Old 05-26-2004, 09:22 PM   #1 (permalink)
thegost
oops
i know i might get flamed for this but does take the same modifications to put a sr16ve in a 1.6 b13 as it would for sr20de swap?
walabe25 is offline   Reply With Quote
Old 05-26-2004, 09:50 PM   #2 (permalink)
WASHED UP
Re: oops
yes same as putting a sr20de into a 1.6 search how to put in sr20de into 1.6 and follow same guides
Old 05-26-2004, 10:45 PM   #3 (permalink)
thegost
Re: oops
i said VE not DE
Old 05-26-2004, 10:51 PM   #4 (permalink)
GT2835R
Re: oops
He said its the same.
Rey Uy
99 SE-Limited
Old 05-26-2004, 10:59 PM   #5 (permalink)
thegost
Re: oops
oh ok and i actually searched and found the answer
Old 05-27-2004, 12:04 AM   #6 (permalink)
Squeaky Cleean!
nx-r_waz's Avatar
Re: oops
Originally Posted by walabe25
i said VE not DE
I think what walabe25 meant was is there any difference swapping a 1.6 to a VE compared to a DE to VE swap......I took it the other way though (like most have it seems), as in is converting the 1.6 to VE the same as converting 1.6 to DE......just worded so you could read it either way.
***. NX-R Coupe - SR20DE Power....
nx-r_waz is offline   Reply With Quote
Old 05-27-2004, 12:33 AM   #7 (permalink)
VE junkie
Re: oops
he wants to know if its just as easy to swap a sr16ve into a 1.6 as it is to swap a sr20ve into a 2.0 litre powered car. the answer is no. a sr16 swap into a 1.6 car is just as hard as swapping a sr20ve into a 1.6 car, if not a bit harder. lots of parts needed. might as well pretend your putting in a 2.0
Old 05-29-2004, 08:14 AM   #8 (permalink)
seen the light
Re: oops
Totally understandable see as you're both Aussies
HP11 VE - SOLD
BCNR33 GT-R - SOLD
HP12 20V family sedan.
S14 all motor track coupe in the pipeline
madandy is offline   Reply With Quote
