How To: Replace your Alternator... - Page 2 - SR20 Forum
Old 03-11-2007, 08:40 PM   #21 (permalink)
Originally Posted by Cjburn View Post
The upper radiator hose and housing (on the head) had to come off in order to get the alternator out of there. After core charge I got a reman'd alternator from Advance Auto parts with lifetime warranty for 75 bucks or so.
The price has about doubled in the past two years.. Mine just went out and they quoted me about 132 with core.
Freakin stupid nissan design. I think mine went out because the fill neck on the radiator is directly above the alternator. I removed the rad. to replace my condenser today and when refilling and letting the car run, it gurgled one good time and soaked the alt. in coolant. Drove it, and about 4-5 miles later the battery and brake light pop on. brilliant.
- 1995 200SX SE-R - Stock so far, working the bugs out first.
- 1984 Olds Cutlass - Olds 455/th700r4 in the works.
- 1988 Civic Dx Sedan - fighting Nissan for daily driver rights.
chimaira989 is offline   Reply With Quote
Old 03-11-2007, 08:49 PM   #22 (permalink)
Speaking of the price, who have you found to have the most inexpensive one? I can't find another for less than about 130? Can't even find any rebuild parts.
Old 10-08-2007, 03:06 PM   #23 (permalink)
I've updated the FAQ with pictures and a few new comments spread throughout.
- Yosho
'96 Nissan 200SX SE-R
'04 Mazdaspeed Miata
'04 Volkswagen R32
Yosho is offline   Reply With Quote
Old 10-09-2007, 04:58 PM   #24 (permalink)
It pulled a premium :)
Feedback Score: 14 reviews
wow, let me tell ya, WITH A/C ... not too fun, infact, I don't really want to do this again. I tried for about a good 30 min before I gave up and just took the upper hose and neck off for the radiator fluid.... EVEN THEN it didn't want to come out right away...
SO my little metal chrager is at a rebuild shop till tomorrow, for a cold cool $100.00... then we put it back all together tomorrow
~KEVIN
New whip...
2000 BMW 540i Sport 6 Speed
Black on Tan
1993 MX-5 Autox whore
camarok is offline   Reply With Quote
Old 10-09-2007, 05:34 PM   #25 (permalink)
Yep, a repair like this is seemingly so simple but it can be a real PITA.
Did the FAQ help at all? I posted the pics to help show it is possible and give a reference as to the orientation of the alternator that I've found works best.
I know after I did this a few times I became much more confident with the proceedure. Just knowing I've done it in the past allows me to keep trying when it doesn't look like it's going to work. Knowing which way I should rotate the alternator also helps...
Old 11-28-2007, 09:38 PM   #26 (permalink)
I just replaced my alternator with a 100 amp from a 2001 sentra and it took under an hour to remoe and replace. This is without jacking up the car or removing the coolant hose. I got mine from Advanced for $163 with core, Checkers wanted $221 and they both use the same parts supplier Parts America who incidentally wanted $199.
INCON3037r is offline   Reply With Quote
Old 11-29-2007, 03:12 AM   #27 (permalink)
Advance FTW.... for customer service and parts quality... at least around here
Old 11-29-2007, 04:51 AM   #28 (permalink)
Feedback Score: 6 reviews
thanks for the write up. I have a feeling I will be changing mine soon. I have a bad belt squeal so I will try to adjust the belt as you mentioned.
fullahwickednez is offline   Reply With Quote
Old 03-22-2008, 05:43 PM   #29 (permalink)
Original Owner
aztecred92's Avatar
Feedback Score: 9 reviews
Originally Posted by martin_g34 View Post
A better way is to raise the motor a little so you don't have to disconnect the hose and make a mess. I just put a long 2x4 under the oil pan and use a jack to support the engine while I remove the passenger side motot-mount bolt. Then just keep raising the motor until you have enough room to remove the alternator.
I found that it also helps to remove the bracket that holds the radiator reservoir, it's just one 10mm bolt.
Out of all the alternators I've changed out (4), I have never been able to take it our without removing something or raising the motor.
Worked form me.
