)
seen the light
4400In and 5250Ex
Stock ECU and switch points. Dyno tested.
HP11 VE - SOLD
BCNR33 GT-R - SOLD
HP12 20V family sedan.
S14 all motor track coupe in the pipeline
madandy is offline   Reply With Quote
Old 05-29-2004, 09:37 PM   #27 (permalink)
Infiniti Parts Guy
It's been discussed, but I'm can't recall anyone sharing their tuning results publically yet.
Justin McClanahan
2008 Mazdaspeed3
1999 GSX
Old 05-29-2004, 10:36 PM   #28 (permalink)
VVL founding father
theres a good 15WHP in the cam timing.
Old 05-29-2004, 10:45 PM   #29 (permalink)
Charlie Brown look alike
Feedback Score: 23 reviews
Let's hear on how to get that HP then!
Peanuthead is offline   Reply With Quote
Old 05-29-2004, 10:48 PM   #30 (permalink)
Old School
Yes, I read that Mike Kojima found some horespower through cam adjustments. Perhaps he will chime in.
Lew
Old 05-29-2004, 11:07 PM   #31 (permalink)
N.A.S.A instructor/racer
dynoed tonight, sr16 cams,4500 both cam with hotshot c.a.i. fujitsubo header,no cat,2.5 cat back,50psi fuel pressure ,jwt ecu. afr @13.9 AT TAIL PIPE engine now has 11k on it
http://www.xxtuning.com/xxpics/jackani.gif
1991 SE-R 1.6/2.0 track #151 2000 subaru rs 3.3H-6 track #33
madddjack is offline   Reply With Quote
Old 05-29-2004, 11:13 PM   #32 (permalink)
VVL founding father
Every set up will be different , if you mock my whole set up , then my adjustments will work. But with different items , you have to dyno and tune for your car!!!
Old 05-30-2004, 01:07 AM   #33 (permalink)
eric96ser's Avatar
Feedback Score: 29 reviews
How much power did you make? Its interesting that raising the fule pressure with the JWT makes more power on VE cars. I have a flat spot that goes away when I increase the pressure. I need to re dyno with my test pipe.
Old 05-30-2004, 07:44 PM   #34 (permalink)
VVL founding father
Lew
True USDM B16 , makes the same power as a JDM , with cam timing.
Old 05-31-2004, 06:39 PM   #35 (permalink)
Too busy to post
Feedback Score: 3 reviews
4600 IN / 5400 EX no Dyno
91 VE-R - One Off - With a/c
95 Yukon 2 DR 4x4 - Z71 - Beast
NeedMore$4SE-R is offline   Reply With Quote
