Old 07-17-2007, 11:03 PM   #101 (permalink)
P11-144
Also known as LOEK
Thanks for NOT answering my question.. Too difficult ?
Primera 01 Wagon EUDM CVT DV9 2,25' SS Advanti AEM Autometer Bride Carbing CS-BABK Eibach ES Flexalite Greddy HKS K&N Koni-Sport Magnaflow Momo NGK Nismo Nissport Optima-Red PIAA Progress Raptor Remus Sachs 'SARD' Sparco SSAC Stillen Taylor Toyo Vibrant Walbro Wilwood
P11-144 is offline   Reply With Quote
Old 07-17-2007, 11:35 PM   #102 (permalink)
SENTRASER
Drive it like ya stole it
SENTRASER's Avatar
Trader Rating: 33 (100%)
Originally Posted by P11-144 View Post
Is there any sense in raising the fuel pressure on a, apart from intake and header, otherwise stock motor ? I heard it could get rid of a ' flat' spot in the power curve ?
On a what? You didn't make a complete statement so how can anyone respond? No there's no reason to raise the fuel pressure unless you make use of the extra fuel.
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by chriscar
Old 07-18-2007, 10:44 PM   #103 (permalink)
P11-144
Also known as LOEK
I DID make a complete statement. It says on a -apart from intake and header- otherwise stock motor. That means that my motor is stock, except for a header and intake. What info was missing ?? Obviously it concerns a sr20motor.
Regarding your answer: I have read that a flat spot in the power curve, which is accentuated by a cai in some cases, can be corrected a littlr or almost completely by raising the fuel pressure a bit. My question was if anyone of you guys can confirm this.
Old 07-19-2007, 06:38 PM   #104 (permalink)
NEEDaSE-R
B13/P11
50lb at 4bar?? anyone know the max whp? Im actually running a little more fuel then 4bar maybe 4-5psi more..
91 se-r t3/t04e
01 P11
03 Kawasaki Ultra 150 SOLD
88 Kawasaki X2 new toy
94 Sea Ray 230 Sundancer
GAINING RESPECT ONE REDLIGHT AT A TIME...
NEEDaSE-R is offline   Reply With Quote
Old 07-19-2007, 06:42 PM   #105 (permalink)
SENTRASER
SENTRASER's Avatar
K, start a new thread, you're clogging up this already long thread with unrelated information.
Old 08-24-2007, 01:06 PM   #106 (permalink)
jen36
Im Not A Chick
259 cc = 175 WHP * Red SR20DE
ok im new to the whole fuel thing but im reading as i go. basically with all my mods that i will have in my car N/A sr20de motor i will be around 160 165 ish now as it states above my stock injector top off at 175. will i be ok with the stock injectors since they are close to topping out? this will be at 3 bar.
it seems like the next upgrade will be the 333 cc = 226 WHP * Grey SR20VE injectors... will this be a lil to much over kill??? will i be running rich??
i figure since we make roughly 115 to 120ish whp stock running 259 cc injectors and running fine without running rich then i should be ok if i add 40 more horses and upgrading to 333cc injectors then i should be fine. but that is just my theory...
basically i just wanna *** if i should upgrade?
jen36 is offline   Reply With Quote
Old 09-03-2007, 12:24 PM   #107 (permalink)
jen36
Im Not A Chick
anybody?
B13 XE with sr20 swap(5 speed swapped)
B13 LE parts car
NX2K RIP (Aug 13 2007) parts car
NX2k soon to be parts car
NX2k my new baby!
NX PART OUT CHECK IT OUT!
http://www.sr20forum.com/mechanical-...-nx-parts.html
We are a community!
Old 09-08-2007, 11:10 AM   #108 (permalink)
Keo
huh??
