What did you guys do about the speedo? 91-92 have the cable. I wanna know more, cause now I want to do the cluster...again.
Get a electric speed pinion, in place of the mechanical one (it is the thing that your cable connects to) switch them out wire it up and problem solved.
[b]Now metal fabricating, welding and powder coating. PM me with your needs!
Hey Back from the dead, I'm in a 93 NX2000 and I have a 91 NX1600 for parts - anyone ever get around to seeing what the difference was to wire it up to a 93-94?
Get me the location and colors of each wire on the analog cluster from a 93-94 and I can whip you up a new diagram like the one I posted for the 91-92.
Im still trying to figure out the deal with the dimmer switch, what I thought before didnt do the trick and since I did it on my friends car and he has it put away in storage I have yet to sort it out but once I do I will let you all know.
um its all back together now....... coming out of the dash there are 2 yellow and red wires... and 1 blue an red? i know i only used 1 of the yellow and red and i used the blue and red, tok me 10 hours *** i had to figure it all out myself becuase no one did it to a car with out a tach
if anyone else does this make sure u use a speedo sensor from an automatic tranny and u must use a digital cluster from a automatic nx1600, same for manual, today i put in a speedo sensor from a automatic in my automatic because the sensors are different (manual and automatic) and its worked with the manual cluster i put in, but the speedo was double off ( i was doing 30 when it should be 60) got another cluster out of a automatic nx1600 and my speedo i know accurate... so make sure you put both auto or manual together in.. (speedo gear and cluster)
