are these a set meant for front and backs? cause i thought backs were shorter? and fronts are usually longer and have a higher spring rate than rears. those look like the fronts are shorter but do have the higher spring rate than the rears. just asking, as i happen to have a set of ground control sleeves that need just the springs...
thanks for the info. so these wouldnt fit for my DD with gr2's then?
you have some reading to do my friend.
classicaddict
B13 XE with sr20 swap(5 speed swapped)
B13 LE parts car
NX2K RIP (Aug 13 2007) parts car
NX2k soon to be parts car
NX2k my new baby!
