Old 01-23-2006, 06:02 PM   #21 (permalink)
merely a flesh wound
chriscar's Avatar
Part numbers added to the first post. Have fun!
Old 01-23-2006, 06:19 PM   #22 (permalink)
i love b13's !
Trader Rating: 22 (100%)
drool at both the gauge install and the engine. good work bro ! very oem looking wich is a huge plus as far as interiors go.
stratton.
im back.......
Old 01-23-2006, 11:47 PM   #23 (permalink)
Also known as LOEK
Chris: That is beautiful !
Can you tell a bit more about the install of the boost gauge ? Maybe a rear view of the panel ? Some pics of the finished product in place ?
I'm much into gauges myself. I will relocate my radio and install a din-panel with 3 gauges instead. I would like to insatll my Autometer temp-gauge instead of the stock one. Your write-up is an excellent guide...
Primera 01 Wagon EUDM CVT DV9 2,25' SS Advanti AEM Autometer Bride Carbing CS-BABK Eibach ES Flexalite Greddy HKS K&N Koni-Sport Magnaflow Momo NGK Nismo Nissport Optima-Red PIAA Progress Raptor Remus Sachs 'SARD' Sparco SSAC Stillen Taylor Toyo Vibrant Walbro Wilwood
P11-144 is offline   Reply With Quote
Old 01-24-2006, 12:52 AM   #24 (permalink)
Enjoy the GTR Matt!
Trader Rating: 23 (100%)
yes, please give details about the boost guage. You mentioned cutting some traces but finally working it out.
Details please! I want to add an oil temp guage but I don't want an A-pillar setup or a pod sitting on the dash.
Old 01-24-2006, 09:39 AM   #25 (permalink)
chriscar's Avatar
Pics for now, details later. Also, checkout all the pics here - http://sr20.net/gallery/Gauges
Old 01-24-2006, 02:36 PM   #26 (permalink)
Also known as LOEK
Nice ! Eager to learn more about this procedure....
Old 01-24-2006, 02:44 PM   #27 (permalink)
chriscar's Avatar
What would you like to know?
Old 01-24-2006, 03:06 PM   #28 (permalink)
Also known as LOEK
On the P11-144 Primera, both OEM uel level and water temp gauges are positioned next to each other at the right hand top side of the cluster. Water temp furthest right. What I intend to do is take the latter out and substitute it with Autometer electric water temp gauge Sport Comp 2 1/16 model. It will be kind of delicate, because I don't want to damage any circuits in the process. My car is OBDII; could I get a CEL for taking the OEM water temp gauge out ? Anyy suggestions about what to do and what not ?
Furthermore, replacing the radio/cassette player with a din-plate and 3 gauges, I will have to relocate the radio/cassette.
Any suggestions as where to tap-in a vacuum/boost gauge ? I'm running n/a for the time being, so it will be reading vacuum only. Going turbo around summer maybe. If I have ay other concerns on gauges I'll pm ya , OK ?
Thks
Loek (= Dutch for Luke)
Old 01-24-2006, 06:39 PM   #29 (permalink)
SR20 Geek
I am making a similar center piece for my car, but it will only hold 2. I do give oyu props on boost gauge. The looks awesome in the coolant spot. Looks good, man.
-Shawn
B14Boost is offline   Reply With Quote
Old 02-03-2006, 12:13 AM   #30 (permalink)
Master Cunnilingust
Trader Rating: 37 (100%)
Nice work Chris! How many tubes of silicone did it take to hold that boost gauge in though? My plan when I was going to do an Avenir swap, was to just scrap the white portion of the cluster and the circuit board, scrap the OEM harnesses and use a single 30+ pin Molex harness to make all the connections. Cut out the OEM gauge face and glue in a new ABS one that had all my new gauges and lights installed in it. Fab up mounting brackets as necessary. I'm glad I won't have to do all that work.
- Rob
Old 02-03-2006, 01:33 AM   #31 (permalink)
chriscar's Avatar
You know how it goes, the first time is messy, and takes forever. I could bang one out allot quicker now, and with allot less silicon. But hey, it's in there nice and firm, all the electrical connections are solid, and it looks perfect from the front.
Old 02-27-2006, 09:57 PM   #32 (permalink)
King of the Boom-Bap
I am exhausted. I am searching for info on installing a oil pressure gauge on my JDM de. The posts that I have found help me with the gauges, but not where to drill+tap. Frustrating but I know it is probably the pan or somewhere simple . -1 for districtborn.
They call me the Minotaur!!!
Aim: DistrictAndre
Yahoo: districtborn19
districtborn19 is offline   Reply With Quote
Old 02-27-2006, 10:03 PM   #33 (permalink)
chriscar's Avatar
Re-read post #14.
You don't drill and tap for the oil pressure sensor, it goes in place of the original dummy light sender.
This is my VE, using a Nissport adapter (viewed from above)
And this is my turbo, running off the oil feed line to the turbo
Old 02-27-2006, 10:52 PM   #34 (permalink)
Woot. Thanks alot. I am scared to run a new engine without a pressure gauge. I need to step my wrenching up.
Old 03-09-2006, 07:35 PM   #35 (permalink)
Trader Rating: 41 (98%)
Thanks for the write up Chris... This here saves the day!!!
Erikbronx is offline   Reply With Quote
Old 03-12-2006, 11:38 AM   #36 (permalink)
Trader Rating: 53 (100%)
Originally Posted by chriscar
Drilled and tapped the water inlet for the water temp sender.
Ver nice write up and pics, but I was wondering about the left side of the alternator. Why did it get no love?
Old 03-12-2006, 11:49 AM   #37 (permalink)
chriscar's Avatar
Thanks for the compliment. Hmm, not sure about the left side of the alternator though. I used a wire wheel on my bench grinder to clean the alternator up, but the left side does look unloved. I had tried to take it apart, but couldn't get the case disassembled. The front looks good, the right side looks good, so it's a mystery to me.
lol - I just went into the garage and popped the hood.. I definitely could have done a better job on that left side. Well, I need to replace the left side motor mount bracket, because one of the holes is stripped, and I'll spend some quality time with the the alternator when it's out!
Old 03-12-2006, 12:22 PM   #38 (permalink)
Your engine looks very nice, I thought it just looked like you didn't paint/polish the left side of the alternator cover like the right side.
Old 02-18-2007, 04:05 PM   #39 (permalink)
SR20nation.com
Trader Rating: 31 (100%)
Would that panel still fit with autometer gauges?
SR20Nation.com
Old 03-10-2007, 04:11 PM   #40 (permalink)
Heres my setup with the autometers
Sold
SOLD
c('o'c)
SR20ANONYMOUS
gtirb13 is offline   Reply With Quote
