Old 06-21-2005, 11:47 PM   #1 (permalink)
Yosho
How To: Replace your Alternator...
keywords: Dash warning lights, Brake light, and Battery Light
(Reprinted from a previous post of mine a few years ago before we had the how to faq library.)
Last night when I went out to start up my '96 SE-R, my Battery Light and Brake Light on my dash stayed on. Many of you already know what this means, but in case you don't... I created a write-up for you.
My SE-R started up fine, which was good... but the 2 lights on the dash meant that I had a problem that I needed to get fixed ASAP unless I wanted to be left stranded. The alternator was most likely no longer putting out enough power to charge the battery. I got the car home, broke out my multimeter and found that... sure enough... with the car running and all the accessories off, I was only getting around 12.3 volts. It should have been in the 13-15 volts range (I usually get around 14.3). That meant that the battery was not getting enough of a charge from the alternator. So I checked all the wires from the alternator just to make sure that they were in good repair and connected properly and then I called it a night.
As you know, a car needs electricity to run. Since the alternator was dead, my SE-R was using the electricity stored in the battery as its power supply. If I had continued to drive further, my battery would have eventually had its power drained and my SE-R would of shut down and left me stranded (probably while I was driving it ). So you don't want to ignore these two important dash-warning lights.
The alternator on our cars is kind of hard to get to... but it really looks worse than it is. With only some basic hand tools, anyone can change out the alternator. Here's what you'll need:
- 17mm Wrench (the longer the better).
- 8mm socket.
- 10mm socket.
- 12mm socket.
- A 12in socket extension.
- A suitable Ratchet for your sockets (3/8th is probably best).
- Something to pry with (a Pry bar if you have one).
- A good Hammer (dead blow hammer or a rubber mallet is nice).
Optional: Not absolutely needed, but raising the car does make the job easier.
- Floor Jack and 2 jack stands to support the car. You can substitute Ramps if you don't have the jack/jack stands. As always, level ground and safety is the key. Use blocks behind the rear wheels if you want added safety. ***Never get underneath a car that's only supported with a floor jack.*** Jack stands are a must. People have died making this mistake.
1) The first step is to remove the battery cables from the battery. You always want to remove the Negative (Black) first and then the positive (Red) last. This is so that if there is a short (spark), it travels down the negative (ground) cable and not down your positive cable and through your entire electrical system (which can cause damage, especially to onboard computers). The battery cable nuts take a 10mm socket or wrench.
Now that the battery is safely disconnected, it’s a good time to check that your battery is clean and that the battery posts/cables are free of corrosion. If there is any dirt or water on top of the battery, take a paper towel and wipe it clean. If there is any battery corrosion, clean it up with baking soda or battery cleaner. Remember to clean your hands after you touch the battery… you wouldn’t want to have any battery acid on your hands and then say… wipe your eyes.
2) To gain access to the alternator from above, remove the coolant overflow tank and place it aside. There’s no need to fully disconnect it, simply lift it out of its holding bracket and place it out of your way. The holding bracket must now be removed. Use a 10mm socket to remove the bolt holding the bracket down. You now *may* want to remove the splash guards on the passenger side of the car so you can access the area from below. It's not absolutly necessary but it helps if you have trouble getting the belt on/off the crank pully. To do this, simply use the same 10mm socket to remove the bolts holding these panels on. You now have enough access from above and below that you can get to the alternator and belt. This is also a good time to remove the headlight bulb or at least remove the plug. It'll buy you a little extra room when you are removing/inserting the new alternator. It'll also protect your bulb from being damaged.
3) With the battery disconnected and the obstructions removed, it is now safe to move on to removing your alternator. The alternator is of course powered by the drivebelt. So we need to remove the belt before we can remove the alternator. To do this you’ll need to adjust the alternator so that the belt becomes slack. The Alternator is really only held in place by 3 key bolts. The bottom bolt will need to be accessed from underneath the car (again, raising the car is helpful). You’ll need a 17mm wrench to remove the pivot bolt nut. Now that the nut is removed, it’s time to slacken the belt by using a 12mm socket. There are 4 12mm sized bolts located on the alternator adjustment bar. 2 of the bolts just hold the adjustment bar to the engine block. The other two bolts allow you to adjust/rotate the alternator. You’ll want to loosen these two up enough that you can rotate the alternator all the way down. As you loosen these up, you’ll notice that the long bolt starts to back out. The alternator isn’t going to rotate on it’s own so this is where the hammer and pry bar are useful. With everything loose… use the hammer and pry bar to tap the alternator down. Repeat until the alternator is down far enough that you can slide the belt off.
