Old 06-29-2004, 02:40 PM   #1 (permalink)
banned
no exhaust
if i ran open header at the track would there be any gains.if so would it be enough gains that it would be worth taking it off lol
Whitelightening is offline   Reply With Quote
Old 06-29-2004, 02:41 PM   #2 (permalink)
SE-R Rawkess
Re: no exhaust
1-2, maybe even 3 hp.
viprdude is offline   Reply With Quote
Old 06-29-2004, 02:43 PM   #3 (permalink)
banned
Re: no exhaust
wow fast response so not really worth taking it off
Old 06-29-2004, 03:13 PM   #4 (permalink)
SE-R Rawkess
Re: no exhaust
gotta help out everyone. im pretty sure it wont give u much. i dont have an sr20ve, but to my theorhetical mind, it shouldnt yield much power to you.
Old 06-29-2004, 05:45 PM   #5 (permalink)
WASHED UP
Re: no exhaust
open header on a ve give about 5-10 hp i ran went from 13.9@ 98 with full greddy exhaust to 13.7@101 running open header..
Old 06-29-2004, 06:26 PM   #6 (permalink)
banned
Re: no exhaust
wow i think its defintly worth crawling under and taking it off at the track.thanks kesi
Old 06-29-2004, 11:03 PM   #7 (permalink)
Infiniti Parts Guy
Re: no exhaust
It really just depends on what exhaust setup you have. The Greddy SP is probably a tad more restrictive than some of the 2.5" setups out there, and those with a 2.5" setup still see a little bit of a gain, even with the larger piping. I'd expect you'd probably see a good deal of power from a test pipe and larger piping. Headers will cause this to vary a bit too, if you have a better header i'm sure it'll probalby make a bigger difference, as there won't be a restriction left once you drop the exhaust.
Basically if you have a stock exhaust it'll make a BIG difference, if you have an aftermarket DE exhaust (2.25-2.5" setup) it'll make a difference, if you have a large system already (3.0" for example) it won't make much difference.
If that makes sense....?
Justin McClanahan
2007 350Z
Old 06-30-2004, 01:56 AM   #8 (permalink)
Re: no exhaust
This kid I know has like a switch in his car (bmw m3) and he can flip his car to open headers--probably an electric mechanism of some sort. But, I have never seen his car in person.
drummer4lifex is offline   Reply With Quote
Old 06-30-2004, 03:15 AM   #9 (permalink)
GT2835R
Re: no exhaust
Its an eletric cutout. Some turbo guys use those, I might end up using one too.
Rey Uy
99 SE-Limited
Old 06-30-2004, 12:20 PM   #10 (permalink)
Re: no exhaust
i think open exhaust is beneficial especially at top end which is in faVOR of drag racing. most all motor hondas here use open exhaust
a VE, still a dream for now...
b12sr20ve is offline   Reply With Quote
