How to:Install MSD 6al - SR20 Forum
Old 04-03-2005, 10:46 PM   #1 (permalink)
Still not my president
Feedback Score: 4 reviews
Tools needed:
wire cutters/strippers
soldering Iron
solder
electric tape(i prefer black but you can rice it out if you want )
mounting hardware
MSD set-up:
1 remove the screw that holds the little black circle cover on
cut both wires and replace the cap
insert rpm pill
MSD install:
Heavy Red wire~Battery (+)
Heavy Black wire~Battery(-)
Red Wire~12 ignition source, i used the red/black wire on the the ecu side from the coil plug
Orange wire~ coil (+) red/black on the coil plug
Black~Coil (-) green/yellow wire on coil plug
White wire~green yellow wire ecu side from the coil plug
be sure to solder all connections.
1992 nx2000:White: Sold
Danielle Wilson 2/10/07
Old 04-06-2005, 12:55 PM   #2 (permalink)
Old 04-07-2005, 12:38 PM   #3 (permalink)
yep thanks again man i appreciate it
Edit: credit to Setzer
Old 04-20-2005, 04:01 PM   #4 (permalink)
Don't u need a tach adaptor for the MSD? And remove what screw and y? I was planning to installed a MSD but i was told and read on this forums, it only effective for car that runs under boost.
da_linkwent is offline   Reply With Quote
Old 04-21-2005, 04:11 PM   #5 (permalink)
no you dont need a tach adapter.
Old 11-30-2005, 12:55 AM   #6 (permalink)
Always Learning !!
On an NA 92 Nissan NX2000 with MSD6AL
I'm curious if installing a MSD 6AL on a N.A. NX2000 will help it or hurt it as it is driven daily and what do I have to do different than stock??? skeemr
skeemr is offline   Reply With Quote
Old 02-17-2006, 03:26 PM   #7 (permalink)
GRAYEYES
Feedback Score: -1 reviews
HOW DO YOU INSTALL A MSD 7AL. I HAVE THAT ONE BUT IM HAVING PROBLEMS HOOKING IT UP TO MY 96200SX
GreenJDMSR20 is offline   Reply With Quote
Old 02-26-2006, 03:56 PM   #8 (permalink)
Feedback Score: 15 reviews
Is the Msd Digital 6 the same way as the msd 6a??
FoolishWayz33 is offline   Reply With Quote
Old 02-26-2006, 05:23 PM   #9 (permalink)
Is an SE-R/VE a VE-R?
There are several msd ignitions. 6a is w/o rev limiter, 6al has a limiter (the "L"). The digital 6+ also has a limiter, and doesn't require pills as does the 6al. No, they're not going to hurt the car.
'93 B13, etc.
do it over and over again?
Old 04-07-2006, 04:51 PM   #10 (permalink)
The DET is in!
Feedback Score: 17 reviews
What are the advantages of using this on a stock setup? I plan on boosting later on down the road....
Also does the rev limiter not matter if your ecu is programmed to limit the revs?
W11 Avenir
GTi-R T28 Setup
Greddy Type S BOV
FMIC
Calum Realtime
Z32 MAF
Subaru 520cc Injectors
O2 Induction Style Manifold
Autometer: Water, Oil, Boost
3.5" Front Bumper Side Exit Exhaust
Progress Coilovers
Walbro 255lph
Nismo AFPR
ACT Xtreme Clutch
Prothane Motor Mount Inserts
RedDragun is offline   Reply With Quote
Old 04-25-2006, 07:36 PM   #11 (permalink)
JAMAICAN DON
have any pics
Detboy is offline   Reply With Quote
Old 06-29-2006, 10:19 AM   #12 (permalink)
SE-ROLGIST
Feedback Score: 14 reviews
The b14 has different wire colors anyone knows the color combination for the b14?
topdog781 is offline   Reply With Quote
Old 07-04-2006, 12:32 PM   #13 (permalink)
AWD owns me
Jaketips42's Avatar
Feedback Score: 12 reviews
I have the 6a sitting on my desk colecting dust. Should I use it or sell it? I am built NA. Sorry for the threadjack...
Sporting the GC awaiting EJ20T
____________________________________GC Pilot
Subaru stole me from Nissan
Old 07-23-2006, 12:55 AM   #14 (permalink)
SE-ROLGIST
igition box
I hooked up all the wires according to the diagram yet the box does not function. I heard a rumor about an inline transitor that needs to be removed for the b14 body. Does anyone have any info on this? I will take advice from any 200sx owner.
Old 07-23-2006, 04:17 AM   #15 (permalink)
SE-ROLGIST
Nevermind after 2 hours of searching YAHOO(NO THANKS TO THE MSD SITE!!!) I just found out that THE MSD IGNITION BOX CANNOT BE INSTALLED ON THE B14 SR20de motor BECAUSE IT IS A TRANSITOR TYPE COIL DAMM IT!!!. MSD 6al BOX FOR SALE SOON!!!
Old 07-24-2006, 12:23 PM   #16 (permalink)
Big Bossman
Doug_O's Avatar
Feedback Score: 5 reviews
Have you looked at this?
ADDING MSD IGNITION TO INTERNAL COIL TYPE SR20 OR 240SX
Money Shot
12.5@110
Doug_O is offline   Reply With Quote
Old 09-25-2006, 08:23 PM   #17 (permalink)
I really need help!!!!!
Hi this is Benjamin from Mexico! i have a sentra 94 or better now as b13 and i bought a 6al msd, the thing is i'm not a mechanical guy so i get my car to a mexican "mechanic" and he fu*ked my car now it overheat and consumes a lot more of gas so i was wonderin if you'd help me bringing me info about this msd thing because i can let my car down, so please guys help! if you could send me some photos i will be forever grateful.
See ya best wishes from Mexico!!! ADIOS!!!!
bensmo is offline   Reply With Quote
Old 11-11-2006, 08:35 AM   #18 (permalink)
RevTech
help!!!! where to put the white wire because the yellow/green on my stock BB ecu is the speed sensor. is it correct to put it there?
=NismO= is offline   Reply With Quote
Old 11-11-2006, 06:16 PM   #19 (permalink)
RevTech
bump! com'on guys. pls help me.. by the way, i saw a green/yellow wire under the stock coil of my BB. can i cut and tap it there?
tia
Old 11-14-2006, 07:22 PM   #20 (permalink)
se-rious
Feedback Score: 20 reviews
tia
yeah you can tap into that wire
2003 spec v-14.5@96 2.3 60 foot, under going a full n/a build by travis for the qr
93 se-r-under going body work and bigger turbo
duesmandella is offline   Reply With Quote
HTML code is On
