Old 05-31-2004, 03:32 AM   #1 (permalink)
Pulsar 20V
cam pulley
My tuner told me I may need adjustable cam pulleys for my VE
its a 189hp SR20VE with 20V interior.
I have been looking for them since last year, but all replies
from Japan (HKS, JUN, TOMEI...etc) have no idea which adj.
cam pully can be put on the VEs.
Now me and my tuner are trying to borrow some adj. pulley from
Silver (15/14) and see which one will match, a slow & stupid way.
If I've found out the answer I'll post here to share with you guys.
PennyFan is offline   Reply With Quote
Old 05-31-2004, 03:38 AM   #2 (permalink)
Re: cam pulley
I thought people were putting jwt cam gears on their ve's?
Originally Posted by totaled200ser View Post
i would just run no manifold, you will gain the best flow. if you guys want to get 10 hp, why not buy a tornado?
Black98SeR is offline   Reply With Quote
Old 05-31-2004, 09:14 AM   #3 (permalink)
Squeaky Cleean!
nx-r_waz's Avatar
Re: cam pulley
I think the number of teeth on the 20V cam gears are different to all the other VE's (and hence the number of teeth on the crank is different, ie. smaller teeth). If you are running these parts, you will not be able to use JWT's.
Andreas Miko posted this up somewhere IIRC correctly, he was dissappointed he won't have access to adjustable cam gears for his 20V project.
Here it is, just found the thread:
http://www.sr20forum.com/showthread....ht=cam+gear%2A
***. NX-R Coupe - SR20DE Power....
nx-r_waz is offline   Reply With Quote
Old 05-31-2004, 09:32 PM   #4 (permalink)
Pulsar 20V
Re: cam pulley
my engine is 189hp SR20VE, not 20V VE, just using the 20v cam.
cant normal sr20ve cam gear match with 20V cam shaft?
Old 05-31-2004, 11:16 PM   #5 (permalink)
eric96ser's Avatar
Trader Rating: 16 (100%)
Re: cam pulley
Any cam gear that fits a DE, will fit a VE. JWT or Nissan Motorsports are the best ones, becuase they can not slip.
1991 Sentra SE-R
The community is here.
Old 05-31-2004, 11:50 PM   #6 (permalink)
VE junkie
Re: cam pulley
just because youve swapped the cam doesnt mean you swapped the new 20v cam gear in as well. if your using 189hp motor cam gears, u can use jwt. 20v cam gears will not be swappable because the chain has too many tightly knit links and more camgear teeth
Old 06-02-2004, 12:45 AM   #7 (permalink)
Pulsar 20V
Re: cam pulley
So I just use cam gears that is design for SR20DE.
thank you very much.
Old 06-02-2004, 01:42 AM   #8 (permalink)
Re: cam pulley
Try OBX,
http://www.obxracingsports.com/
They seem to have these pulleys available, also lots of yummy bits and pieces like overdriven crank puleeys etc...
Good luck,
Adrian
amdeman is offline   Reply With Quote
Old 06-02-2004, 05:20 AM   #9 (permalink)
VVL founding father
Re: cam pulley
Be careful with any other than the JWT , Shaggy and i both had bad run ins with the others!!!!!
212.6WHP SR20VE-N1 TB, N1 cams,JWT cam gears,N1 retainers,N1 valve springs,SR16VE M/T ,Nismo radiator(w/cap),AEBS GEN1 HEADER,N1 intake manifold W/TB , cobra maf,3" exhaust w/N1(APEXi) muffler,Greddy MSS for cam switching,Autolight gauges,Tein HA's,Cusco under cariage brace and F/R STB's,N1 sway bar,Momo ,wheel and nob, N15(zenki) lights and grill,and a system that makes my but knumb!
Silver Jon is offline   Reply With Quote
