Old 05-28-2004, 08:59 AM   #1 (permalink)
banned
sensor question
i had the de temp sensor and de aac valve when i was running the de ecu,now that i swithced to the ve ecu should i switch back to the ve sensors
Whitelightening is offline   Reply With Quote
Old 05-28-2004, 02:25 PM   #2 (permalink)
eric96ser's Avatar
Trader Rating: 16 (100%)
Re: sensor question
With the temp sensor, yes. You can use either AC valve though. I'm using the VE AAC on my car.
1991 Sentra SE-R
The community is here.
Old 05-28-2004, 07:14 PM   #3 (permalink)
VE junkie
Re: sensor question
keep the ve iac valve with either ecu. no need to swap it. definitely swap the sensor, they work off of different ohm resistances i believe. or something.
Old 05-28-2004, 07:14 PM   #4 (permalink)
banned
Re: sensor question
what happens if i leave the usdm sensor in.i am not sure if i have the ve sensor plug.
