Go Back   SR20 Forum > Classifieds > Suspension & Chassis
Old 01-20-2006, 08:22 PM   #1 (permalink)
BRAND NEW, Shortened Konis
These are Koni's, they are not the ones I normally sell. They are very, very similiar to the 8611's but don't have compression adjustability. They are rebound adjustable (require removal to adjust). They require the bigger housing to work. They will handle 500lb springs. They will work on a B13/14/15. They are not installed in the housings at this time. I am getting out of the Koni install business so these have to go. You can buy them a couple ways. BUT THEY WILL ONLY WORK WITH COILOVER SETUP. You or I need to weld the perch on. This is a advantage for those who weld themselves. Or I will do it for you.
Inserts are 132 each. Total $264
Housings for the Inserts are $50 for the set. YOU CAN NOT USE YOUR OEM SENTRA HOUSINGS with these inserts.
I will charge $50 to weld the perch's on if you need that. And 75 to install them in the housings. If you want to weld and install them I will prepare them for $25 (you save $100), you can weld the perch and install them yourself after welding. I will help you with the install. All the hard parts will be done for you. It's a bolt in affair + a little epoxy. I can't install them till a perch is welded on.
So if you weld, you can pay 264+50=314 and have a great setup. This setup is adjustable, and will be very similiar to a 8611 setup from the drivers seat. Better then the old 8611 that has too much compresion dampeing. If you want a complete set of konis you can pay another 264 for some rears that would work great with a B13 and also handle 400+ pound springs.
These Koni's are from a Maxima. Rears would be from the front of a B14 sentra.
Steve
06 G35 6MT
Old 01-20-2006, 08:40 PM   #2 (permalink)
LikeTheMovies's Avatar
Trader Rating: 18 (100%)
how much are the ones you usually sell?
99 Sentra SE-L (Turbo)
*Avenir Motor/GT28R Turbo/3" Downpipe/Nismo AFPR/370cc/Calum ECU*
*Hypercos W/AGX's and ME Rear Mounts*
*VRS 2.5" Exhaust*
*NX2000 Brakes*
14.27@100mph 213whp 198tq. Old Setup
New Setup Coming Soon!! GT28R
95 200sx Se-R (For Sale)
15.061@91mph
LikeTheMovies is offline   Reply With Quote
Old 01-20-2006, 08:49 PM   #3 (permalink)
I ussually only sell them installed in the housing. So they would be 339 installed in your housings or 389 installed in my cores. These are better then the ones I normal sell by a great margin. Plus, these would have the weld on perch and I always charge $50 for that. It's a nice flat perch and cuts down on noise and makes the setup very clean.
Old 01-20-2006, 09:14 PM   #4 (permalink)
www.FAIRTAX.org
paNX2K&SE-R's Avatar
Trader Rating: 66 (100%)
What is the diameter of these inserts Steve?
91 SE-R w/DET
02 G20 Sport 5spd
94 Miata "homobile"
93 240SX Family Project
Old 01-20-2006, 09:16 PM   #5 (permalink)
Nearly 1.75. I don't have my dial calipers handy. Why do you ask?
Old 01-20-2006, 10:02 PM   #6 (permalink)
www.FAIRTAX.org
I've been (casually) looking for inserts to fit a 1 11/16" in diameter housing.
Old 01-20-2006, 10:11 PM   #7 (permalink)
What car did those come off? Sounds like a B14/15 to me.
Old 01-20-2006, 10:17 PM   #8 (permalink)
www.FAIRTAX.org
They are custom built units.
Old 01-20-2006, 10:53 PM   #9 (permalink)
Sale is pending on my first set.
Maxima inserts are 1.77. I found another set of housings rummaging around the garage looking for my dial calipers. So I can do another set just like this. This is my last set of housing. They are altima housings as well so only maxima inserts with the welded on perch again. .
Old 01-21-2006, 12:47 AM   #10 (permalink)
First set sold.
Old 01-21-2006, 01:21 AM   #11 (permalink)
SR powered S13 coupe
McCoy's Avatar
Trader Rating: 74 (100%)
Originally Posted by 98sr20ve
First set sold.
Thank you, Steve!
Old 01-21-2006, 10:34 PM   #12 (permalink)
Veritas
SERprise In WV's Avatar
Trader Rating: 17 (100%)
You will be in nirvana when you bolt on a set of Steve's Konis, Monty. Especially if these have better characteristics than my 'old' set.
Greg Perry
Huntington, WV
-'93 SE-R, 12.80 @ 110mph
The car: www.TurboChargedSE-R.com
Great parts at great prices: PowerTechPerformance.com
Old 01-21-2006, 11:04 PM   #13 (permalink)
McCoy's Avatar
I have been holding off to long on getting these, GP. I'm just glad that my wait will reward me with a strut that can serve my addiction.
Old 01-22-2006, 11:01 AM   #14 (permalink)
Second set sold as well.
Old 01-22-2006, 08:24 PM   #15 (permalink)
www.FAIRTAX.org
Monty, what happened to your STs that you had rebuilt?
Old 01-22-2006, 09:13 PM   #16 (permalink)
McCoy's Avatar
They've been sitting in the garage for the past year. The valving is to stiff for the street, even though they feel great on the track, the street ride is not worth it for me . I'm hoping to find someone to revalve them, but no luck so far .
I am pretty sure that Morris Dampeners messed something up on the rebuild, and after what I went through with them I wouldn't want to ask them to revalve them.
Old 01-23-2006, 12:29 AM   #17 (permalink)
All gone or some left Steve?
91 SE-R (AKA- The Black Bomb)
T-Dog is offline   Reply With Quote
Old 01-23-2006, 01:12 AM   #18 (permalink)
I found another set of cores. I don't know what they came off of. I need to measure them up and see what I can do with them. I can get back to you. You live close to me btw it seems.
Old 01-23-2006, 11:18 AM   #19 (permalink)
There's gotta be someone somewhere who messes with Bilsteins. Have you posted on some the "national" message boards like sccaforums.com or maybe improvedtouring.com?
I actually wish I had kept them (until Steve's deal came along ) along with a ton of other SE-R parts I sold when I thought I wouldn't need them anymore (Autopower rollbar, Corbeau seat -- although I picked one up locally that's nearly new for $80 -- various pairs of ERS springs). I guess all car geeks are like that anyway.
Edit: Maybe Koni's could fit in those housings???
Pat
'92 Sentra SE-R
'82 Camaro Z28, ESP autocross car (50% ownership)
slowSER is offline   Reply With Quote
Old 01-23-2006, 09:39 PM   #20 (permalink)
www.FAIRTAX.org
I have 2 sets of them which are mostly blown. I know there has to be a Koni insert out there that would be a perfect fit. Steve Lotho found a company to rebuild his but you don't wanna know how much that ran
