Old 08-24-2005, 02:00 PM   #21 (permalink)
Swap Guru
I just want to make a correction about the first post for the RNN14 & B13 ECU Pinout
If you notice the Injector Pin Out it states that
Injector 1 is Pin 101
Injector 2 is Pin 103
Injector 3 is Pin 110
Injector 4 is Pin 112
!!!THIS IS INCORRECT!!
I wired up my Emanage this weekend and this caused me about 20 minutes of Heartache..
After consulting the Alldata, The Japaneese Greddy Emanage Book as well as the FSM i found the correct wires.
Here are the Pics to back up this information.
First is the Original post with the incorrect wires
If you notice in this image that Pin 103 and Pin 110 are highlited with an arrow going between them. These pins discriptions need to be switched around so that..
Injector 2 is Pin 110
Injector 3 is Pin 103
Also here is a Pic of the FSM showing the correct pinout.
The wires going from the Injector to the Ecu are Highlited as well as the Pins on the Ecu.
Hopefully this will help everyone out and save them the heartache that I went through.
Enjoy
Kevin
Red200Se-R is offline   Reply With Quote
Old 11-15-2005, 05:06 PM   #22 (permalink)
TEAM 15 FTMFW!!!!
Few qustions.. whats the AIV controll solenoid and what does pin 115 do?
Raceworx is offline   Reply With Quote
Old 03-21-2006, 12:09 PM   #23 (permalink)
So is the BB DET ecu pinout the same as the b13 SE-R???
Allmotor is offline   Reply With Quote
Old 04-15-2006, 10:23 AM   #24 (permalink)
Travieso Racing
Originally Posted by Nick
i made this up, i got sick of fliping threw PDF files and the FSM tracing stuff out.
Hope people can put this to use besides me
waist? are you gay? if so its ok... but dont put gay analogs into your ecu pinout people are tryin to read this..
Wastegate- GTI-R is only one that uses it
Danny GDM (HKS)
1993 PRiMERA GT
Old 04-15-2006, 01:56 PM   #25 (permalink)
Master Cunnilingust
Trader Rating: 37 (100%)
Dude you're a fu*king dick. So the guy misspelled waste. Someone posts something very usefull and all you can do is come in and bitch about one misspelled word? I think you need to go fu*k yourself so you can feel better about your lame ass.
- Rob
Old 04-15-2006, 02:03 PM   #26 (permalink)
Master Cunnilingust
That's the PAIRC solenoid valve.
Pin 115 isn't used.
Old 05-04-2006, 09:27 AM   #27 (permalink)
Here is a useful ECU pinout guide for several cars I found:
http://www.innovatemotorsports.com/r...ecu_pinout.php
'97 SE-R with BB T25 setup, G20 ECU, E-Manage, Starion FMIC, SPEC 6 puck stage 3 clutch, D2 coilovers, fully shaved doors including side molding, Royal Sapphire Pearl (Toyota Supra) paint, Halo headlights, Aerogear vented hood, 98 Sentra Grille, Vis Extreme front bumper, Andy's Autosport rear bumper, and Kenwood Excellon CD player (Formerly Raser-X's car)
http://www.uwm.edu/~elh3/Pictures/20...rbocharger.jpg
Tomcat5678 is offline   Reply With Quote
Old 09-06-2006, 01:28 PM   #28 (permalink)
Chasing after the vette
Sorry to revive an old thread. But I need some help. I just installed the emangae ultimate to my GTiR sr and when I plug in the ignitions wire to the (what the manual says to put it, PIN 1) it wont start. I moved it over to the #3 pin where this pin out that was provided says it's the ignition signal, it works.
Can someone help me?
Oh and before I forget. Ever since I plugged all of them in. I've been spitting liquid out of the tail pipe. The car has not yet been dyno tuned. I'm afriad to drive it like this.
2001 Nissan Sentra with a GTiR (finally)
Color Radium 18" Konig Trouble's w/ Falkon 451's 215/40/18 tires
ICE: 3 12" JL Audio W3, 2 amps 300 watt mono and 500 watt 4 channel and a Pioneer receiver.
Project: 1995 200sx se. GA to SR
snkyjester1 is offline   Reply With Quote
Old 10-01-2006, 10:21 PM   #29 (permalink)
Sorry for the dumb question...
Is this ECU guide applicable to a '92 PS13 SR20det?
Thanks.
6330 is offline   Reply With Quote
Old 03-13-2007, 02:46 PM   #30 (permalink)
can someone please get me a u13 pin out
NineFiveSx is offline   Reply With Quote
Old 03-30-2007, 09:33 AM   #31 (permalink)
SE-ROLGIST
This would be so much better if it had the color code for each pin out spot
"I am the representative for the people"
topdog781 is offline   Reply With Quote
Old 03-30-2007, 12:59 PM   #32 (permalink)
Sigfod's Avatar
AMEN!
96 SE-R Totaled in '99
2000 Sentra SE w/ GTi-R 2.0T
2006.5 2006.5 GTI DSG 2.0T FOR SALE
2008 BMW 328xi Touring
2008 BMW 328xi Coupe
Sigfod is offline   Reply With Quote
Old 03-30-2007, 05:28 PM   #33 (permalink)
Wiggle wagon driver...
Trader Rating: 26 (100%)
i can post colors for the wires i used...if i get really really bored i might make a color chart. it will not be very helpful though b/c some of the pins have the same color wires.
200sx w/JDM highport swap..turbo build in the works
05 Altima
01 F150
Originally Posted by KdubL View Post
she looks funky...like she just finished eating a doo doo samich
Katana200sx is offline   Reply With Quote
Old 11-01-2007, 02:32 AM   #34 (permalink)
Trader Rating: 15 (94%)
Project Shift_Rebirth
Nyc Sr20PowerD is offline   Reply With Quote
Old 09-12-2008, 02:42 PM   #35 (permalink)
where do i put it?
first post has red x = no picture
92 NX2000DET GT28RS
HTML code is On
