HOW TO: Trunk key doesn't work? Check inside - SR20 Forum
Old 04-16-2005, 11:25 PM   #1 (permalink)
eric96ser's Avatar
Feedback Score: 29 reviews
I've had my B13 for almost 5 years now, and the trunk key hole has never worked, and I even bought a new key cut from the key number from Nissan. I had an extra trunk lock from a friend's totaled car, and I decided to take it apart and see if I could figure it out. Once you remove the trunk lock, you need to remove the C clip holding the arm that pops the trunk latch.
Next, remove the cap that holds the lock cylinder in the holder. I put it in a bench vise and used a hammer and screw driver. Be careful not to bend this since you will need to put it back on.
Here is the lock cylinder. When you put the key in, the small brass pieces should be flush. The problem with mine, and the extra I had, was that some of the brass pieces were stuck. I sprayed it with WD40, but the middle ones were still stuck. I used a jewelers screw driver to move the sliders back and forth, and that freed them up.
Once the sliders are free and moving, put the cylinder back in and the lock should work. I used some grease for my bicycle suspension to keep everything lubed up. The lock cylinder only goes on 1 way, and the arm goes on 1 way also. I put the lock back in the trunk, and it worked. Hopefully this will help you use the trunk lock key again. It's alway been a pain to unlock the door to pop the trunk.
The community is here.
Old 04-17-2005, 03:42 AM   #2 (permalink)
addicted to speed
the brass pins can changed to fit your key too IMO, if you are on your second lock.
Blk Lbl is offline   Reply With Quote
Old 04-18-2005, 01:15 PM   #3 (permalink)
Yes Dear.
Feedback Score: 6 reviews
(sr20girl) - oh koool, i cant open my trunk with a key as well. hmmm, my bf's driver side door wont open wiht the key either. maybe we can do the same thing? i hate driving his car *** i have to open the passenger side door and either hop over to the driver side or unlock it and come back to hte driver side. kinda embarrassing for me =T
Sr20kidD is offline   Reply With Quote
Old 04-18-2005, 01:26 PM   #4 (permalink)
Feedback Score: 12 reviews
If the lock is just stuck due to rusting then I would try some PB Blaster to loosen it first. Wait a day and see if it works. If it does then spray it with some Tri-Flow (lockshops or Bike Shops should have it). You want to flush out the PB Blaster with Tri-Flow over several days I would think. Worth a shot before takine things apart as PB Blaster really works well on stuck things.
Steve
06 G35 6MT
Old 04-18-2005, 01:47 PM   #5 (permalink)
eric96ser's Avatar
I tried everything, and it wou;dn't work. Maybe mine was more stuck than others, but if the PB Blaster doens't work, my way hopefully will help.
Old 04-18-2005, 03:21 PM   #6 (permalink)
Veritas
SERprise In WV's Avatar
Feedback Score: 17 reviews
Good stuff, Eric. I'm going out to hit mine with PB first. If that doesn't work....your writeup will go into action.
I nominate this for permanency in the Tech File/How-To forum.
Greg Perry
Huntington, WV
-'93 SE-R, 12.80 @ 110mph
The car: '93 SE-R with a VE
Old 04-18-2005, 04:27 PM   #7 (permalink)
eric96ser's Avatar
I bent my key hoping is was just the lock stuck. I am so happy to be able to open the trunk from the outside. It sucked having something heavy to put in the trunk, and have to put it on the ground, open the door, pop the trunk, then put it in the trunk. I find myself using the key, because I can now.
Old 04-19-2005, 08:16 AM   #8 (permalink)
Just goes to show you need to spray your locks yearly with Tri-Flow to avoid this mess in the long run.
Old 05-02-2005, 12:35 AM   #9 (permalink)
Feedback Score: 3 reviews
My trunk lock never worked. We removed that carpeting crap that covers the trunk lock and found out that the metal rods that go into the lock cylinder were out of alighment so I stuck them back into the cylinder correctly and voila! it worked.
05 Legacy GT
93 NX2000 w/VE
(\__/)
(O.o )
Old 05-02-2005, 01:01 PM   #10 (permalink)
Mr. Grumpypants
My problem is that the little sliver that covers the internals of the lock from the outside is stuck in the open position so everything inside is gunked up! The thread has given me the inspiration to do something about it! Who cares that my car has a MIL for the O2 sensor, needs to be inspected, needs the AC fixed, needs the struts fixed to allow for more ride height, and 15 dozen other things... I'm doing this first
Kieran Lavin
Ask me about the 2011 Nissan-Infiniti National Convention
www.nissan-infiniti.us
kieranlavin is offline   Reply With Quote
Old 05-02-2005, 08:24 PM   #11 (permalink)
...im learning
i tried spraying it. It works for a while, but i think in the end, you may have to just open it up. I have a bad trunk and a passenger side door. I never thought the door was ***** be a problem. But now, i realize that i wish it worked. For some reason, i dont picture the door one being all that awesome to get at.
