Go Back   SR20 Forum > Classifieds > Suspension & Chassis
Closed Thread
Old 10-26-2006, 08:12 PM   #1 (permalink)
I drive a race car again!
B13 SE-R Suspension Techniques Rear Sway Bar
Used Suspension Techniques rear sway bar for B13 SE-R.
Did have a bit of surface rust, I cleaned and repainted it a more acceptable red, but since then it's had it's share of new scratched and dings and could use another coat of paint before re-installing.
Comes with the full set of brackets, bolts, and bushings.
Nothing missing, ready to bolt right up to your car.
$120.00 shipped to your door in the continental USA via UPS Ground.
Steve
#6 ITA - 138,557 miles of bent-up motor, 50K of the new stuff
Indy Region SCCA
http://img.photobucket.com/albums/v3...5/MidOhio2.jpg
Racerlinn is offline
Old 11-06-2006, 10:26 AM   #2 (permalink)
Two week bump.
Old 11-07-2006, 12:24 PM   #3 (permalink)
nissan crazy's Avatar
do those mount to the stock location ???
nx2000 with 20k orig miles and going off the deep end
2000 Xterra ( Wifes new get around)
2004 titan for the towing duties
http://www.cardomain.com/id/edog145
k6 gsxr 600 new toy
and the other hobbie
http://viewmorepics.myspace.com/inde...eID=1261402640
nissan crazy is offline
Old 11-07-2006, 12:45 PM   #4 (permalink)
On the chassis, yes, they use the stock mounting points.
They do NOT attach to the stock points on the rear struts, instead using the large "L" shaped brackets that are attached to the hub using the large bolt that located the rear trailing arms.
This link shows a Progress bar, but it's the same basic concept as far as mounting points.
http://www.sr20forum.com/showthread....=progress+sway
Old 11-09-2006, 04:49 AM   #5 (permalink)
so it would fit with a set of k sport coilovers
Old 11-09-2006, 09:10 AM   #6 (permalink)
Statement or question? I am not familiar with the ksport, but I would assume so as the bar does not connect to the struts.
Old 11-15-2006, 10:14 AM   #7 (permalink)
Would you take $100 sipped for the bar
payu is offline
Old 11-15-2006, 07:15 PM   #8 (permalink)
To PR, no.
Give me a zip code, I'll estmate costs.
Old 11-15-2006, 11:07 PM   #9 (permalink)
I will give you 100 shipped to Wa. 98273
Old 11-26-2006, 12:00 PM   #10 (permalink)
Bumpage
Old 11-27-2006, 02:35 PM   #11 (permalink)
JDM WHORE TWIN
93sr20's Avatar
Trader Rating: 18 (100%)
if you will take $100 shipped just pm me your paypal and consider it sold
w10
http://picsandflicks.do-goo.net/index.htm
post anything you want
se-r commercial
http://www.youtube.com/watch?v=lgKti...ndid%3D2568109
93sr20 is offline
Old 11-28-2006, 10:12 AM   #12 (permalink)
Sold
Closed Thread
