HOW TO: B13 cable/electronic cluster swaps - SR20 Forum
Old 06-30-2005, 08:42 PM   #1 (permalink)
Master Cunnilingust
Feedback Score: 37 reviews
How to remove wire terminals from the harnesses
Thankfully, Nissan has made it very easy for us to modify wiring harnesses throughout the car. The cluster harnesses you'll be rearranging the wires in, have an intricate plastic part that keeps the terminals from coming out of the harness. You'll need a small jeweler's screwdriver, an awl or some small picks. They work well for lots of things, especially in this application.
The first drawing shows one of the long sides of a cluster harness. You can see the tab that you depressed to release this side of the harness from the cluster, as well as the open areas where the metal terminals that the wires are connected to. Using a jewelers screwdriver or an awl with a dulled end, press into both areas marked as indentations on the drawing. The plastic should shift to the left, towards the terminals. If you pull up on the plastic just behind the release tab, you can pull this plastic up and out from behind the terminals. See the third picture, a side view of a harness with before and after renditions of this. Once you understand how this clip is released, it should make sense how to do so on the other side of the harness, as well as other harnesses for the cluster.
Now you don't have to worry about the wires falling out, they are still held in by individual plastic tabs inside the harness. To fully remove a wire from the harness, again, using a small jewelers screwdriver or an awl, depress the plastic tab while gently pulling on the wire from the opposite side of the harness. See the second picture. The tab is kind of far back in the hole, you kind of have to wedge between it and the terminal. Once you understand how this works for one wire it should make sense how to remove the rest of the wires.
I don't have harness numbers or terminal numbers for the '91-'92 cluster, so I've done my best to describe each harness. The letter/number after each wire description tells you what harness in the '93-'94 cluster you need to swap the wire to (M30, M32, M33, M102) and the number after the hyphen is the terminal number within that harness. See the harness and terminal diagram below. If your car is an automatic, has cruise, has an airbar or is Canadian Domestic Marketed, you may or may not have or need a spare indicator light location to install the airbag indicator light. The Odometer off indicator would be the best location to install an airbag indicator light if possible. The information is written to show how you'd swap a '91-'92 cluster into a '93-'94, although you should be able to work it backward just as easily to install a '93-'94 cluster into a '91-'92. Swapping of speedo sensors in the transmission will be required, drilling a hole in the firewall for a cable driven speedo, or running a pair of wires from the electronic sensor in the tranny to the cluster, will be required, all depending on which cluster you're swapping into which car. From what I can tell, M30, M32 and M33 harnesses in the ’93-’94 are the same three harnesses used in the ’91-’92. So in order to swap a ’93-’94 cluster into a ’91-’92, you’d need to get ahold of the M102 harness since your car won’t have it. In the opposite case, you’ll end up swapping all of M102’s wires into the other harnesses and end up not using M102 at all.
Why would a person go to all this trouble to install the incorrect cluster in their car? Your guess is as good as mine. Probably the same reason a person would drill a hole in the firewall, and hack into their coil wiring to install an aftermarket tach, when ALL B13's have a tach wire at the ECU located right inside the car. So, this information is here so that it's available should someone decide to do things the hard way, which they often do. And I had a '91-'92 cluster with harnesses I got for free to play around with, so I thought I'd indulge my electrical fetish some more since I'd already written the previous cluster swap article.
’91-’92 cluster wiring
Right side 12 slot symmetrical plug black
Orange/black – CEL M30-35
Green – fuel M102-1
Red/white – door open M102-2
Blue/white – washer (canada) M32-10
Red/black – low fuel M102-5
Yellow – power for fuel gauge, ABS light, seatbelt, brake, oil pressure, temp gauge, speedo, battery. M32-15
Blue – clock backlight M30-38
Blue/red – ABS ground M102-7
Green/black – left turn signal power M102-8
Black – ground M33-27
Empty slot to the left of Green/black M33-25
Middle 10 slot, offset plug black
Black (top left) – Tach ground (add a ground or use one that’s unused)
Black (bottom left) – Ground for speedo only
Black (bottom right) – Ground for high beam indicator M32-12
Black/red – high beam indicator M32-11
Blue/black – tach signal M30-39
Red/black - clock M30-37
Yellow/green – speedo M102-6
Left 12 slot, symmetrical plug white
Yellow/black left – seatbelt ground M32-14 (4-door) M32-9 (2-door)
Yellow/green left – oil pressure ground M30-33
Purple – bulb check M30-31
Yellow/green right – temp signal M30-41
Yellow/black right – brake M30-32
Black/white- overdrive off ground M33-19
Yellow/red – battery ground M30-36
Green/Yellow – right turn signal power M33-26
Red/blue – illumination M33-21
Red/yellow – illumination M30-40
Black – temp ground M102-3
Two wire buzzer plug
Red/black
Green/white
M32-16 Green from speedo sensor
M32-18 Red from speedo sensor
'93-'94 Electronic speedometer cluster wiring info:
M30 Plugs in horizontally behind the temp gauge on the bottom left hand side of the cluster (when looking at the back)
M32 Plugs in horizontally behind the fuel gauge on the bottom right hand side of the cluster (when looking at the back)
M33 Plugs in horizontally behind the tach
M102 Plugs in vertically above M32
M102 - 7 wires
1 G/L Fuel gauge
2 R/W Door open indicator
3 B Ground for water temp, fuel, tach and speedometer gauges as well as airbag indicator and clock
5 R/B Fuel indicator
6 Y/G Speedometer gauge
7 L/R ABS indicator
8 G/B Left hand turn signal indicator
M32 - 9 wires
9 Y Seatbelt indicator
10 L/W Washer indicator (Canada only)
11 R/B High beam on indicator
12 B Ground for high beam on indicator
13 R/W Airbag indicator
14 Y/G(4door and NX)Y/B(2door) Seatbelt indicator
15 Y Power for Abs, fuel, brake, overdrive off(auto), door, malfunction, washer(Canada), charge, and oil indicator lights, water temp, fuel, tach, and speedo gauges.
