Inj Size And WHP Output - Page 8 - SR20 Forum
Old 04-24-2009, 11:06 PM   #141 (permalink)
merely a flesh wound
chriscar's Avatar
Feedback Score: 110 reviews
You asked what's necessary to go to 4bar (1st post), and if that alone would support 175whp on an SR20DE (2nd post), then stated that you wanted 200whp NA (3rd post).
Stock injectors will support 175whp as shown in post #1 of this thread.
It's not much of a stretch to figure out the equation needed to determine what they'll support at 4bar (203whp), however, to do that, you'll need to buy an adjustable fuel pressure regulator, and fuel pressure gauge (either way, you'll need an ecu retune). It would be more practical to buy a used set of 370cc injectors for ~$100.
I suggested starting a new thread because your 3rd post indicated you're looking to push such high whp NA. FYI - In all my time here, and it's been a long time, I don't recall anyone running a normally aspirated DE who needed to upgrade their stock injectors.
Old 04-24-2009, 11:38 PM   #142 (permalink)
so the 370cc injectors would put me just over 200 (in theory), could i go to 444cc? and would either one require the ecu retune? thanks for the response
AU G20 BB is offline   Reply With Quote
Old 04-24-2009, 11:41 PM   #143 (permalink)
going thru life @ 1 bar
Feedback Score: 21 reviews
bigger injectors SUPPORT the higher HP levels, ALONE they will not give you the HP
...Currently down due to a clutch disc spring failure....
Old 04-24-2009, 11:46 PM   #144 (permalink)
chriscar's Avatar
Changing injectors or fuel pressure ALWAYS requires an ecu retune. 370's (and 333's from a VE) fit in a stock rail and any injector running 3bar will not require an adjustable fuel pressure regulator and for 99% of NA DE people, stock 259's @ 3bar are sufficient. 440's are top feed and need an aftermarket rail. Don't take this the wrong way, but unless you're planning on dumping major dollars into a DE, I doubt you're going to need any sort of injector upgrade. You're asking noob questions, and while that's not a bad thing, they've been addressed many time in other threads, and don't belong in this thread, which is more of a reference thread. The number of views vs posts (23,645 vs 143) bears this out.
Old 04-25-2009, 11:44 AM   #145 (permalink)
sorry, point me in the right direction and i'll be glad to go there (new to the forum)
Old 04-25-2009, 11:46 AM   #146 (permalink)
http://www.sr20forum.com/search.php
Old 07-21-2009, 01:36 AM   #147 (permalink)
Feedback Score: 6 reviews
ok these injectors on the left are the oem p11 roller rocker ones.
How many cc are these? The list says gray injectors top out at 226 whp but it says thats for VE motors.
fullahwickednez is offline   Reply With Quote
Old 07-21-2009, 10:22 AM   #148 (permalink)
Turbo monkey
Feedback Score: 3 reviews
RR injectors are 259cc
Koojo is offline   Reply With Quote
Old 08-05-2009, 04:28 AM   #149 (permalink)
custom sr20ve
Dear all,
Now I am running SR18 but rebored to 2000cc using SR20VE's pistons. Engine head is ported n polished, using TOMEI cams with 260lift.
What size of injectors should I use ?
thanks
an article about a funny forum (MUST READ)
http://timelesscomments.blogspot.com...ous-forum.html
b14bot is offline   Reply With Quote
Old 08-07-2009, 04:51 AM   #150 (permalink)
What exactly is needed to install MSD injectors into a roller rocker fuel rail? Will a SAFCII be able to control the 50 lb ones?
Old 10-26-2009, 02:38 PM   #151 (permalink)
need to know what size are a set of injectors i have. they are from a subaru non-turbo engine and the color of them is grey. i have googled it and have came up empty. i am planning another ga build for my b12. i know they arent the same size as the red ones because the red ones that come on the impreza non turbo are 280 and are red. i got them off a old wagon like a 93 to 98. not sure if it 2.2 or 2.5.
bestb12injersey is offline   Reply With Quote
Old 02-08-2010, 02:11 AM   #152 (permalink)
The New DVLDEGG
Feedback Score: 5 reviews
Just curious if anybody has tried it or not but I have the blue, top feed 39lb EV6 injectors out of a supercharged 03-04 cobra. I have these for my mustang but havent used them yet. We were thinking about trying them along with a JGY top feed fuel rail on my little bros turbo b13. He is currently running 370,s and it leans out hard and fast when it picks up the boost.
98 240SX SE - Stock... For now...
03 Sentra Spec V 6spd - Another Project car...
91 NX2000/DVLDEGG - The New DD Build thread HERE
05 Suzuki SV650S - Corner carver
91 MR2 Turbo - Future project(turbo needs rebuilt)
92 Sentra SE-R - R.I.P(Parting out here)
01 Mustang GT - 13.323@102.45 NA (sold)
dracer35 is offline   Reply With Quote
Old 09-22-2010, 03:47 PM   #153 (permalink)
hey guys do you have the part number for the oem subaru sti yellow side feed injectors?
trinisentra is offline   Reply With Quote
Old 03-31-2011, 06:20 PM   #154 (permalink)
Does anyone have specs on 550 rc i am running a t28 and not sure at what bar to send out my jwt to get tune for
BoostingSE-R is offline   Reply With Quote
Old 03-31-2011, 06:21 PM   #155 (permalink)
top feeds dont like anything but 3 bar
Old 06-23-2011, 06:22 PM   #156 (permalink)
what the hell are these ???
thanks
Bubzi is offline   Reply With Quote
HTML code is On