SR-N is offline   Reply With Quote
Old 05-21-2005, 11:27 AM   #12 (permalink)
Well I'm in the choir of trunk lock....not ...just trunk pop....(had to rhyme ) and my driver side door acts funny sometimes...I have to flick the switch fast and hard and sometimes that doesn't even work....I had started hating reaching out and using the key........oh and my passenger side door needs to be adjusted but I can handle that but **** do something bout the trunk and driver door... Can't be hard...I'll just take em a loose and see what's ailing them.
Mrstaff...Bham PTAC Tech.
94 sentra se-r sapphire blue..Jdm swap completed next stop Boost ..
83 chevy caprice classic a 327 with a cam and head work r.i.p.
1992 sentra E 4speed manual 2dr(true beater)
New daily driver beater....94 mazda 626 my import hooptie
1.8L 2000 b15 engine for sale... OBO still have the car it came out of.
mrstaff00 is offline   Reply With Quote
Old 05-21-2005, 04:04 PM   #13 (permalink)
Feedback Score: 7 reviews
I just fixed my driver door. I had to do the same, reach out and unlock it. Turns out the screws that hold the lock in place were loose and one was missing. I tightened them up, and the lock doesnt move now when you use the inside door handle - opens perfectly. Next up - new hinges.
Old 05-22-2005, 05:33 PM   #14 (permalink)
Just so you guys know....Most locksmiths will tell you it is not a good idea to use oils like WD-40 in locks, it will attract dirt and eventually your locks will get all gunked up again. The recommended lubricant for use in locks is powdered graphite. This is usually avalible at any hardware store. hope this helps! Nik~
Originally Posted by hbkorkut
where i come from there ain't no ebay
nik33615 is offline   Reply With Quote
Old 05-27-2005, 10:58 PM   #15 (permalink)
www.FAIRTAX.org
paNX2K&SE-R's Avatar
Feedback Score: 93 reviews
The trunk lock in our G has never worked with the key...........Until today! I just happened to have a can of pb blaster sitting on my shelf and as I walked by it jogged my memory of Steve's tip when I went to grab something from the trunk. A little squirt of that and viola a working lock! I'll lube it up well with powered graphite in a few days.
03.5 G35 Sport 6MT
07 Forester XT Sport 5MT
94 Miata GT28RS powered
93 LS1 240SX Family Project
Old 06-05-2005, 12:59 PM   #16 (permalink)
El Rey de los Chingones
Isfahan's Avatar
Feedback Score: 8 reviews
Great and useful post, thanks eric96ser. To the fellow novices out there, the trunk lock comes out of the trunk from behind the black plastic mask on the outside of the trunk deck. To do this, take out the two 10mm bolts around the lock, the six 8mm nuts that hold the black plastic mask to the metal lid, and the licence plate. For some reason, I still had to wiggle the trunk lock out between the metal lid and the plastic mask because the black plastic was still being held on by some unseen attachment point near the center of the licence plate mount. After following eric96ser's post, today is the first time in 5 years my car's trunk key has actually worked! Now to attack that noisy starter...
Isfahan is offline   Reply With Quote
Old 06-06-2005, 01:15 AM   #17 (permalink)
4th sr20 and counting..
zipstrips's Avatar
Feedback Score: 21 reviews
the same key should do the doors trunk and ingition? out of my 3 all came with one key and i can only do the doors and ign...
SHIFT_multiplication!
01. Audi TT 225
98. the zips machine
95. t28 setup
95. Celica, 3SGTE
90. Miata BP swap
Old 06-06-2005, 01:20 AM   #18 (permalink)
one key should open everything.....unless it's a "valet" key. valet keys don't work on glove boxes or trunks. So maybe thats the problem, although I have no idea if b13s even came with valet keys. I got my nx over 10 years after it was new and I only got the one key with it that worked on all the locks. Just a thought...
Old 07-23-2005, 06:17 PM   #19 (permalink)
SE. Period.
I've tried to get the protective piece of metal onto the pressure spring and into the lock cylinder for the past hour because they fell out, and I can't get it!!! Any tips?
NEVERMIND. I got it all done, and now my lock is sweet! It works! Here's a picture of why it doesnt work.
here's why it wasn't working though.
iMagnusX is offline   Reply With Quote
Old 04-10-2007, 09:17 AM   #20 (permalink)
It pulled a premium :)
Feedback Score: 14 reviews
(Back from the dead)
HA I've been looking for this, saw it a while ago...
Well I've got a 98 with the security system in it... and my trunk and drivers side door tumblers are completely useless... gotta get in with passenger side door ( no key fob either )
I wonder if I'll be able to do this with the tumblers seeing as they have electrical connectors on them. I will let you all know when I get to it...
I did go to Nissan today and found out that a new drivers side tumber is $77.00!!!!
~KEVIN
New whip...
2000 BMW 540i Sport 6 Speed
Black on Tan
1993 MX-5 Autox whore
camarok is offline   Reply With Quote
HTML code is On
