How To: Z32 MAFS Install SR20DET (Pics) - SR20 Forum
Old 12-24-2005, 03:11 AM   #1 (permalink)
Force Fed
Well here is my next addition. I have a sh*tload of parts I have to install, today I tackled the Z32 MAF. Easy right? In and out? Well not exactly so I made sure to document the Issues I had and the fixes. There are more than one way to install. This is myway and it worked:
Items Needed:
Z32 MAFS
Intake that fits the Z32 MAFS
80MM Grommet
2 80mm Hose Clamps
80MM to 60MM Aluminum Pipe
Wire Harness
Steel bar for support
Electrical Tape
Wire Connectors
Tools
This write up may help. If it does, give me some points please:wavey:
**Disconnect your negative Battery Terminal**
Okay well getting started, I ran into an immediate problem. The Z32 MAFS intake side did no fit the APEXi Intake I had been usuing with my stock MAFS.
Fix was, I bought a new APEXi Intake. I swear by the APEXi, my old one with adapter piping is for sale as well.
Okay to attach the MAFS to the Intake depends on the intake itself..make sure you keep hold of the little rubber gasket ring that goes bewteen the MAFS and the Intake, it sits in a little valley type area on the MAFS. Then use a paper style gasket between the intake and the MAFS and use the 4 screws to secure it nice and tight.
Okay now pull out your old MAFS and Intake and you will see the next problem.
The Stock MAFS has an 60mm exit to the stock compressor pipe...your new Z32 MAFS has an 80mm one. I eventually plan on getting a full aluminum pipe made that will go all the way up from the compressor to the intake, but for now I had to improvise cause I hate to stop in the middle of sh1t unless it is for beer or good head from a hottie...so what I did was headed down to the speed shop and bought an 80mm to 60mm reducing pipe and a gromet...
See you can't just use a reducing grommet, becuase the stock compressor piping is rubber if you used a rubber style gromet it would collapse..you need something strong in there that wont collapse. Use two hose clamps and attach the MAFS with installed intake to the Reducing pipe using the grommet. Once your done it should look like this, mine looks like an F15 motor now:
Then put the pipe in. You can slide it down the stock rubber compressor tube and use the stock hode clamp to secure it on the 60mm end of the reducter. Push it in as far as you can, there isnt much room. It will look like this now, and yes I had just enough room...
it is time to cut the harness you are looking at in the picture above....make sure you cut it about 2 cm's from the tip. This way it can still be used again.
Then get your wire diagram and wire the stuff up:
Here is the breakdown using the Harness I bought for 20 Bucks..
From Right to Left:
White - to White on the stock Harness
Black - to Ground on the car
Black - to the Black on the Stock harness
Red - to the Black and White stripes wire on the Stock Harness
Attach all of the wires from the new Z32 Harness to your stock wire cluster...use the direction above. You can either solder the wires (preffered) or do what I did. I just used wire connectors and crimped them together, then wrapped the harness in black tape. I didnt wanna do it permanantly with solder yet since I am going to have an intake pipe made for me later and may have to reduce the harness length.
Then you will still have the ground wire to deal with...I extended the ground wire and set it right below my profec motor..but there are plenty of places to ground it at..
Okay now here is what the finish product will look Like installed...The only thing left to do is reconnect your battery cable and start up. If you have an SAFC II like me, you will have to make an adjustment in the ETC menu prior to startup. Go into ETC, choose Sensor Type, choose HW and In "2" and Out "6":
Next write up is 550's and AEM UEGO wideband install:mephfawk:
Late
Daryl
1995 Nissan RPS13 180SX Click Here For PICS Of This Beast!!!
Click Here For Action
bjorkluv is offline   Reply With Quote
Old 12-24-2005, 03:26 AM   #2 (permalink)
Feedback Score: 156 reviews
you get brownie points homey! this should be move to technical library but what will it do, unless no one knows how to put a maf sensor on.
1810 is offline   Reply With Quote
Old 12-24-2005, 06:22 AM   #3 (permalink)
Force Fed
Thanks Brother!
Old 12-24-2005, 07:14 AM   #4 (permalink)
Veritas
SERprise In WV's Avatar
Feedback Score: 17 reviews
Very nice write-up, Bjork!
You do know that HKS makes an adapter that allows you to join a Z32 MAF to the stock intake piping, right? IIRC...they're about $40.
Regardless....it looks good.