(Remove the belt and inspect it. Is it cracked or frayed? If so, replace it with a new belt. There’s little point to replacing the alternator if your belt is going to break and leave you stranded the following week.)
4) With the belt off it’s now time to remove 3 electrical connectors on the alternator itself. The first one is a plug. Simply press the sides of the plug together and pull. The main power wire is held down over a 10mm bolt. Use a 10mm socket and extension to remove the nut. The last connector is located on the side of the alternator and is held down by either a small 8mm or 10mm bolt depending on its manufacturer. Remove the bolt. The Alternator now has all 3 electrical connections removed.
5) If you haven’t already done so, remove the entire alternator adjustment bar by removing the 2 12mm bolts that hold it to the block. These are the 2 bolts referred to in step 3. With the bar removed from the block and disconnected from the alternator. Place it out of the way.
6) Now it’s time to remove the alternator pivot bolt. You’ve already removed the 17mm nut holding the bolt in place (step 3) so you can now push/pull the bolt through. With the bolt removed. The alternator is free to come out. You’ll need to push/pull the alternator up out of its supports and get it free. Gentile use of the pry bar here is very handy. With the alternator released, it can now be removed. You’ll need to pull it up through the space previously occupied by the coolant overflow tank. This is a tight fit, so you’ll need to manipulate and pull the alternator up and out. You shouldn’t have to jack the engine up or remove the upper radiator hose on a B13 or B14. I’ve read reports that the NX does require the hose to be removed, but I have no first hand experience with this. Use your own judgment.
***Oct 08, 2007 - Updating with action photos of process... they say a photo is worth a thousand words, so hopefully these will help. The biggest problem I've run into over the years is trying to get the angle right (and general orentation of the alternator) when sliding it out/in. These pictures were taken earlier in the year when I had to replace my own (again). Note, the car was sitting on level ground on all 4 wheels. There was no need to jack up the engine for additional clearance or remove the radiator hose. I have never found that necessary on any B13/14 I've worked on but your milage may vary. Notice in the pictures that you will probably wind up scraping the paint a little trying to slide the alternator in and out. It's a tight fit and can be a PITA, just be paitient and keep trying until you get it.***
Congratulations. You’ve successfully removed your bad alternator from the car! Now you can just follow these same steps in reverse order to install your replacement alternator. Once the new alternator is installed and everything is hooked up, your warning dash lights should be a thing of the past.
Reinstall Notes:
Adjusting the belt - If this is the first time you’ve replaced a belt it’s a pretty simple process. Once you have the belt back over the reinstalled alternator, you’ll want to adjust the alternator up so that the slack on the belt is removed. This isn’t a hard process, but it isn’t a very exact one either. Just raise the alternator with the adjustment bolt enough so that there isn’t any slack on the belt…but there’s still some deflection (you can still twist the belt a little). When you first start up the car, you may hear the belt squeal/slip. That’s often normal for a new belt. If the belt squeal continues, you have too much slack in the belt and you’ll want to adjust/raise the alternator with the adjustment bolt as needed.
Battery Cables - Remember when reinstalling the battery cables to the battery you want to bolt up the positive (Red) first and the negative/ground (Black) last. Again, you’re doing this so that if there is a spike it flows down the ground wire instead of through your electrical system. This is just the reverse of how you removed them originally.
- Yosho
'96 Nissan 200SX SE-R
'04 Mazdaspeed Miata
'04 Volkswagen R32
Last edited by Yosho : 10-08-2007 at 03:03 PM. Reason: Updated with Action photos! ;)
Yosho is offline   Reply With Quote
Old 07-21-2005, 01:33 AM   #2 (permalink)
MaxPwr
A small note: before adjusting the belt, loosen the pivot bolt on the bottom of the alternator. This will allow the alternator to pivot freely. If the bolt is not loosened, the bracket with the adjustment bolts might snap.. Be sure to tighten the pivot bolt after adjusting the alternator.
