HOW TO: Install a Walbro Fuel Pump in a B14 - SR20 Forum
Old 12-25-2005, 12:41 AM   #1 (permalink)
Grandma's gonna get ya!
coalitionSE-L's Avatar
Feedback Score: 6 reviews
I've seen a lot of discussion of Walbro pump installs on the forum, however, I haven't seen a comprehensive write-up. I just got done installing my pump successfully so I figured I'd go ahead and do a write-up on it to de-mystify it for people.
This write-up covers the installation of a Walbro fuel pump in 95-99 B14's. This install is pretty straightforward, however, there are some opportunities to make big mistakes so be careful and take your time. Please take the proper safety precautions before doing this installation because there will be fuel spillage in your work area. Also, be sure to do this in a well lit and well ventilated area. I would advise against doing this install if you have more than 3/4 of a tank of fuel, somewhere in the range of 1/4 of a tank would be ideal.
What You Will Need:
-Phillips head screwdrivers
-Flat head screwdrivers
-Pliers
-10mm and 8mm sockets w/ 1/4 or 3/8 drive ratchet
-Solvent impermeable gloves (highly recommended)
Before doing anything you will need to relieve the pressure in the fuel system. To do this, access the fuse panel under the dash. Start the car and with it running, pull the fuel pump fuse. When the engine stops, the fuel system is de-pressurized. On 98's and 99's, the fuel pump fuse is the blue, 15 amp fuse located in the second row from the left. It is the fourth fuse from the top. You will want to double check with your fuse diagram though.
It is now safe to proceed with the removal of the stock pump. First and foremost, disconnect the negative terminal on your battery. Next, you will need to remove the back seat to access the pump. This will reveal the sending unit access panel. Remove the three 10mm bolts from the access panel.
What you see is the top of the fuel sending unit. Next you need to remove the electrical connectors and move the grey access panel out of the way. Disconnect the send and return lines, be careful when doing this as residual fuel will probably spill out of them. Next, remove the six 8mm bolts from the sending unit.
Lift the sending unit up slowly, depending on how much fuel you have in your tank, there will be some drainage going on. There will be an electrical connector and two hoses connected to the bottom of it. Take note of the send and return lines and remove these items along with the connector. Carefully pull the sending unit out.
Now you can see the fuel pump which is installed in a plastic housing.
I would strongly advise solvent impermeable gloves at this point because in some cases, you will need to completely submerge your hand in gasoline.
The pump housing slides out of two tracks. To get the housing out, press up on the tab located at the bottom of the housing and slide the housing toward the front of the car. When it is free, slowly and carefully remove it from the car. You will want to let it drain for a while before fully removing it as it will be full of gasoline. When it is out, it will look like this.
The housing consists of two sections, an upper and a lower. There are five tabs that hold these two sections together. They look like this.
Carefully unhook these tabs and seperate the two housings. This reveals the actual pump itself.
Remove the pump from the lower housing and take not of the hose orientation.
At this point, you will want to ensure that you have all of the necessary hardware for the Walbro pump pictured below. Be careful because some of the parts are extremely small.
Follow the instructions provided with your Walbro pump exactly and ensure that you use all the provided hardware when installing the filter, hose, and connector onto the Walbro pump. Luckily, the connector pulls right out of the stock pump and plugs right in to the Walbro. You will discard the stock clamps for the send hose and use the screw-tight kind that Walbro provides. Orient the hose the same way on the Walbro pump as it was on the stock pump.
Set the Walbro pump into the lower pump housing. It fits perfectly on B14's.
Next, snap the upper part of the pump housing back on. You should have no problems doing this. If it does not snap back on with ease, the pump may not be positioned right.
Installation is the reverse of removal. Take care when you are sliding the housing back into its tracks and be sure it is secure. When you are done tightening the top back on the sending unit and the hoses are reconnected(as in picture 2), re-connect the negative terminal on the battery and turn the key on before you bolt the grey access panel back down. This way the pump can prime and pressurize and you can check the send and return lines for leaks before buttoning up.
Finish up and you're done!
1999 SE-L SR20DET-- Sold!
Old 06-26-2008, 02:55 AM   #2 (permalink)
this might sound dumb but im goin to ask it anyway. where is the best place to install an external walbro? right now its installed in my engine bay. im thinking thats a bad spot because of the heat in there.
