2 rear sets and one front set.
The ones on the right are rear shigspeed housings that can only be used with a coilover setup. They have a B13 front insert and actually are longer than off the shelf for more droop travel (about 2")
The ones on the left are shortened rear B13 inserts. The rather large spacer used is unecessary and it does prevent the use of the Progress sway bar because it gets in the way of the endlinks. All you have to do is take the bolt out, cut about some off of it, and then just get rid of the spacer and you will be fine. But you can use this with a stock sway bar or an Addco one. These can be used with coilovers or the stock large diameter type springs.
Shortened B13 Front, can be used with coilovers or the stock large diameter type springs.
I have 2 Koni bumpstops that will work on all three sets, the person who asks first gets them first with their struts.
The Red Inserts retail for ~$250 a pair, then add in the labor and housings...
Make me some offers.