'92 Nissan Sentra SE-R
Stillen front strut brace
K&N air filter
Borla axle-back exhaust
MONRO SHOCKS
MaxPwr is offline   Reply With Quote
Old 07-24-2005, 09:00 PM   #3 (permalink)
GSRMx
VIVA MEXICO CABRONES!
Trader Rating: 19 (100%)
Beware that if the internal voltage regulator in the alternator goes bad, you won't get the warning lights. It happened to me just a month ago, no battery or brake lights came on and I was strandled in middle of nowhere in a mountain road between Mexico City and Tampico.
Sato
1 bar loop mod.. 15PSI power!
WE ARE A COMMUNITY!!!
SOMOS UNA GRAN COMUNIDAD!!!
GSRMx is offline   Reply With Quote
Old 07-29-2005, 08:50 PM   #4 (permalink)
Cjburn
The upper radiator hose and housing (on the head) had to come off in order to get the alternator out of there. After core charge I got a reman'd alternator from Advance Auto parts with lifetime warranty for 75 bucks or so.
Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.
--Winston Churchill
Cjburn is offline   Reply With Quote
Old 09-24-2005, 01:37 PM   #5 (permalink)
martin_g34
70/30 Racing
martin_g34's Avatar
A better way is to raise the motor a little so you don't have to disconnect the hose and make a mess. I just put a long 2x4 under the oil pan and use a jack to support the engine while I remove the passenger side motot-mount bolt. Then just keep raising the motor until you have enough room to remove the alternator.
I found that it also helps to remove the bracket that holds the radiator reservoir, it's just one 10mm bolt.
Out of all the alternators I've changed out (4), I have never been able to take it our without removing something or raising the motor.
martin_g34 is offline   Reply With Quote
Old 09-25-2005, 02:26 PM   #6 (permalink)
Yosho
Thank you all for your comments.
Alternator replacement is one of those seemingly simply jobs that can be a real PITA. I've done this now many times on B13's and B14's. There's no need to remove any hose or raise the motor. Having said that though, the more space you can create around the alternator the easier the job will be. It may well be worth it to you to follow the advice above, in order make the replacement a little easier, if you don't mind the extra steps involved.
Old 10-28-2005, 11:00 AM   #7 (permalink)
Pfsantos
...driv'n like I stole it
I'm curious to know why the brake light comes on when the charging system is faulty.
Best regards,
Paulo
95 200SX SE-R
Pfsantos is offline   Reply With Quote
Old 11-01-2005, 09:39 AM   #8 (permalink)
Pfsantos
Well, I went looking at the wiring diagrams, and noticed the brake light is connected to the charge light ground path via a diode. Don't know why the electrical engineer(s) decided to turn on the brake light any time the charge light is on. The diode prevents the alt light coming on because of the brake light (i.e. when you have low brake fluid or the parking brake on).
Old 11-08-2005, 02:40 PM   #9 (permalink)
rastamaster
SE-Rollin
Best regards,
Paulo
95 200SX SE-R
Really? I never knew that and it was driving me crazy because here is my sequence of events: I swapped my sr20 for a new one (DE), got the car back and it ran fine, battery light came on and two days later the brake light came on, and then 2 more days, my car dies because of belt or alt or battery issues. Im just glad it isnt an issue with my e brake.
rastamaster is offline   Reply With Quote
Old 12-12-2005, 05:42 AM   #10 (permalink)
Pretty White
newbie
Pretty White's Avatar
Obviously you have not swapped out a NX alternator. Upper radiator hose and bracket must me taken out, leading to rebleeding the cooling system of air, really sucks...
TEAMSERIOUS 2008!
Old 12-12-2005, 06:19 AM   #11 (permalink)
Yosho
Yep, as I stated in my original post...