I couldn't remove my alternator until I followed martin_g34's advice.
aztecred92
L I V E S T R O N G
'92 SE-R
'85 MR2
'02 Silverado 2500HD
"The most difficult subjects can be explained to the most slow-witted man if he has not formed any idea of them already; but the simplest thing cannot be made clear to the most intelligent man if he is firmly persuaded that he knows already, without a shadow of doubt, what is laid before him." — Leo Tolstoy
aztecred92 is offline   Reply With Quote
Old 03-27-2008, 04:12 AM   #30 (permalink)
My brake light came on 3 weeks ago. When I press down hard on the E-Brake handle, the light goes off until I remove the pressure, then back on.
My battery light never came on, but I am thinking it may be busted, after I read some of the above comments.
I have had a nightmare the last week. Started with a nasty smell in the car, which turned out to be leaking battery acid. Changed the battery, but the guys at the store tested my old battery and said it was putting out the electricity it should be.
Next my strereo/mp3 player's power cuts in and out. Now it rarely comes on at all.
Next my high beams burnt out, so I changed my lamps. Burnt out again, so I changed them being ever so carefull not to touch them. Burnt out again, including the regular lights.
I think on the weekend I'm going to change out the alternator, but would apreciate any advice you guys have to give on my problems. I don't know if it is possible, but could the alternator being over charging the battery, thus boiling the acid? Oh and the new battery is leaking acid now too.
Canadian huh? Where's your pet beaver?
www.northwestnissans.com
wilde cherry is offline   Reply With Quote
Old 03-27-2008, 07:12 AM   #31 (permalink)
newbie
Pretty White's Avatar
Feedback Score: 4 reviews
Wilde Cherry, sounds as if you have a coin or something stuck under the e brake handle.
Originally Posted by sonny
Old 03-28-2008, 11:36 AM   #32 (permalink)
For future people that have the same problems as me.
The E-brake light seemed to be some random crap stuck under the handle which i cleaned out. Now it turns off when I release the E-brake.
Changed the alternator on my nx2000. The guy at the auto electric repair place that I bought it off of said from my symptoms that it was most likely a regulator that is part of the alternator that had stopped functioning.
He said that the stereo would have a safety feature that would cut the power from the unit if it was too strong.
The replacement was pretty easy for me. I'm a handy guy but not an auto mechanic by any means. One thing that I would comment about the change is, when someone mentioned moving the rad overflow thing, it is not necessary to unhook the hose at all. Just gently pull the reservoir straight up and rest it aside (I put mine between / ontop of the rad and the front body piece). Be aware of where the overflow tap is as you move it, make sure you keep the fluid tipped away from that spot or it will spill.
Once complete, my stereo came on right away, and after I put in new headlight bulbs (yet again), they worked and didn't burn out like before.
Old 10-12-2009, 02:45 PM   #33 (permalink)
GearJammer
Im on alternator number 2 in the last month. The first "reman" went bad after a few weeks, if that. $130 + $70 core charge! WTF
Lets hope for the best with this one...
200SX_SER is offline   Reply With Quote
Old 07-22-2010, 09:02 PM   #34 (permalink)
NX2000 Racer
Greg Amy's Avatar
Info update: can be done on an NX by removing right side motor mount bolt and jacking up the engine...
Thanks for the tips, guys.
Kakashi Racing
2006 ARRC/NARRC/NERCC, 2008 NARRC/NERCC ITA Champions!
1993 VE-Powered Electric Blue NX2000 (street rod)
Greg Amy is offline   Reply With Quote
Old 07-22-2010, 09:13 PM   #35 (permalink)
I got an email saying that this thread was bumped. Holy sh*t, I miss my NX, the ugly little car with T-Tops. I would've kicked my ass if I knew now I was driving a SRA Mustang GT, but well, FWD sucks....
Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.
--Winston Churchill
Cjburn is offline   Reply With Quote
Old 08-02-2010, 10:12 AM   #36 (permalink)
newbie
keywords: Dash warning lights, Brake light, and Battery Light
(Reprinted from a previous post of mine a few years ago before we had the how to faq library.)
Last night when I went out to start up my '96 SE-R, my Battery Light and Brake Light on my dash stayed on. Many of you already know what this means, but in case you don't... I created a write-up for you.