16 G Speedometer gauge
18 R Speedometer gauge
M33 - 5 wires
19 B/Y Overdrive off indicator (auto only)
21 R/L Meter illumination
25 G/Y(2door)G/R(4door and NX) Cruise on indicator
26 G/Y Right hand turn signal indicator
27 B Ground for turn signal indicators
M30 - 10 wires
31 PU Brake indicator
32 Y/B Brake indicator
33 Y/G Oil indicator
35 OR/B Malfunction indicator
36 Y/R Charge indicator
37 R/B Clock
38 L Clock illumination
39 L/B Tachometer
40 R/Y Meter illumination
41Y/G Water temp gauge
- Rob
Old 12-27-2007, 05:02 PM   #2 (permalink)
tach not working
Hello, I have a 1994 ser. the tach is not working. where do I start and what do I need to look for in fixing this problem??? thanks for the info.. jj
jimmyjammz is offline   Reply With Quote
Old 12-27-2007, 09:35 PM   #3 (permalink)
SR20 ENTHUSIAST
Feedback Score: 5 reviews
Did you have the gauge cluster out? The tach signal wire may have ripped out on the gauge cluster side, or become cut/snagged over on the ECU side behind the center console.
Chris
B13Sentra2DR is offline   Reply With Quote
Old 03-29-2009, 02:08 PM   #4 (permalink)
i have a 94 sentra E with no tech.
how would i install the 91 ser cluster into the car.
mayko is offline   Reply With Quote
Old 03-29-2009, 02:25 PM   #5 (permalink)
banned
Feedback Score: 3 reviews
guys..plz dont full this thread with junk. all the info is rite in the first post. this is very very usefull info. and makes it easier to find with less junk surrounding it. thanks for this information. lots of ppl will be needing this since alot of 1.6 to 2.0 is goin on.
srpowa is offline   Reply With Quote
Old 05-22-2009, 10:29 PM   #6 (permalink)
#TranceFamily
Feedback Score: 4 reviews
this is the new 1.6 b14 cluster I bought from the junkyard today. I pulled it off from a 95 B14 200sx se.
As you can tell I saved the harness plugged in and with a couple of niches of wiring just in case.
my stock 1.6 tachless cluster goes to 150mph. Ive noticed that majority of the senras at the junkyard go up to 120mph or 130 mph.
It looks way different from you guys.
http://i6.photobucket.com/albums/y20...0/P11SR20B.jpg
99 G20 5-Spd SoCalG20
MODS: Injen CAI, OBX Header, Stillen Sport rotors, Custom FSTB, Octotat RSTB, Tein SS, 02 Sport Headlights, 2.25" Exhaust, Remus Muffler, B&M SS, Carbing Lower Arm Bar, Greddy GR-3, Mautai916 Grounding Kit, Brian Crower Stg. 2 Cams, Greddy Cam Gears, Greddy RAS, and more to come...
818_99G20 is offline   Reply With Quote
Old 08-29-2009, 12:29 AM   #7 (permalink)
will a 96 nissan sentra instrument cluster fit a 94 nissan sentra
lucas75 is offline   Reply With Quote
Old 11-01-2009, 02:47 PM   #8 (permalink)
coach
i have a 92 se-r with a mech. speedo how do i make that work if i wanna put in a nx electrical speedo? am i gonna have to get a tranny that uses a electric speedo plug?
cees is offline   Reply With Quote
HTML code is On
