HOW TO: Reground MAF sensor <PICS> - SR20 Forum
Old 01-02-2006, 11:51 PM   #1 (permalink)
YOUR F0RUM SUX
Feedback Score: 14 reviews
HOW TO: Reground MAF sensor &lt;PICS&gt;
EDIT... pics are back up... Any question please PM me.. I will be more than happy to help.
******ALSO NOTE: This is done on a 1999 Nissan Sentra SE-L with a stock MAF. 1995-1999 200sx SE-R and Sentra SE and SE-L have the same MAF.*******
Sentrixx is offline   Reply With Quote
Old 01-03-2006, 09:12 AM   #2 (permalink)
SE-R GREEK
Feedback Score: 8 reviews
Note:
The pics above are for the B14 MAF grounding process.
B13s are almost identical but the connector is a bit different.
Old 01-03-2006, 09:16 AM   #3 (permalink)
YOUR F0RUM SUX
Noted! Thanx for the correction.
Old 01-03-2006, 09:56 AM   #4 (permalink)
Feedback Score: 11 reviews
Very nice job You made it look so easy I think I'll have to reground mine now.
'99 Sentra SE-L
'91 Sentra SE-R sold
FloridaSR20s
Thomas
sr20sentra91 is offline   Reply With Quote
Old 01-03-2006, 03:50 PM   #5 (permalink)
what gauge wire is the stock wire?
Robert
-91 Pulsar GTi-R (JDM)
-95 Primera SLX 2.0 (UKDM)
-93 Sentra SE-R (USDM)
94AztecClassic is offline   Reply With Quote
Old 01-04-2006, 03:41 AM   #6 (permalink)
YOUR F0RUM SUX
Pretty sure its 16 or 18. Its pretty damn thin.
Old 01-04-2006, 04:37 AM   #7 (permalink)
The smooth funky classic
brokeser's Avatar
Feedback Score: 12 reviews
Thank u for the remake Great photos.
L
brokeser is offline   Reply With Quote
Old 01-04-2006, 10:52 AM   #8 (permalink)
YOUR F0RUM SUX
L
LOL.. You like? Well I felt the need because I like the fact that I can actually look at the general idea of whats going on. When doing a new project that I don't know crap about. And pics always help. Thanx for the good feed back ***. I appreciate it. I'm going to make more as I do new projects. Actually I'm working on a new system setup this weekend that I'm going to take pics of. So stay posted.
Wayne.
Old 01-04-2006, 06:53 PM   #9 (permalink)
El Rey de los Chingones
Isfahan's Avatar
That looks way too easy. I've been itching to do something on my car for a while, and since the Progress stuff still hasn't come in yet it looks like it is time to play around with the electical system of my car again. On the B13, is the center wire still the one to splice? Hpro 123 said the connectors are different, but I'm guessing you just pop it out differently? Thanks for the great post!
Isfahan is offline   Reply With Quote
Old 01-14-2006, 04:58 PM   #10 (permalink)
Lock it up!!!!
Feedback Score: 15 reviews
great job definetly makes it look easy. I am defitnetly doing this now. Does it really make that much of a difference? UMMMM just thinking I dont have a stock maf anymore should I still do it?
97 200sx Se-r. Back in my possession
12 Wrx 5dr hatch
08 Yamaha R1
11 Lexus IS 250 (wife's ride)
Joes97turboSE-R is offline   Reply With Quote
Old 01-14-2006, 05:59 PM   #11 (permalink)
YOUR F0RUM SUX
Thanx. I did notice a bit of a difference in it. Milage and performance wise. I don't see why not. Do you still have the stock harness? If so go right ahead and do it. Can't hurt.
Old 01-14-2006, 10:05 PM   #12 (permalink)
banned
Feedback Score: 5 reviews
Where the pics of the DMM showing you had a bad ground at the MAF or before and after specs of the voltage, do you have any?
charlie2020 is offline   Reply With Quote
Old 01-14-2006, 10:10 PM   #13 (permalink)
YOUR F0RUM SUX
Didn't take any and didn't use one. Just for the fact that its just a ground. And nothing could be bad from finding a better one. And the fact that it was the last and final mod in my search for better gas milage and stock performance.
Old 01-14-2006, 10:20 PM   #14 (permalink)
The Genesis
bad MAF grounding is a common problem for us. Not all cars are affected, but nonetheless, it doesnt hurt to do this simple mod. Personally, ive never tested my MAF readings to see if mine is grounded well enough, but im still gonna do this trick just because its free and easy, plus when it comes to electrical stuff, a GOOD ground always helps. good job on the write up and good pics too
Dork!
Old 01-19-2006, 09:20 PM   #15 (permalink)
http://www.se-r.net/engine/maf_ground.html
That link has info on how to test for a bad ground.
I did this tonight and my idle is now rock solid, Hopefully I'll see some mpg improvements as well.
rsayers is offline   Reply With Quote
Old 01-19-2006, 11:14 PM   #16 (permalink)
DBA/IT
Feedback Score: 22 reviews
Originally Posted by rsayers
[url]I did this tonight and my idle is now rock solid, Hopefully I'll see some mpg improvements as well.
I was getting about 23-25 mpg before reground, and now I get a good 26+ mpg every tank. Good schitt
http://www.rollyourcar.com
Old 01-20-2006, 01:45 AM   #17 (permalink)
YOUR F0RUM SUX
Nice! Keep us posted on any better numbers. Glad to see this helped ya'll out.
Old 01-21-2006, 07:00 PM   #18 (permalink)
Isfahan's Avatar
Quick question for those of you with B13's that have done this. When I opened up the tube (not electrical tape) that the wires run in on their way to the plug, I found two wires, a grey and white one that seems to be about 10 gauge thickness, and an orange/blue one that is around 16 gauge. Am I missing something, or is one of those the ones I splice my new ground into like mentioned above? Thanks,
-Nic
Old 01-22-2006, 09:42 PM   #19 (permalink)
Isfahan's Avatar
I finally finished. Turns out that the grey and white wire that was thick actually had two of the three wires (including the ground) running inside of it. It even had metal wire inside of it, like a normal wire, running alongside the other two wires. But that metal wire didn't go anywhere. I wonder why they did that? Anyway, I got it all hooked up and ready to go. Thanks for the great write-up!
-Nic
Old 01-22-2006, 09:56 PM   #20 (permalink)
banned
-Nic
Its called shielding, and the shielding runs back almost to the ecu where it branches off to many other grounds, some of teh ground go to actual ECU pins and from there go to ground points of teh chassis, its important you keep these shielded wired seperate or else you'll get a short to ground.
HTML code is On
