Old 03-03-2007, 04:19 PM   #81 (permalink)
STRATTON
i love b13's !
Trader Rating: 20 (100%)
370 cc = 250 WHP * Purple SR20DET
---------------------------------------------370 cc @ 4 bar = 290
dre, got a question, 370cc @ 4 bar @ 90-92% injector duty cycle would = out to about what kind of whp ??
stratton.
im back.......
Old 03-05-2007, 05:49 PM   #82 (permalink)
Hanzzzzz
The Anti-Riced
This is what i got based on information from this thread, someone please correct me if i am wrong.
assuming it is a 4 cylinder at 4BAR fuel pressure:
For a turbo car at 12:1 fuel to air mix:
(injector size in CC's) x 0.783 = max whp the injector can support (roughly)
For a N/A car at 13.5:1 fuel to air mix:
(injector size in CC's) x 0.881 = max whp the injector can support (roughly)
Since duty cycles were not given, I dont know how they would factor in.
I am not a tuner, just a guy who passed grade 9 math.
Hanzzzzz is offline   Reply With Quote
Old 03-05-2007, 06:05 PM   #83 (permalink)
Sigfod
Sigfod's Avatar
Oh do 3 bar next!
96 SE-R Totaled in '99
2000 Sentra SE w/ GTi-R 2.0T
2006.5 2006.5 GTI DSG 2.0T FOR SALE
2008 BMW 328xi Touring
2008 BMW 328xi Coupe
Sigfod is offline   Reply With Quote
Old 05-13-2007, 10:11 PM   #84 (permalink)
BoostThis
what are the HP numbers for the top feed 00-02 RR sr20motor injectors?? its not listed in the first post.
BoostThis is offline   Reply With Quote
Old 05-17-2007, 11:39 PM   #85 (permalink)
DeNismo
VVL Junkie
what type of injectors are in the VZ-r?
Nissan Pulsar Gti-R'91 - under constuction (sr20vet in the garage)
DeNismo is offline   Reply With Quote
Old 05-18-2007, 01:13 PM   #86 (permalink)
XxToKeSxX
Got Hung Out to Dry!
XxToKeSxX's Avatar
Trader Rating: 42 (100%)
That's pretty good
In reality though, I don't think the relationship is linear... Since its volumetric flow. The formula probably has a couple polynomials, like to the second or third order or something... if your testing maximum flow there is probably only one variable still. If the duty cycle is taken into account you would be dealing with less than maximum flow, and another variable might be thrown in there... but this is just taking it from not much higher than a 9th grade math basis.
In other words, your rule of thumb calc is fine for rough numbers.
The reason max flow is calculated is because that gives you what your potential whp output is... if you want a rough calculation for whp just take what your duty cycle is and multiply it times the maximum whp numbers that are given (if the numbers given are at 100% duty cycle...
Are the number's shown on the first page maximum whp numbers for injectors at 100% duty cycle?
If yes... for a rough number... given the numbers provided are maximum potential whp numbers
370cc's at 4 bar = 290whp from first post (assumin MAF supports)...
92% duty cycle = 0.92 x 290whp = 266.8whp (roughly)
93% duty cycle = 0.93 x 290whp = 269.7whp (roughly)
and so on...
I'm probably wrong... but its all rough estimation, there are a few more factors, the best way to get true numbers is dyno test data, and injector flow test data.
1998 SE-R | S3Rs/I/H/E/M | 99.9% Daily Driver | Rubí DeL FuegO
1993 NX-? | Have No Clue | 00.1% Daily Driver | The Diable-Bleu
1991 nX-T | My Boost Slut | 00.1% Daily Driver | The Deviled Egg
Shift_from a Sentra, and got Scrambled Eggs
Old 05-22-2007, 02:01 PM   #87 (permalink)
RedDragun
The DET is in!
Trader Rating: 17 (100%)
How much whp are the Subaru injectors good for at 4 bar?