My SE-R started up fine, which was good... but the 2 lights on the dash meant that I had a problem that I needed to get fixed ASAP unless I wanted to be left stranded. The alternator was most likely no longer putting out enough power to charge the battery. I got the car home, broke out my multimeter and found that... sure enough... with the car running and all the accessories off, I was only getting around 12.3 volts. It should have been in the 13-15 volts range (I usually get around 14.3). That meant that the battery was not getting enough of a charge from the alternator. So I checked all the wires from the alternator just to make sure that they were in good repair and connected properly and then I called it a night.
As you know, a car needs electricity to run. Since the alternator was dead, my SE-R was using the electricity stored in the battery as its power supply. If I had continued to drive further, my battery would have eventually had its power drained and my SE-R would of shut down and left me stranded (probably while I was driving it ). So you don't want to ignore these two important dash-warning lights.
The alternator on our cars is kind of hard to get to... but it really looks worse than it is. With only some basic hand tools, anyone can change out the alternator. Here's what you'll need:
- 17mm Wrench (the longer the better).
- 8mm socket.
- 10mm socket.
- 12mm socket.
- A 12in socket extension.
- A suitable Ratchet for your sockets (3/8th is probably best).
- Something to pry with (a Pry bar if you have one).
- A good Hammer (dead blow hammer or a rubber mallet is nice).
Optional: Not absolutely needed, but raising the car does make the job easier.
- Floor Jack and 2 jack stands to support the car. You can substitute Ramps if you don't have the jack/jack stands. As always, level ground and safety is the key. Use blocks behind the rear wheels if you want added safety. ***Never get underneath a car that's only supported with a floor jack.*** Jack stands are a must. People have died making this mistake.
1) The first step is to remove the battery cables from the battery. You always want to remove the Negative (Black) first and then the positive (Red) last. This is so that if there is a short (spark), it travels down the negative (ground) cable and not down your positive cable and through your entire electrical system (which can cause damage, especially to onboard computers). The battery cable nuts take a 10mm socket or wrench.
Now that the battery is safely disconnected, it’s a good time to check that your battery is clean and that the battery posts/cables are free of corrosion. If there is any dirt or water on top of the battery, take a paper towel and wipe it clean. If there is any battery corrosion, clean it up with baking soda or battery cleaner. Remember to clean your hands after you touch the battery… you wouldn’t want to have any battery acid on your hands and then say… wipe your eyes.
2) To gain access to the alternator from above, remove the coolant overflow tank and place it aside. There’s no need to fully disconnect it, simply lift it out of its holding bracket and place it out of your way. The holding bracket must now be removed. Use a 10mm socket to remove the bolt holding the bracket down. You now *may* want to remove the splash guards on the passenger side of the car so you can access the area from below. It's not absolutly necessary but it helps if you have trouble getting the belt on/off the crank pully. To do this, simply use the same 10mm socket to remove the bolts holding these panels on. You now have enough access from above and below that you can get to the alternator and belt. This is also a good time to remove the headlight bulb or at least remove the plug. It'll buy you a little extra room when you are removing/inserting the new alternator. It'll also protect your bulb from being damaged.
3) With the battery disconnected and the obstructions removed, it is now safe to move on to removing your alternator. The alternator is of course powered by the drivebelt. So we need to remove the belt before we can remove the alternator. To do this you’ll need to adjust the alternator so that the belt becomes slack. The Alternator is really only held in place by 3 key bolts. The bottom bolt will need to be accessed from underneath the car (again, raising the car is helpful). You’ll need a 17mm wrench to remove the pivot bolt nut. Now that the nut is removed, it’s time to slacken the belt by using a 12mm socket. There are 4 12mm sized bolts located on the alternator adjustment bar. 2 of the bolts just hold the adjustment bar to the engine block. The other two bolts allow you to adjust/rotate the alternator. You’ll want to loosen these two up enough that you can rotate the alternator all the way down. As you loosen these up, you’ll notice that the long bolt starts to back out. The alternator isn’t going to rotate on it’s own so this is where the hammer and pry bar are useful. With everything loose… use the hammer and pry bar to tap the alternator down. Repeat until the alternator is down far enough that you can slide the belt off.
(Remove the belt and inspect it. Is it cracked or frayed? If so, replace it with a new belt. There’s little point to replacing the alternator if your belt is going to break and leave you stranded the following week.)
