Old 06-03-2004, 05:52 PM   #1 (permalink)
bad VE dyno numbers
I made 166.9 HP and 137.9 Torque kinda sucks here are my mods
hotshot gen 5 header port matched, AEM cold air ntake, no cat, 3 inch to 2 1/2 rear section to a 3 inch dual outlet magna flow muffler, fidanza flywheel, ACT hd with 4 puck, SE-R LSD tranny, one msd trigger set at 5k, JWT VE ECU,
I also trapped at like 95 mph in a Ungutted no weight reduction box still in the back G20
93.5 G20 VE 3 inch exhaust,JWT ECU,5k pill(one trigger) no weight reduction LSD SE-R Transmission 14.805@95.041
Will be turbo'd with Aquamist soon to come
SR20loper is offline   Reply With Quote
Old 06-03-2004, 06:08 PM   #2 (permalink)
eric96ser's Avatar
Trader Rating: 16 (100%)
Re: bad VE dyno numbers
Here is the chart:
1991 Sentra SE-R
The community is here.
Old 06-03-2004, 06:12 PM   #3 (permalink)
The only thing me and Eric can thing of is its the AEM cold air intake being its 2.5 and designed for the regular DE.
also found out that the WHP are actually lower like 5-3 hp lower its DIN not SAE
if anyone has any input let me know
Old 06-03-2004, 06:55 PM   #4 (permalink)
VVL founding father
whats your timing at? What injectors/MAF/? How many miles on the VE?Which tranny?
212.6WHP SR20VE-N1 TB, N1 cams,JWT cam gears,N1 retainers,N1 valve springs,SR16VE M/T ,Nismo radiator(w/cap),AEBS GEN1 HEADER,N1 intake manifold W/TB , cobra maf,3" exhaust w/N1(APEXi) muffler,Greddy MSS for cam switching,Autolight gauges,Tein HA's,Cusco under cariage brace and F/R STB's,N1 sway bar,Momo ,wheel and nob, N15(zenki) lights and grill,and a system that makes my but knumb!
Silver Jon is offline   Reply With Quote
Old 06-03-2004, 07:02 PM   #5 (permalink)
I love Katamari
so you have a 3" test pipe to 2.5" b-pipe to 3" muff?
I'm thinking that bottleneck is what's killing your top end. It looks like you could also set the VVL lower
Bjorn is offline   Reply With Quote
Old 06-03-2004, 08:56 PM   #6 (permalink)
MAF is SE-R, VE injectors, timing at 15 degrees
you guys don't think the intake could cause this?
Old 06-03-2004, 09:58 PM   #7 (permalink)
95mph is just about right for a VE with no cams and no weight reduction.
Steve
06 G35 6MT
Old 06-03-2004, 10:05 PM   #8 (permalink)
808 SE-R MAFIA
That seems a little on the low end of average, but not by much. 170whp seemed to be the norm with hotshot headers and sr20 cams. I should be dynoing sometime this month with almos tthe exact same setup. Ill post for comparison.
nathan
sr20sleeper is offline   Reply With Quote
Old 06-03-2004, 11:14 PM   #9 (permalink)
VE junkie
jwt ve ecu? umm....? what timing. timing is everything. timing timing timing.
Old 06-04-2004, 01:07 PM   #10 (permalink)
Infiniti Parts Guy
JWT says 15º with their ECU, which he mentioned he was at above.
I doubt a slight difference in intake piping is gonna unleash a ton of power. It's probably somewhere else in the system. Also, did JWT go that high with the rpms knowing you have SR20VE cams in there?
Also, what sorta dyno do they have over there, is it a standard dynojet?
Justin McClanahan
2007 350Z
Old 06-04-2004, 04:25 PM   #11 (permalink)
I still dont think anything is wrong. What type of dyno? My guess is its correction factors of some sort. 95mph with a stockish ve is right on the money in many ways.
Old 06-04-2004, 07:21 PM   #12 (permalink)
Infiniti Parts Guy
Yeah, 95mph isn't bad, especially in hot AZ....
Old 06-04-2004, 10:10 PM   #13 (permalink)
SE-R BUM
YOu think its the switching points...does the ve increase hp power when the intake and the exhaust cams is set at different points... or just broaden the powerband...
i have the same exact set up but i have a HS intake besides and the exhaust im running 2.25 so i think my ve is chocking right now... so i think im running around the same horse power
(New all motor) 96 B14: Sr20VE JWT ECU, Msd switches, ES mounts and Bushings,2.25 stomung exhaust, KYB shocks, Eibach Sportlines, NGK Plugs/wires, ACT HDPP & Street disc, Hotshot CAI & Headers gen. 5,N-1 intake mani/TB,thermo spacers, B15 LSD trans, AEB1 GEN. 1 Header...
Old 06-04-2004, 10:13 PM   #14 (permalink)
the munchkins father
from whta kojima was saying that the ve likes large exahust like 3"
jimmy
the cars are second now, my daughter is the only thing i want
i love you gia 7-3-2003
http://www.sr20forum.com/showthread.php?t=76928 for all the guys interested in a complete sr20det with incon turbo raffle $40 a ticket. raffle being held by NeedaSe-r
jbanach77 is offline   Reply With Quote
Old 06-05-2004, 01:48 AM   #15 (permalink)
eric96ser's Avatar
Moving the crossover points won't make more peak power, it will just make more mid range power. I agree that his crossover needs to move down. If both cams are being switched at the same time, 4500 looks like the best place.
Old 06-05-2004, 04:08 AM   #16 (permalink)
爆走
that dyno was wack
Old 06-05-2004, 07:44 AM   #17 (permalink)
Originally Posted by bigtom
that dyno was wack
Whack as in horrible numbers or sh*tty picture or just a sh*tty dyno?
Also Bigtom you've had alot of dyno experience how much HP does the WAI give Vs. the cold air? also AEM is 2.5 inches do think that really has an effect? most VE guys are running WAI 3 inch.
thanks for your help
Old 06-05-2004, 10:48 AM   #18 (permalink)
that dyno was wack
I agree or else there might be something wrong with some signal to the ECU
Carsten Elmegard
TeamNissan Denmark
http://www.TeamNissan.dk
1998 Primera with SR20VE
Now with Blown SR20VE engine
TeamNISSAN is offline   Reply With Quote
Old 06-05-2004, 02:47 PM   #19 (permalink)
On Vacation
My homeboy put out 163 HP completely stock in his VVL. He had DE MAF.
Manny
Manny E.
523 whp & 409 wtq ---RETIRED
SE-Rawkus is offline   Reply With Quote
Old 06-05-2004, 03:05 PM   #20 (permalink)
Jah Rastafari
Trader Rating: 55 (100%)
Manny
He did the 163 with VE 333cc injs, DE MAF and DE comp. He had a JWT pop charger and 2.5 inch exhaust thats it.
I think thats what it was