W11 Avenir
GTi-R T28 Setup
Greddy Type S BOV
FMIC
Calum Realtime
Z32 MAF
Subaru 520cc Injectors
O2 Induction Style Manifold
Autometer: Water, Oil, Boost
3.5" Front Bumper Side Exit Exhaust
Progress Coilovers
Walbro 255lph
Nismo AFPR
ACT Xtreme Clutch
Prothane Motor Mount Inserts
RedDragun is offline   Reply With Quote
Old 05-22-2007, 02:22 PM   #88 (permalink)
chriscar
merely a flesh wound
chriscar's Avatar
Trader Rating: 96 (100%)
Well if you look at the original chart, and divide the whp by the injector size, you'll come up with .67 for 3bar setups and .77 for 4bar.
I had my STi injectors flow tested at 520cc so at 4bar, that calculates out to (520*.77) = 400whp
Old 05-22-2007, 04:33 PM   #89 (permalink)
RedDragun
The DET is in!
I thought they were 525cc at 3 bar?
Old 05-22-2007, 06:31 PM   #90 (permalink)
chriscar
chriscar's Avatar
Mine were tested and came out to 520 @ 3 bar. You're going to sweat 5cc?
Old 05-22-2007, 11:37 PM   #91 (permalink)
RedDragun
The DET is in!
Lol no I thought you had said that they were 520cc at 4bar but then I re-read it and I get it now.
Old 06-05-2007, 07:08 AM   #92 (permalink)
ruthlessef-9
whats with this changing of chip/map?? is this with FWD SRDET's?
or does this go for RWD too
cause If i can' get more WHP with just increasing my fuel pressure Im going to 4bar ASAP!
ruthlessef-9 is offline   Reply With Quote
Old 06-05-2007, 02:42 PM   #93 (permalink)
gomba
Endless Turbo Preparation
The STI injectors should be added to the original post.
'95 200sx SER - Loading Turbo.exe |!!!!.................| 22%
"He who asks a question is a fool for five minutes; he who does not ask a question remains a fool forever” - Chinese Proverb
gomba is offline   Reply With Quote
Old 07-05-2007, 11:40 PM   #94 (permalink)
STRATTON
i love b13's !
what to be sure here so ill ask the guru's. what injector will run at 4 bar fit in a stock rail and fit in a aft market rail that will fit a 02 intake manifold ?
stratton.
Old 07-07-2007, 10:54 AM   #95 (permalink)
P11-144
Also known as LOEK
Is there any sense in raising the fuel pressure on a, apart from intake and header, otherwise stock motor ? I heard it could get rid of a ' flat' spot in the power curve ?
Primera 01 Wagon EUDM CVT DV9 2,25' SS Advanti AEM Autometer Bride Carbing CS-BABK Eibach ES Flexalite Greddy HKS K&N Koni-Sport Magnaflow Momo NGK Nismo Nissport Optima-Red PIAA Progress Raptor Remus Sachs 'SARD' Sparco SSAC Stillen Taylor Toyo Vibrant Walbro Wilwood
P11-144 is offline   Reply With Quote
Old 07-16-2007, 01:54 PM   #96 (permalink)
fullahwickednez
B15NYC.COM Founder
Originally Posted by Andreas Miko View Post
3 bar or 44 PSI with vacum hose off is stock fuel presure.
so on the list its stated 259 cc = 175 WHP * Red SR20DE those are the factory injectors correct?
so at 3 bar they can support up to 175 WHP but at 4 bar, those injectors could be capable of flowing 300cc? how much WHP is that good for?
fullahwickednez is offline   Reply With Quote
Old 07-16-2007, 01:58 PM   #97 (permalink)
SENTRASER
Drive it like ya stole it
SENTRASER's Avatar
Trader Rating: 33 (100%)
175 / 259 = .67 *300 = 202 whp
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Old 07-16-2007, 02:02 PM   #98 (permalink)
fullahwickednez
B15NYC.COM Founder
hehe I just scrolled up and saw the rough formula and got that number also. thanks for the help though, I appreciate it.
Well if theyre capable of handing 200WHP, why do people flame the noobies who want to use their stock injectors on a bluebird t25 at stock boost? I thought a DE on a t25 makes 200 to the crank?
[of course this is with upgraded fuel pump]
Old 07-16-2007, 04:51 PM   #99 (permalink)
SENTRASER
SENTRASER's Avatar
Because why pay for the program and MAX out your stock fuel injectors when for around $100 you can atleast get 370's? I didn't use the formula, I just figured it out actually.
