Old 05-08-2007, 12:10 AM   #41 (permalink)
Chris for the centerl panel how did you attach the tabs to the plastic? I'm thinking either glue or some kind of screws.
Old 05-08-2007, 01:11 AM   #42 (permalink)
Trader Rating: 31 (100%)
and could you give us a more indepth process as to what you needed to do to get the gauge cluster to function normally after the boost gauge was put in?
93 NX2K---Boosted!
91 NX2K---Sold
99 G20 ---Sold
92 NX2K---Undergoing construction
squabzter is offline   Reply With Quote
Old 06-03-2007, 11:57 PM   #43 (permalink)
_______
Mike's Avatar
Trader Rating: 56 (100%)
Just wanted to say thanks to Chris! I got my gauge install rocking http://www.g20.net/forum/showthread.php?t=64451
Mike
Mike is offline   Reply With Quote
Old 07-14-2007, 09:54 PM   #44 (permalink)
Seeing red
JimR's Avatar
Now that my SE-R will spend most of its time driving to and from autocrosses and trackdays, I figured gauges were a good idea. I like Chris's setup, so I guess imitation is the sincerest form of flattery.
I have no boost, cams, or VE, so I chose a voltmeter/water temp/oil pressure setup. A voltmeter is much more telling than waiting for the emergency brake light to start flashing when the alternator starts dying a long way from home. Yeah, been there. And water temp and oil pressure are the two pretty much everyone needs.
Much like electricity, I take the path of least resistance. The SE-R is stereo-less and no longer a daily driver, so the spot vacated by the head unit leaves me with an easy source of dimming and switched power (aka only juiced when the key is turned). I bought a cheap Nissan stereo wiring harness from Wally World, and pulled out all the pins I didn't need, leaving ACC and two illumination wires to run to the gauges. It all plugs right in, no extra cutting/tapping/wiring neccessary.
The 42 Draft DIN gauge panel is kind of thin. I made brackets out of aluminum angle stock from Lowe's, and mounted the panel with four tiny screws and some crazy Loctite epoxy. I used the same aluminum stock to make a bracket for a terminal block for my grounds. One wire connects to metal around the shift boot and distributes to three wires going up the gauges. Overkill? Probably.
The oil pressure sender is mounted to the firewall engine mount/shifter bracket with a sturdy $2 exhaust hanger bracket from Autozone. That's the last of my creativity on the sender end. Going to Custom Steel for all the other underhood bits will make things easy. The wires go through the firewall in the factory hole by the wiper motor, just behind the passenger side strut tower on a B13.
I'm an electrical knuckle-dragger, so anyone can do this with a little time and money.
1992 SE-R / 1993.5 G20
JimR is offline   Reply With Quote
Old 07-14-2007, 10:31 PM   #45 (permalink)
Cookin Up Some Snails
Trader Rating: 16 (100%)
ive never seen this thread .
Great job Chris. all your work is allways good to look at.
rodrigo is offline   Reply With Quote
Old 08-16-2007, 12:38 AM   #46 (permalink)
Pursuit of happiness
Thanks you guys, this will come in handy.
saved me alot of time.
Ed
pathfinder7 is offline   Reply With Quote
Old 09-17-2007, 02:40 AM   #47 (permalink)
Always Dubbin'
i just ordered all my gauges and din plate.. hopefully the boost process on my sentra will go smoothly, if not theres always time to change stuff up. Thanks for the how to Chris
Coming soon: Project Daily
GT25 powered Volkswagen GTI ~ 275whp on stock internals
92serturbo is offline   Reply With Quote
Old 09-20-2007, 09:09 PM   #48 (permalink)
"The Chubby Panda"
Trader Rating: 19 (100%)
mmm...tasty phantom water gauge in stock gauge place....
mmm....hole for new gauge placement when they arrive....
My other NX....is an NX.
Canx2k is offline   Reply With Quote
Old 08-24-2008, 05:31 PM   #49 (permalink)
<>< Jesus is the Answer
blairellis's Avatar
bumping this thread, anyone got pics of their install in a P10?
Got it figured out. Heres mine for now:
Blair
93 P10
Old 08-24-2008, 07:13 PM   #50 (permalink)
_______
Mike's Avatar
http://www.sr20forum.com/gallery/***...y.php?cat=1381
That's a link to the pictures from my gauge install thread.
Mike
Old 09-07-2008, 10:46 AM   #51 (permalink)
blairellis's Avatar
Anyone know what kind of thread size and pitch the stock oil pressure sending unit is?
Old 09-07-2008, 11:13 AM   #52 (permalink)
_______
Mike's Avatar
The GFD kit comes with a 1/8" npt to 1/8" bspt adapter. I'm pretty sure the threading in the jack is 1/8" bspt.
It is Autometer part number 2269
Mike
HTML code is On