"You shouldn’t have to jack the engine up or remove the upper radiator hose on a B13 or B14. I’ve read reports that the NX does require the hose to be removed, but I have no first hand experience with this. Use your own judgment"
I have no first hand knowledge of this on an NX. I do know that I've heard many people insist that you need to remove the hose on the B14/13's as well... in which they are mistaken. The removal is a tight fit though on both the 14/13's so I can see how even a small change in the shape and size of the NX engine bay could require hose removal first. Again, use your own judgement.
Old 12-22-2005, 11:36 PM   #12 (permalink)
Icitte
damn....i just came to change mine...F*CK!! What a pain in the ass!!
i have a 200SX Se-R 95....with A/C!
don't know if your have an A/C systeme but damn....it didn't help me!
when y tried to push down my Alternator it was stuck on a hose for the A/C....when i tried to get it out where the prestone reservoir was....i can't....i needed to remove the prestone hose!!
i don't know if i bougth the good alternator but i had bad time to put the adjustement braket on! damn
i would like to explain you more but my english is to bad....
sorry....
Icitte is offline   Reply With Quote
Old 12-22-2005, 11:46 PM   #13 (permalink)
sonny
SR20DEtroit
sorry....
The adjustment bracket is a pain; hope it worked out for you. Btw, nice writeup; I have to do this on my cousin's b13 tomorrow.
sonny is offline   Reply With Quote
Old 12-26-2005, 07:30 AM   #14 (permalink)
Pretty White
newbie
See, and thats what I do not understand. The NX and the SE-R share the same chassis, only that the NX has it's radiator behind the support instead of under it. Even with the radiator shifted to the left, it still bangs the upper radiator jacket. Wierd!
Old 01-02-2006, 03:02 PM   #15 (permalink)
millertime1.6
I've done this twice in the last two weeks. I have a b13 de-t with a/c. I noticed that it was easier to remove the electrical connections last-once the alternator was fully unbolted, with the belt off.
millertime1.6 is offline   Reply With Quote
Old 01-10-2007, 06:04 PM   #16 (permalink)
voiddweller
I just replaced the alternator on my B14. This was the original part with 135k miles that I took off the OEM low port when I did the swap. Yosho, thank you for the great tips! Dave, thanks for your help and the garage!
I did the following steps. The use of a stubby wrench will help a lot with the ground (negative cable) on the Alt.
- Front splash guard (under front bumper) removed
- Relocated coolant resvoir
- Removed coolant bracket
- Removed negative battery cable
- Removed Adjuster bracket
- Loosened Alt Pivot Bolt
- Removed Belt
- Disconnected positive and negative wires on Alt
- Disconnected AC cable in same bundle
- Removed passenger side light bulb
- Removed all remaining Alt bolts
- Removed Alt up out out of engine bay with pully facing slightly up and toward passenger side. Positive screw on side near passenger light.
- Required a decent amount of force against frame and radiator hose, but did not damage with the exception of a few scrapes.
- Threw old Alt in front yard with great force
- Repeated all but last step in reverse for reinstall
I used a Nissan remanufactured Alternator from the local dealer. Price was a steep $160+tax.
The sticker states it was rebuilt by Hitachi, so at least I know it's OEM quality. I don't want to do this job again, so I bent over and did it. Replacing this 4 or more times (with the crap you might get from Pep Boys or similar parts stores with extended or lifetime warranties) is of no interest to me.
In keeping with this spirit of this thread, I will not post pics
_______
97 200SX SE-R (Email for lowport parts)
96 240SX (Email for parts)
92 240SX (Email for KA parts)
Low Port to High Port Swap
Garage Epoxy Project
Speak Correct Engrish
voiddweller is offline   Reply With Quote
Old 02-12-2007, 02:59 PM   #17 (permalink)
NX 2.0
SR20 Racer/Tuner,Gamer
Ok i had to put a 1.6l alternator because the 2.0 one wouldnt fit
so i took a 1.6 alternator and just change the pulley to a 2.0 one its the same connection and its working fine now
look at the picture its a 1.6 ga16de alter
the 2.0 l in Canada at parts store was like this and wouldnt fit without re-making the alternator braket
This one was not fitting because the front bolt must be parallel with the 2 rear bolt on my 2 nx2000
