Old 05-28-2004, 07:48 PM   #1 (permalink)
VE powered
uh-oh, failed emissions test
I just failed the WA state emissions test with my VE. Here is the pertinent data:
Cruise Limit HC (ppm): 160
Cruise Emissions HC: 214
Cruise Result HC: FAIL
Cruise Limit CO%: 1.2
Cruise Emissions CO%: 0.77
Cruise Result CO%: PASS
Idle Limit HC (ppm): 220
Idle Emissions HC: 213
Idle Result HC: PASS... barely!
Idle Limit CO%: 1.2
Idle Emissions CO%: 0.18
Idle Result CO%: PASS
The cruise part of the test is done on a dyno. In my case this was 2nd gear at about 25 mph or 2000 rpms.
According to the handout they give you when you fail "... a very lean air/fuel mixture can cause HC failures." I'm running with an adjustable FPR at 28 psi at idle (stock on a DE is 36 psi). I'm thinking all I need to do is tune my FPR for 36 psi and retake the test. Thoughts?
Edit: I think a very lean air/fuel mixture would be a problem if I'm getting a misfire at idle... I'm quite certain this isn't the case. I was thinking instead of doing the Jay Hass trick of dumping a gallon on denatured alcohol in a 1/4 tank of gas would do the trick?
Thanks,
Steve
autoxer7 is offline   Reply With Quote
Old 05-28-2004, 08:11 PM   #2 (permalink)
Coropate greed hater
Re: uh-oh, failed emissions test
Could be a bad cat too. Your CO emmissions weren't too far from the limit.
-The Usual Suspects
Old 05-28-2004, 08:35 PM   #3 (permalink)
VE powered
Thanks. Yeah, I was thinking that, too. I have an aftermarket cat (Random Tech) that is about six years old.
Old 05-28-2004, 09:30 PM   #4 (permalink)
VE powered
Here is a fairly simple explanation of what to expect with ignition timing and fuel mixture changes: Aussie emissions tuning
I'm gonna try retarding the timing by about 7 degrees and lean the fuel mixture just a couple more psi.
Steve
Old 05-28-2004, 10:26 PM   #5 (permalink)
My guess is at that fuel pressure you are running really lean. Oh, well your engine not mine
Steve
06 G35 6MT
Old 05-29-2004, 08:06 PM   #6 (permalink)
VE junkie
yeah mine is at 50 psi with stock reg. 28 is lean probly.
Old 05-29-2004, 09:55 PM   #7 (permalink)
Infiniti Parts Guy
you could put a restrictor plate right behind the cat (where the gasket sits) to help keep the cat hot too?
Justin McClanahan
2007 350Z
Old 05-31-2004, 10:51 AM   #8 (permalink)
Just LTrain Again..
I believe when you do that, the CO% shoots up. I may be wrong, but IIRC that has worked for some people with luck but the same "can't have your cake and eat it too" applies here. I'd say give it a shot. But it may flip flop your levels.
-Linus
VVL
'94 SE-R w/ VE ....sale pending
"Relax, alright? My old man is a television repairman, he's got this ultimate set of tools. I CAN FIX IT."
VVLtrain is offline   Reply With Quote
Old 05-31-2004, 01:50 PM   #9 (permalink)
the spookman
hmm i failed for emmisions. bad cat and exhaust system leaks.
05 Legacy GT
93 NX2000 w/VE
(\__/)
(O.o )
Old 06-03-2004, 05:14 AM   #10 (permalink)
Internet Hero
my SER just failed WA state emissions too. my hydroCarbon number was 2000+
it gets 160 miles on a tank of gas and was getting a CEL for cylinder #1 misifre after plugs, wires, cap, rotor and knock sensor were replaced. 02 sensor might fix my problem but either way i've spent enough $$ to just get the damn waiver
guess thats what happens with a $1500 car. good luck to a fellow emission failer.
where in WA you at?
xt_out is offline   Reply With Quote
Old 06-06-2004, 06:14 AM   #11 (permalink)
VE powered
Good news... I finally passed on the 3rd attempt.
2nd test (retarded the timing 10 degrees to 5 deg BTDC):
Cruise Emissions HC: 202
Cruise Emissions CO%: 0.79
Idle Emissions HC: 96
Idle Limit CO%: 1.2
Idle Emissions CO%: 0.03
3rd test (installed new CATCO cat replacing 6-7 yr old Random Tech, timing 5 deg BTDC):
Cruise Emissions HC: 98
Cruise Result HC: PASS!
Cruise Emissions CO%: 0.16
Idle Emissions HC: 38
Idle Limit CO%: 1.2
Idle Emissions CO%: 0.01
Retarding the timing improved idle HC emissions by more than 50%, and a new cat improved cruise HC emissions by 50% and idle HC emissions by a further 60%. I bought the direct fit CATCO cat complete with flanges from Summit Racing, part no CTO-4087, $112.94 delivered. The same "4087" cat can be ordered from here for $93.68 delivered, but I needed it before this weekend which is why I ordered mine from Summit (in stock, two days via UPS Ground). Even though the CATCO is advertised for a 240SX it had the exact same dimensions as my old Random Tech.
Steve
Old 06-06-2004, 12:16 PM   #12 (permalink)
Just LTrain Again..
Cool. Just out of curiosity, does Washington state have only an idle test or do they do a rolling test for emissions too?
-Linus
Old 06-07-2004, 02:27 AM   #13 (permalink)
Wants Primera Race Motor
-Linus
i think this would count as a rolling test. Cool thing about livin in Kitsap county Steve. we dont need to do emission testing i have plenty of friends that roll around w/ no cats. not that i would do such a thing
Brian
My SE-R
14.5@ 94 all motor
click for my DET install
12.5@ 114 boosted 295 whp 298 tq
BlkB14 is offline   Reply With Quote
