Old 06-24-2004, 09:42 PM   #1 (permalink)
banned
help with MSS
i have most of it hooked up.i dont know where the blue wire or the white wire go.if these wires arent hooked up will the mss still work.i have the wires from the solenoids going to the relay then the green yellow from the mss to the relay.and there are 2 grounds going to each relay.
the orange is going to the batter with a fuse for constant power,the red is to a switched 12v,grey is to ground,brown to the tach wire,blue not connected,white not connected.also where do the other 2 wires on the solenoids go.
Whitelightening is offline   Reply With Quote
Old 06-24-2004, 09:53 PM   #2 (permalink)
banned
Re: help with MSS
should the black wire from the mss be going to the battery - or can it be just grounded to the body.does it matter.silver jon if you get this pm me your number i lost it i need to call you tomorrow
Old 06-24-2004, 10:27 PM   #3 (permalink)
banned
Re: help with MSS
2 months with VE and still no cam activation this sucks lol
Old 06-24-2004, 10:35 PM   #4 (permalink)
Re: help with MSS
Quoted from needmore$forser, but i dunno how ro work forum yet
Sean from JGY got this from greddy
*Red = 12volt + IGNITION
*Black = 12 volt - GROUND
*Brown = RPM
Light Blue = Speed
Orange = 12VOLT CONSTANT
____
*Yellow = + INTAKE
*Green = + EXHAUST
_____
White = TPS
Grey = GROUND
donkeysass98 is offline   Reply With Quote
Old 06-24-2004, 10:44 PM   #5 (permalink)
banned
Re: help with MSS
yea i got all that and the relays and the brown wires from the solenoids to 12v+ and i know its not working *** the oil pressure should jump up on my gauge but it stays about 75-80 psi.oly wires not connected are the blue and white is this why?
Old 06-24-2004, 10:57 PM   #6 (permalink)
Re: help with MSS
Writing for Whitelightening because he has to go to work...
Ok but what he needs to know is where the speed wire is and on the tps there are three wires White, black, and red with a yellow stripe I believe. Which wire do you tap into there??
From what I read earlier I think the blue is not necessary but the tps one is. Anyone. Silverjon?? We are both doing this at the same time so any help would be appreciated
lalito is offline   Reply With Quote
Old 06-25-2004, 12:53 AM   #7 (permalink)
Re: help with MSS
Im not too sure *** I dont have a VE or MSS to get to but common sense tells me it should be the wire running to the ECU. Im not being sarcastic at all, christ I dont *** how to make this post not make me look like an asshole lol. Im 17 gimme a break. Someone smart pikk up this topic for me, please.
Old 06-25-2004, 04:29 PM   #8 (permalink)
Re: help with MSS
bump...
common y'all help some brothers out. Also, is brown wire rpm-- does that go to tach wire I assume???