4) With the belt off it’s now time to remove 3 electrical connectors on the alternator itself. The first one is a plug. Simply press the sides of the plug together and pull. The main power wire is held down over a 10mm bolt. Use a 10mm socket and extension to remove the nut. The last connector is located on the side of the alternator and is held down by either a small 8mm or 10mm bolt depending on its manufacturer. Remove the bolt. The Alternator now has all 3 electrical connections removed.
5) If you haven’t already done so, remove the entire alternator adjustment bar by removing the 2 12mm bolts that hold it to the block. These are the 2 bolts referred to in step 3. With the bar removed from the block and disconnected from the alternator. Place it out of the way.
6) Now it’s time to remove the alternator pivot bolt. You’ve already removed the 17mm nut holding the bolt in place (step 3) so you can now push/pull the bolt through. With the bolt removed. The alternator is free to come out. You’ll need to push/pull the alternator up out of its supports and get it free. Gentile use of the pry bar here is very handy. With the alternator released, it can now be removed. You’ll need to pull it up through the space previously occupied by the coolant overflow tank. This is a tight fit, so you’ll need to manipulate and pull the alternator up and out. You shouldn’t have to jack the engine up or remove the upper radiator hose on a B13 or B14. I’ve read reports that the NX does require the hose to be removed, but I have no first hand experience with this. Use your own judgment.
***Oct 08, 2007 - Updating with action photos of process... they say a photo is worth a thousand words, so hopefully these will help. The biggest problem I've run into over the years is trying to get the angle right (and general orentation of the alternator) when sliding it out/in. These pictures were taken earlier in the year when I had to replace my own (again). Note, the car was sitting on level ground on all 4 wheels. There was no need to jack up the engine for additional clearance or remove the radiator hose. I have never found that necessary on any B13/14 I've worked on but your milage may vary. Notice in the pictures that you will probably wind up scraping the paint a little trying to slide the alternator in and out. It's a tight fit and can be a PITA, just be paitient and keep trying until you get it.***
Congratulations. You’ve successfully removed your bad alternator from the car! Now you can just follow these same steps in reverse order to install your replacement alternator. Once the new alternator is installed and everything is hooked up, your warning dash lights should be a thing of the past.
Reinstall Notes:
Adjusting the belt - If this is the first time you’ve replaced a belt it’s a pretty simple process. Once you have the belt back over the reinstalled alternator, you’ll want to adjust the alternator up so that the slack on the belt is removed. This isn’t a hard process, but it isn’t a very exact one either. Just raise the alternator with the adjustment bolt enough so that there isn’t any slack on the belt…but there’s still some deflection (you can still twist the belt a little). When you first start up the car, you may hear the belt squeal/slip. That’s often normal for a new belt. If the belt squeal continues, you have too much slack in the belt and you’ll want to adjust/raise the alternator with the adjustment bolt as needed.
Battery Cables - Remember when reinstalling the battery cables to the battery you want to bolt up the positive (Red) first and the negative/ground (Black) last. Again, you’re doing this so that if there is a spike it flows down the ground wire instead of through your electrical system. This is just the reverse of how you removed them originally.
Old thread from the dead. I just realized why you could move your alternator out from there, it is because your powersteering cooler lines are not there. On the NX there are steering lines that flow to the front of the car. Sucks. I am going to do Martins idea. I am in no mood to bleed out antifreeze.
Old 08-09-2010, 04:41 PM   #37 (permalink)
<<<< New to Forum - but I thought I would mention that I just came back from pick and pull here in Columbus Ohio and I picked up my alternator for $16.99+tax($23.98 w/o core) and it has a 30 day warranty! They had a number of cars for me to pull it from(I found a NX) and it was a pretty easy process.(though the cooling system on that car will likely be worthless now seeing as anything that got in the way got cut)
Imatsu is offline   Reply With Quote
Old 05-30-2011, 02:47 PM   #38 (permalink)
lil josh
i know im a little late to the fan wagon but i felt i had to give a special thanks to the original poster of this. thanks to the detailed pics on how squeeze the alt. out of the tight space a frnd and i got this project done in less than an hour and a half. i had no probelms didnt have to remove any hoses or lift the motor or anything of that nature. i did however lift the pas side of the car and rip the wheel off to make it much easier. the part that took me the longest was gettin the 17mm bolt back through the alt. and bracket ... but thanks alot u made life easy!!
98nismosx is offline   Reply With Quote
HTML code is On
