Getting horn to work when replacing steering wheel w/ aftermarket wheel. - SR20 Forum
Old 03-02-2005, 02:25 PM   #1 (permalink)
newbie
Pretty White's Avatar
Feedback Score: 4 reviews
This is to answer the age old question, "Why can't I get the horn to work?" when swapping from a Airbag steering wheel to a non airbag wheel.
1)Remove the stock wheel (Pretend this is a stock wheel)
2)Locate this hole on the steering column
3)Widen it a little bit with a philips screw driver of a round file. (You want the ballpoint pen spring and stud to move freely w/o binding up)
4)Find a small stud or grind/cut down a wood nail head and round it off.
5)Get a ballpoint spring (300lb progressive spring j/k)
6)Put some grease on the spring and then insert it in the hole. Then put the stud in after
7)Walla, the horn is ready to work. Nothing "technical". Nothing too complicated. A freaking ballpoint pen spring folks.
I hope this helps! Enjoy!
Originally Posted by sonny
Old 03-03-2005, 02:47 PM   #2 (permalink)
Are You VVL'n?
Feedback Score: 50 reviews
Good visuals Pretty White. Heard about the ball point spring method but didn't know how to go about it. The Momo wheel I have sitting around will be making its way into the se-r, holla.
JET
PARTING OUT: 96 CLOUD WHITE (QM1) SE-R - CLICK HERE
sr20jet is offline   Reply With Quote
Old 03-14-2005, 11:18 PM   #3 (permalink)
Big kid with gray hair
Any issues with the turn signal not canceling itself? Never had the wheel off on my NX, so forgive me if this is a dumb question. I had this problem on a Neon once when I installed a Momo.
Hammerin Hank is offline   Reply With Quote
Old 03-15-2005, 12:47 AM   #4 (permalink)
REV it up!!!!!
daxx's Avatar
Feedback Score: 38 reviews
I have a Momo steering wheel but my horn buttons are on the side, how do I get that to work? do I stick a wire in the hole(there are two wires though coming from each button) so everytime I push the button it makes contact for the horn to sound....does the other wire have to see a 12v source or something?
In Loving Memory of JJR,09/23/2006.>>>CAPT. REV
U.I.O.G.D.
SR20DEEP in Vegas
96' SE-R Patience is a Virtue - RETIRED
Pro-tech Design
The Few, The Proud..The NRR
daxx is offline   Reply With Quote
Old 03-15-2005, 01:55 PM   #5 (permalink)
newbie
Not if you position the strikers in line with the cancel switch on the hub.
Old 03-15-2005, 01:56 PM   #6 (permalink)
newbie
As long as the horn ring on on the back of the steering wheel hub, the ballpoint pen trick is all you should need.
I will take pics in a few minutes.
Old 03-15-2005, 03:11 PM   #7 (permalink)
REV it up!!!!!
daxx's Avatar
pics would be good!
TIA
Old 03-16-2005, 01:10 PM   #8 (permalink)
newbie
pics would be good!
TIA
Sorry, I been busy and my wife took the camera to take pics of a house. I will do it later on this evening.
If you do have an aftermarket steering wheel it should be included in the box with the instructions. So this should not be necessary, but I will still take pics.
Old 04-19-2005, 08:01 PM   #9 (permalink)
s13 frankenstein
Feedback Score: 7 reviews
hmmm, my hub doesnt have any pins on it..... does this mean im' sh*t out of luck when it comes to manually cancelling the turn signal
93 Nx2000 SR20DE+T - Parted out!
93 240sx SE Coupe - "Stock" and slow...
Witt19 is offline   Reply With Quote
Old 04-19-2005, 09:25 PM   #10 (permalink)
newbie
Sorry, I posted the pic in the other thread. I thought the back of the wheel wan on this thread.
Old 09-13-2005, 11:52 PM   #11 (permalink)
all motor
Feedback Score: 9 reviews
thanks for the write-up. i am going to put my steering wheel in this weekend
Classic SE-R is offline   Reply With Quote
Old 09-13-2005, 11:59 PM   #12 (permalink)
i love b13's !
Feedback Score: 23 reviews
ahh i should have seen this before i put my quick release hub on. ill prolly just make a button some where on the dash, good write up though ian.
stratton.
im back.......
Old 04-12-2007, 08:45 PM   #13 (permalink)
The picture didnt work.for the 1st one.Can you post up pictures if u can on how i can remove my steering wheel?
I need to know how to remove it so i can put the new Gt grant steering wheel.
Team Optimum
0-60 in 5 minutes
Wht91SE-R is offline   Reply With Quote
Old 04-12-2007, 09:12 PM   #14 (permalink)
merely a flesh wound
chriscar's Avatar
Feedback Score: 110 reviews
Ya earned yourself a sticky, Ian.
Old 04-19-2007, 07:34 AM   #15 (permalink)
newbie
Thanks. 2 in 10 years on the forum/mailing list.
Old 04-22-2007, 10:18 PM   #16 (permalink)
newbie
22mm socket and a hell of a lot of forceful turning. Once the nut of loose, hit the steering wheel a few times on both both sides with the backsides of your hands to loosen it,
Old 05-22-2007, 02:52 PM   #17 (permalink)
going thru life @ 1 bar
Feedback Score: 21 reviews
some of the pictures of this thread no longer are working, can any one help?
Old 08-22-2007, 08:48 AM   #18 (permalink)
NX2000 Racer
Greg Amy's Avatar
Addendum:
Don't know about the rest of you guys, but the above instruction, while helpful, weren't the whole story on my car ('93 NX). I drilled out the hole above, saw the brass/copper contact back there, but there was no power to that contact. Reason is, the power for the horn comes through the airbag circuit, the yellow-jacketed cabling with the flat connectors. When you install a Momo adapter you have to remove the clockspring, thus you lose the power wire going through the column.
The solution, thanks to Ray Kawski and Matt Ostlund, is to run the yellow/green wire from the spiral (clickspring) harness to the back of the wiper stalk assembly. That will provide power to the brass/copper contacts inside, to which the spring and the pin you create will touch.
Kawski pics are here:
http://www.e-rak.com/gallery/v/vehic...bum34/album37/
I did this last night and it works as advertised...
Greg Amy is offline   Reply With Quote
Old 02-24-2008, 10:02 PM   #19 (permalink)
Gaining
Feedback Score: 25 reviews
Ok, today I went out and tried to make my horn work on my aftermarket steering wheel, but instead of what is pictured, I was presented with something else. I encountered 3 prongs, not a hole. The prongs when pushed will go forward back into their housings. So, do these have to be removed? Does this require splicing wires? I have a 94 SE-R w/cruise control (the cruise control doesn't work though). I can't figure this out, so any help would be much appreciated. Thanks. Mike.
blackcloud is offline   Reply With Quote
Old 02-24-2008, 10:11 PM   #20 (permalink)
NX2000 Racer
Greg Amy's Avatar
Mike, you don't have an airbag, right? This topic is about cars that have the 'bags, such as the NX.
See that pin on the upper left, the top one in the left circle next to the screw? That's what you need; that is the pin that will ride against the contact wheel on the steering wheel adapter. Simply clean up those contacts, verify with a test light and/or multimeter that you have power at that pin, re-grease them lightly, and you're all set... - GA
HTML code is On