Trader Rating: 36 (100%)
Originally Posted by jen36 View Post
anybody?
you'll be fine with the stocker.
everything else is all in the tunning
Old 09-17-2007, 01:26 PM   #109 (permalink)
Luis
Guanaco Tuner
Luis's Avatar
Andreas, what would the max be for the "new" Nismo yellow injectors that flow 615cc and also those same injectors at 4bar.
Old 09-17-2007, 03:49 PM   #110 (permalink)
Andreas Miko
Jah Rastafari
Trader Rating: 52 (100%)
555 cc = 373 WHP * Yellow
---------------------------------------------555 cc @ 4 bar = 423 WHP
601 cc = 405 WHP * Yellow Tomei
---------------------------------------------601 cc @ 4 bar = 457 WHP
To keep things safe use this as a limit. Also these injs look the same and if you do not know which one you got use 373 WHP 3bar and 423 WHP 4 bar as your limit.
Always beter to keep it safe.
Old 09-17-2007, 03:55 PM   #111 (permalink)
Luis
Guanaco Tuner
Luis's Avatar
Yeah I got my injectors from Japan in the original box. I verified the part number with JWT as the 615cc units. So I guess I'm good to 450 without worries. Thanks for getting the ball rolling on their 615 + 4 bar program.
Old 09-17-2007, 03:57 PM   #112 (permalink)
Andreas Miko
Jah Rastafari
Thanks for the props
Old 10-30-2007, 03:09 PM   #113 (permalink)
CanSR20
I'll be honest and say this was all pretty much Greek to me so I'll ask my quick question and hope to not get flamed to badly lol. After reading I checked my fpr and it was at 60psi, I dropped it down 50psi thinking it was to high regardless. So will this trick work with out JWT mods to the ECU or should I put it back to 44psi? Injectors are 38s.
CanSR20 is offline   Reply With Quote
Old 12-04-2007, 09:26 AM   #114 (permalink)
Master_Sentra
65 lbs/min of Fury.......
Master_Sentra's Avatar
What about the EVO injectors?... are they compatible with GTiR's?
Someone is offering me FCI 850cc or FCI 1150cc. at a very reasonable price.
How much WHP can be expected from both running with the stock DET FPR (3 bar) and would the 1150’s be adequate for a DD??
Club Nismo Peru
http://www.clubnismoperu.net
In the quest for 500+ whp...
Master_Sentra is offline   Reply With Quote
Old 12-04-2007, 09:29 AM   #115 (permalink)
Andreas Miko
Jah Rastafari
Why do you need injs that big. 740 cc injs will net you 520 WHP at 3 bar. A 520 WHP car is no joke, much less one for a daily driver which to me would not even be fun.
Think of your goals and get the smallest inj that will get you there.
Old 12-04-2007, 09:48 AM   #116 (permalink)
Master_Sentra
Originally Posted by Andreas Miko View Post
Why do you need injs that big....
I don't... it's just that my friend has the 850cc and 1150cc available at really low price (they were on his talon tsi)...
So I guess 850's would be more than enough...
Old 01-04-2008, 09:01 PM   #117 (permalink)
1gDSMer
Rotten Egg
i bought some rc720's from my buddy with a turbo 4g64. ive been told they will work but do you know andreas? on my gtir engine. and was wondering if rc injs are fine to run on 4 bar since i read msd's arent. lmk if you can.. thanks
matt
93 Electric Blue NX2000
1gDSMer is offline   Reply With Quote
Old 05-11-2008, 10:07 AM   #118 (permalink)
unijabnx2000
where do i put it?
any one know why the WHP & Inj size "chart" is different(not close either) than the formula
horsepower X b.s.f.c.
______________________________________
# of injectors X 0.80 (duty cycle)
Old 05-11-2008, 12:49 PM   #119 (permalink)
Luis
Guanaco Tuner
Luis's Avatar
BSFC can vary widely between our engines depending on modification level etc. This is a guide based on real world results. There are plenty of Injector x BSFC calculators out there.
Old 05-11-2008, 01:13 PM   #120 (permalink)
unijabnx2000
where do i put it?
