Old 05-26-2004, 11:53 PM   #1 (permalink)
thegost
dyno numbers
i wanted to know some numbers that members have put down in their VE powered cars
walabe25 is offline   Reply With Quote
Old 05-27-2004, 12:07 AM   #2 (permalink)
Squeaky Cleean!
nx-r_waz's Avatar
Re: dyno numbers
Hit the search button man, you'll find heaps of figures out there....limit your search to the VE section only and it shouldn't take long to find what you're after.
Edit: I just did this serach:
http://www.sr20forum.com/search.php?searchid=373171
There is about 6 threads on the first search page with dyno numbers for ya. One is basically asking the same q as yours.
***. NX-R Coupe - SR20DE Power....
nx-r_waz is offline   Reply With Quote
Old 05-27-2004, 04:51 AM   #3 (permalink)
爆走
Re: dyno numbers
i just recently helped silverjon put his VE together and it did 204.3whp with tuning from JWT. it has only bolt-on mods. with a few more changes we should get another 15hp easily. 220whp is very close. i will post the dyno chart in a day or so.
Old 05-27-2004, 12:26 PM   #4 (permalink)
Re: dyno numbers
Tom, you know if you post this info people are going to want to know at least a little bit of info about what you did. That is far more then most people get wtih the stock VE. What cams? Header? etc? Otherwise its just a annoying tease.
Steve
06 G35 6MT
Old 05-27-2004, 12:33 PM   #5 (permalink)
banned
Re: dyno numbers
VEry true steve please fill us in a little better also if silverjon reads this please email me at neovvl92@aol.com or hit me up on aim i need help installing the greddy mss
Whitelightening is offline   Reply With Quote
Old 05-27-2004, 12:42 PM   #6 (permalink)
WASHED UP
Re: dyno numbers
i/e/h N1 CAMS CAM GEARS COBRA MAF 3 INCH EXHAUST.Nothing special.
Old 05-27-2004, 12:45 PM   #7 (permalink)
banned
Re: dyno numbers
what header and i guess he has springs to go with them n1 cams (thanks eric)
Old 05-27-2004, 01:47 PM   #8 (permalink)
WASHED UP
Re: dyno numbers
yes n1 springs.Not sure what header but one thing i know ve love 4-1 race headers
Old 05-27-2004, 02:45 PM   #9 (permalink)
Re: dyno numbers
That HP figure makes sense now.
Old 05-27-2004, 02:50 PM   #10 (permalink)
En mi barrio..
Re: dyno numbers
I spoke to John last night and he told me it was a temporary header on the engine right now. Should have something different (and better) in a few weeks.
Sr20 B12 is offline   Reply With Quote
Old 05-27-2004, 03:44 PM   #11 (permalink)
Re: dyno numbers
240 HP on the crank
Carsten Elmegard
TeamNissan Denmark
http://www.TeamNissan.dk
1998 Primera with SR20VE
Now with Blown SR20VE engine
TeamNISSAN is offline   Reply With Quote
Old 05-27-2004, 05:08 PM   #12 (permalink)
Re: dyno numbers
What does 240 crank hp calculate to wheel hp?? Team Nissan, what are your mod's.
lalito is offline   Reply With Quote
Old 05-27-2004, 05:24 PM   #13 (permalink)
Re: dyno numbers
Hey Lalito
It is different from car to car how much power is lost in drivetrain. But I will guess 20HP
I have Fuji header, SR16VE cams, K&N air intake and EFI engine control management system.
NISSAN RULES...........
TeamNissan Denmark
240 HP @ 7200 rpm
235 NM @ 7000 rpm
Old 05-27-2004, 08:10 PM   #14 (permalink)
Squeaky Cleean!
nx-r_waz's Avatar
Re: dyno numbers
Originally Posted by TeamNISSAN
Hey Lalito
Hey TeamNISSAN,
You will lose much more than 20hp through your drive train, that is not even 10% if you have 240hp at the fly. FWD drivetrain loss will be in the vicinity of 25 - 35%.
There is a guy here in Australia who has just done the conversion, stock VE engine, VE ECU, VE injectors, VE maf and he dynoed (first time) at 102 kW at the wheels. The stock VE makes 187hp at the fly (which is about 140kW IIRC). He would be making *close* to the stock power figure at the moment as he is runing all the standard VE gear, and therefore would be losing something like 35 - 40 kW through his drive train - about 30%.
EDIT- I just had a bit of a looksie - it seems FWD losses are more like 10 - 20% (15% seems to be the generic assumption for FWD drivetrain loss, AWD is about 30%...)
Old 05-28-2004, 12:01 AM   #15 (permalink)
Neo'ed
Re: dyno numbers
A drive train loss really shouldn't be a percentage imo. More likely a fixed loss of power.
Old 05-28-2004, 12:08 AM   #16 (permalink)
VVL founding father
Re: dyno numbers
If you want some help pm me with your #.
212.6WHP SR20VE-N1 TB, N1 cams,JWT cam gears,N1 retainers,N1 valve springs,SR16VE M/T ,Nismo radiator(w/cap),AEBS GEN1 HEADER,N1 intake manifold W/TB , cobra maf,3" exhaust w/N1(APEXi) muffler,Greddy MSS for cam switching,Autolight gauges,Tein HA's,Cusco under cariage brace and F/R STB's,N1 sway bar,Momo ,wheel and nob, N15(zenki) lights and grill,and a system that makes my but knumb!
Silver Jon is offline   Reply With Quote
Old 05-28-2004, 12:11 AM   #17 (permalink)
VVL founding father
Re: dyno numbers
Who ever said i have N1 springs? The header is a Hotshot Gen 5.
Old 05-28-2004, 04:19 AM   #18 (permalink)
Re: dyno numbers
so what springs are you using? retainers?
93.5 G20 VE 3 inch exhaust,JWT ECU,5k pill(one trigger) no weight reduction LSD SE-R Transmission 14.805@95.041
Will be turbo'd with Aquamist soon to come
SR20loper is offline   Reply With Quote
Old 05-28-2004, 06:21 AM   #19 (permalink)
www.FAIRTAX.org
paNX2K&SE-R's Avatar
Trader Rating: 66 (100%)
Re: dyno numbers
No its most definatly not fixed because its not linear. People use % because its fairly close and they don't have to calculate it which can be time consuming.
91 SE-R w/DET
02 G20 Sport 5spd
94 Miata "homobile"
93 240SX Family Project
Old 05-28-2004, 08:52 AM   #20 (permalink)
Re: dyno numbers
hey silver jon, great numbers...did u use an open exhaust?
a VE, still a dream for now...
b12sr20ve is offline   Reply With Quote