Jedi_SR20det is offline   Reply With Quote
Old 12-29-2008, 03:00 PM   #3 (permalink)
Crush the Domestic Dino
Feedback Score: 3 reviews
SPAM^^
sjsdperformance is offline   Reply With Quote
Old 12-29-2008, 06:25 PM   #4 (permalink)
1.6 3/25/06 VE 7/11/06
Feedback Score: 25 reviews
excellent write up, and MUST be put into a sticky. Sooner or later i will be doing this install so thanks a lot for this.
bj200sx is offline   Reply With Quote
Old 03-29-2009, 05:02 PM   #5 (permalink)
Originally Posted by sjsdperformance View Post
SPAM^^
spam sounds good right now. do u mind cooking me up some dude? haha!
Old 03-29-2009, 10:15 PM   #6 (permalink)
lol i just wondered why i posted there must have been a spam post that got deleted good writeup btw
Old 06-19-2009, 01:03 AM   #7 (permalink)
Feedback Score: 55 reviews
im missing one of the ring retainers where can i buy one?
93 sentra xe dd (gas saver)
91 sentra se-r project car
97 200sx se-r new baby [/U]
99 sel
93 se -r
99sel-r is offline   Reply With Quote
Old 06-19-2009, 08:08 AM   #8 (permalink)
B14 (VVL) B15 (DD)
excellent wrtie up, i just did my fuel pummp the other day, busted missions trying to get the plastic case out till i saw the tabs on the bottom of the tank, plus the tank rim on the opening was sharpe so u get plenty of cuts...8)
Well i work as a Honda mechanic, but i drive a B14 and a B15, lol you think they hate me...
1...low...b15 is offline   Reply With Quote
Old 06-20-2009, 12:22 AM   #9 (permalink)
Booooooooooost
Feedback Score: 5 reviews
just did this in my b13 and it sucks BALLS! i would advise gloves, also. I swear you'll think your finger is going to fall off if you get gasoline in a cut like I did. and also the tank is super sharp so you need gloves that will protect against that, too. and don't get gas on that little o-ring that seals the gas tank from the car because it will swell up and you'll have fun trying to get everything back together. i'd have to say that if I was gonna do it again i'd drain the tank and that would make it so much easier.
1992 Aztec Red SE-R - Boosted.
Stock Avenir motor on 9 psi, 370s at 4 bar, N60 maf, Calum ecu
1992 White SE-R - The Daily.
JDM DE swapped
SR20? is offline   Reply With Quote
Old 08-12-2009, 03:18 AM   #10 (permalink)
custom sr20ve
hey guys,
I liked to know, the exact model of the Walbro Fuel Pump u guys did succesffully to your B14 replacing the original ones.
Can any give me the product code of the Walbro that plug n play into b14 ?
Thanks a mil
b14bot is offline   Reply With Quote
Old 08-12-2009, 11:39 AM   #11 (permalink)
Well i just bought mine off of ebay heres the listing
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
Pump = GSS-342
Kit = 400-954
Old 09-11-2011, 08:00 PM   #12 (permalink)
El Lobito with many toys
Wolf_SER's Avatar
Feedback Score: 24 reviews
Coming back from the grave.... I just want to tell you guys to BEWARE of most of ebay sellers selling this fuel pumps as most of them are excellent chinese copies of the original except that they do not work as the original.
I bough mine from ebay at 90 dlls and to realize does not gives more that 50 psi at boost levels beyond 3 psi just pissed me off.
China have become expert in selling this GSS342 fuel pump SO BEWARE and do not buy it anymore...
The new Walbro pn is GCA3362HP (without HP if you want stock performance)
Just wanted to give you a heads up.
Luis.
Wolf_SER is offline   Reply With Quote
Old 09-12-2011, 03:25 PM   #13 (permalink)
Corr Performance Tuning
Feedback Score: 7 reviews
that's why folks should purchase from local or USA shops.
EFI-101 7-16
AEM EMS Factory Trained
JWT
Join Us on Facebook
Haltech Factory Trained Dealer
Corr's BLOG
panapower is offline   Reply With Quote
HTML code is On
