I think we should also post the part numbers of filters that are longer but have the same thread as ours. I'll work on some searches and post part #s when I get a chance.
__________________ 03.5 G35 Sport 6MT
07 Forester XT Sport 5MT
94 Miata GT28RS powered
93 LS1 240SX Family Project
According to FAST, I don't see any SR's taking 9E000's. QR's do though.
91 NX2k hard top (track whore) Celebrating 14 years of ownership!
93 SE-R (street/track toy) Overkill is just about right
93 SE-R (daily driver) 221k and counting!
Highports dont need the built in check valve, its built into the oil filter spout, at least the ones ive seen. Lowports need the check valve in the filter since its not built in.
Uh... so would it cause oil starvation on startup if a highport filter was used in a lowport motor. I mean, is that why the red oil pressure light comes on for a second or two at startup?
I sure hope I've been using the right filters...
Michael.
No, a highport filter on a lowport gives you 0 pressure after it blows off. The 2 filters are different, and can't be used on both motors. The low port filter is shorter than the high port filter. I would double check the part number before you drive the car again.
Michael.
I've the same startup issue once I changed to a WIX filter. (highport, not to mention)
Err.. I liked WIX filters too!. Maybe I should change back? Any advice? The engine oil light comes off after half a second of startup.
I would also like to point out something that everyone should do after changing oil...
1. Disconnect your coil.
2. Turn the key and let the car crank over and over until you see the oil light turn off.
3. Reconnect coil. Go for a drive knowing you primed your engine and got everything good and oily.
But, now I'll start priming the motor, lol. I change the oil pretty quickly, (maybe 10 minutes max?), so usually its not all 100% drained by then (but good enough for me).
I would also like to point out that after I ASSumed the
'95 G20 lowport used the 'lowport' filter, I found that
it didn't by blowing about 3.5 quarts of Mobil 1 all over
my driveway. It turns out, that it also uses the 53J filter.
Peter
'91 SE-R track slut w/ VE
'02 G20 Sport
'95 Yamaha FZR 600 RIP
'02 CBR600F4i peter.serwe@gmail.com
