Old 06-13-2004, 03:28 AM   #1 (permalink)
Trader Rating: 2 (75%)
Tach problems, with Rpm Switch and Standalone
Ok, I got two summit racing RPM Switches (all wired up, and controling the intake and exaust solonoids on my SR220VE in my G20), and my standalone fuel managment (mostly wired up). When both are wired up, my tach dies????
The tach signal I am using is the one that is right off the back of the ecu, as I could not find any information about one on the distributor...
Just curious if any one else has tried to wire up any rpm switch or standalone fuel management or pigy back like an emanage, or safc, and had the same problem, of the tach diing once another device is on that circuit...
Any ideas would be great!!!
phatg20 is offline   Reply With Quote
Old 06-14-2004, 06:43 PM   #2 (permalink)
meh
Re: Tach problems, with Rpm Switch and Standalone
since the DE dist can be used on the VE, this may help. the DE dist has a 4 wire plug out of the distributor in a shielded cable:
-12v=org/blu or pin 47,109,38....on a b13 USDM DE ecu
-ground=blk or pin 48 on a b13 USDM DE ecu
-cyl pulse trigger=blu or pin 22&30 on a b13 USDM DE ecu
-reference trigger=yellow or pin 40&31 on a b13 USDM DE ecu
what kind of standalone are you using? does it have on/off outputs you can activate the solenoids with?
*edit*
i may have the cyl pulse and reference backwards.....dont remember
www.full-race.com
javierb14 is offline   Reply With Quote
Old 06-16-2004, 07:11 PM   #3 (permalink)
I am using the DE dist....
I have two summit boxes wired up (one for each solonoid), and the standalone i am using is a MegaSquirt...... I tapped the tach signal that goes from the ecu to the dash.... I can have the summit boxes, and the tach working, or the megasquirt and the tach working, but i cant have all... As soon as i have both the megasquirt and the summit boxes my tach dies..
*edit*
Old 06-17-2004, 12:20 AM   #4 (permalink)
Infiniti Parts Guy
try tapping off the distributor signal going to the ECU?
Justin McClanahan
2007 350Z
Old 06-17-2004, 12:23 AM   #5 (permalink)
The summit boxes, wont work with ANY of the lines from the dist..... ???
Old 06-17-2004, 01:41 AM   #6 (permalink)
Infiniti Parts Guy
yeah they do... on the lowports it's the one off the coil plug... green and yellow I think?
Old 06-17-2004, 05:43 PM   #7 (permalink)
Which wire on the 99 dist?
Old 06-18-2004, 05:39 PM   #8 (permalink)
Master Cunnilingust
Trader Rating: 37 (100%)
Terminal 1 on the ECU, W/B, is the ignition signal to the ECU from the distributor in a '99 G20.
- Rob
Old 06-28-2004, 05:01 PM   #9 (permalink)
use a tach adapter. msd...
THE VE-T IS ALIVE.
-92 sentra vvl-t 470whp...385tq. 24lbs.
-98 sentra SE/ sr2ve powered.
-2005 c230 kompressor.
-2006 Lancer Evolution 9 MR.
http://images.cardomain.com/member_i...66_28_full.jpg
your local asshole.
LanceSR20 is offline   Reply With Quote