Greg Perry
Huntington, WV
-'93 SE-R, 12.80 @ 110mph
The car: '93 SE-R with a VE
Old 12-24-2005, 07:58 AM   #5 (permalink)
Force Fed
Nah I didnt know that..thanks for the info..but I am gonna get rid of that rubber crap sooner or later anyway..
Old 12-24-2005, 11:25 AM   #6 (permalink)
You're Ugly!
Feedback Score: 18 reviews
damn, that apexi power filter looks sexy . nice write up!
SR20DEEP CA
shingouki1 is offline   Reply With Quote
Old 12-24-2005, 11:56 AM   #7 (permalink)
the proof wizard
Feedback Score: 26 reviews
is the adapter for fwd? and where can it be found? thanx
Old 12-24-2005, 02:40 PM   #8 (permalink)
Honda Employee...
Feedback Score: 5 reviews
had to get the "shocker" in your write up, didn't you??
-Zack
-'91 SE-R, Aztec Red: JWT Pop-Charger, Fidanza Flywheel, JWT PP w/01 SE disc. AGXs w/GC coilovers (300/279) & C/C plates. NX2K Brakes w/Carbotech pads & Crown SS lines. Progress rear sway bar. Active Tuning RSTB, ES Bushings & motor mounts.
gottabfast is offline   Reply With Quote
Old 12-24-2005, 04:17 PM   #9 (permalink)
Keeping It Real
Nice man! Great pics!
Marvin
B15 SE TURBOCHARGED
Mr Sentra is offline   Reply With Quote
Old 12-24-2005, 05:12 PM   #10 (permalink)
banned
Feedback Score: 44 reviews
props, but he has a rwd , are the wire colors going to be the same for us most but not all fwd guys?
B14 Se-Rious is offline   Reply With Quote
Old 12-24-2005, 05:27 PM   #11 (permalink)
Force Fed
Well Yes I have a RWD.. But many people are running JDM SR20DET's in their rides...The MAF in my Car looks very similar to the MAF on a Primera, It doesnt look anything like the MAF on B15 SE w/SR20....it will take a bit of cross reference but shouldnt be hard to figure out...
Mr Sentra - Thanks Marvin!
gottabfast -
coryb13ser - Do you mean the MAF Adapter? sh*t you can make one and run the APEXI Intakes...I can tell you how. I ran one on my B15 SE while I was in the states...just takes a bit of fabbing..then price the filters in the states and maybe I can beat the prices...
shingouki1 - Thanks man
Old 12-24-2005, 11:06 PM   #12 (permalink)
Veritas
Is this an open offer? If so...I'm looking for a Z32 MAF adapter and filter....Apexi is great and so are the HKS mushrooms. Prices in the US are in the $140 range, IIRC.
Old 12-24-2005, 11:12 PM   #13 (permalink)
Veritas
Also...you can find the HKS adapters that let you use a Z32 MAF on the stock RWD DET intake pipe here: http://www.projectnissan.com/shoppin...idproduct=4100
Old 12-24-2005, 11:44 PM   #14 (permalink)
Force Fed
Are you looking for a MAF and Filter? SHoot for an adapter I would get the one in the link you posted....the MAF's vary in price....I can get you an APEXi Intake that will bolt right up to the Z32 MAF like mine for 60 bucks usually...
Old 12-25-2005, 11:52 AM   #15 (permalink)
Veritas
You, sir, have a PM.
Old 12-25-2005, 12:12 PM   #16 (permalink)
Tired!
coach's Avatar
Feedback Score: 43 reviews
I just noticed that, hilarious.
Brent
1999 SE-L -- back to NA form
Old 12-25-2005, 06:20 PM   #17 (permalink)
Force Fed
Ill reply to all the PMs soon..gotta go for a run with the dog..
Old 12-27-2005, 06:54 PM   #18 (permalink)
you got pm my brotha
Old 12-27-2005, 07:19 PM   #19 (permalink)
Feiticeira
Feedback Score: 16 reviews
s anyone agree that this install guide should be a sticky? great job bjorkluv
SR20DEEP CA
OptimumSE-R is offline   Reply With Quote
Old 01-22-2006, 09:41 PM   #20 (permalink)
NISSAN ADDICT
RYAN_S-14's Avatar
Feedback Score: 20 reviews
Moved to: Technical Information Library
RYAN_S-14
http://www.floridasr20s.com/gallery/album21
RYAN_S-14 is offline   Reply With Quote
HTML code is On
