Gauge installation writeup - Gauges - SR20 Forum
Old 01-22-2006, 10:42 PM   #1 (permalink)
merely a flesh wound
chriscar's Avatar
Feedback Score: 110 reviews
Here's some pics of my gauge install on the turbo NX.
The mounting plate comes from www.42draftdesigns.com.
The great thing about this panel is it's designed with a recess for the VDO Vision gauges, so the bezel sits flush with the face of the panel. Very factory!
It's made to snap in to a DIN slot, so you'll need to fabricate some simple brackets to mount it into a B chassis car.
The radio was easier to move than I thought it would be. I just had to cut up the stock mounting brackets and grind them down here and there.
The real bitch was getting the boost gauge installed. I'm tring to keep the car as low profile as possible (stock wheels, side mount intercooler, tinted windows), so I didn't want to have the gauge on the a-pillar, steering wheel, etc, so I sunk it into the stock temperature gauge spot in the cluster.
At first it looked simple, but I wound up having to cut some of the circuit board traces, one of the 8 pin plugs, and I lost one of the light bulbs for the tach. Eventually I worked it all out, and althoug it ain't pretty behind the scenes, I'm happy with the results.
You're going to need some kind of adapter to install the oil pressure sender. On my turbo car, I connected it to a T fitting on the oil feed to the turbocharger. On the VE, I used a Nissport adapter.
Water temp sender goes in the coolant neck on the passenger side of the engine. Nice and simple, no need for any adapter.
Oil temp sender goes on the back side of the oil pan. Epoxy or weld a piece of bar stock to the inside of the pan to give the sender enough threads to grab.
More pictures here
http://picasaweb.google.com/cscarpul...000TurboGauges
Here's the part numbers.
I bought the gauges and adapters from www.egauges.com, they have excellent prices and usually have everything in stock. There are 2 oil pressure senders listed here. Both are 80psi, but *360-009 has a built in 7psi low pressure warning connection, which you can wire to either your stock oil pressure warning light, or to an external one.
Code:
150-121  2 1/16 0-30 In.Hg. 0-25 PSI Turbocharger Vision      $30.00
350-104  2 1/16 80 PSI Engine Press. Elec. Vision             $25.75
360-009  *Pressure Sender: 0-80 PSI/5 Bar 1/8-27 NPT - 7.0 PSI $33.54
360-003  *Pressure Sender: 0-80 PSI/5 Bar 1/8-27 NPT           $23.75
310-105  2 1/16 250F Engine Water Temp. Elec. Vision          $25.55
323-095  Temperature Sender: 250F/120C 1/8-27 NPT             $6.84
310-106  2 1/16 300F Engine Oil Temp. Elec. Vision            $25.55
323-057  Temperature Sender: 300F/150C 1/8-27 NPT             $6.14
The gauge panel and boost gauge tubing kit came from www.42draftdesigns.com
I bought the boost tubing kit there because it has a push-lock fitting for the gauge, and comes with a t-fitting with a built in restrictor.
Code:
42-023 VW mk4 Triple Gauge Panel                              $20.00
42-150-851 8' plastic boost tubing kit                        $12.00
Old 01-22-2006, 10:47 PM   #2 (permalink)
Technician @ Toyota
scortch99th's Avatar
Feedback Score: 45 reviews
good job chris.
91 classic SE-R (sold)
94 classic LE (falling apart beater)
91 240sx(rps13) (sold)
95 P10 Primera (current daily)
COMPRESSED CLIQ
Originally Posted by STRATTON
freddie your a SICK man.
stratton.
Originally Posted by chriscar
Maximum horsepower is dictated by your wallet.
Old 01-22-2006, 11:05 PM   #3 (permalink)
newbie
Pretty White's Avatar
Feedback Score: 4 reviews
WOW!
Originally Posted by sonny
Old 01-22-2006, 11:33 PM   #4 (permalink)
Original Owner
aztecred92's Avatar
Feedback Score: 9 reviews
I'll second that WOW!
aztecred92
L I V E S T R O N G
'92 SE-R
'85 MR2
'02 Silverado 2500HD
"The most difficult subjects can be explained to the most slow-witted man if he has not formed any idea of them already; but the simplest thing cannot be made clear to the most intelligent man if he is firmly persuaded that he knows already, without a shadow of doubt, what is laid before him." — Leo Tolstoy
aztecred92 is offline   Reply With Quote
Old 01-22-2006, 11:50 PM   #5 (permalink)
Looks good chris. Just fyi, nissport makes a din plate for the vdo gauges that screws right in (it is more then the one you bought though).
Old 01-23-2006, 06:53 AM   #6 (permalink)
GTI-R DONE
Feedback Score: 18 reviews
wow nice work, how do you get ur wire to do that. or do you buy it like that
94 Aztec Red Sentra
Gtir Motor Swap with S3M Cams Love Fab Turbo Manifold and a 3in turbo back.
Turbonetics 60-1 With a PWR Water to Air Intercooler
JWT Ecu 72lb program with Z32 MAF
P11 G20T Tranny. Lenso's and M+H slicks
All Rolling on Drag DR20s and Ksports.
SeRboostSr20 is offline   Reply With Quote
Old 01-23-2006, 08:35 AM   #7 (permalink)
agent camel toe
Feedback Score: 22 reviews
werd..nice write up chris..gotta bring that thing to e-town soon
nyce1s.com
R.I.P. RESPECT SR.
96 b14 det--under the knife
2002 quest gxe--pimp wagon
Old 01-23-2006, 08:44 AM   #8 (permalink)
agent camel toe
seems like all the gauges are electrical...pm sent
Old 01-23-2006, 09:01 AM   #9 (permalink)
Dreamin' of VVL
Feedback Score: 11 reviews
Chris, nice write-up. That is one clean install. Those VDO gauges, sure do match the OEM gauges almost perfectly.
johnand is offline   Reply With Quote
Old 01-23-2006, 10:03 AM   #10 (permalink)
PLAY MY HEAD, MONKEY!
daveracer's Avatar
Feedback Score: 93 reviews
Cool.
Old 01-23-2006, 10:09 AM   #11 (permalink)
agent camel toe
ok caps off...just wondering where u tapped most of these gauges..
Old 01-23-2006, 11:52 AM   #12 (permalink)
chriscar's Avatar
Did they actually ever release that piece? I don't see it on their website.
Old 01-23-2006, 11:58 AM   #13 (permalink)
chriscar's Avatar
Do you mean how did I get them twisted? You just put them in a drill, hold the other side in a vice, and use the drill to twist them up. Simple
Old 01-23-2006, 12:04 PM   #14 (permalink)
chriscar's Avatar
Drilled and tapped the water inlet for the water temp sender.
The oil temp sensor is in the oil pan.
And the oil pressure sensor is on the turbo oil feed line.
Old 01-23-2006, 01:02 PM   #15 (permalink)
I think so (I already bought one from them). I'd just send a message to geo and see if anyone wants to buy one.
Old 01-23-2006, 02:14 PM   #16 (permalink)
GTI-R DONE
wow thats an awesome tip, thanks man
Old 01-23-2006, 04:25 PM   #17 (permalink)
agent camel toe
damn chris..did u buff ur motor?
Old 01-23-2006, 04:29 PM   #18 (permalink)
chriscar's Avatar
Haha, no, just allot of time spent cleaning and painting.
http://sr20.net/gallery/Engine_Assembly
Old 01-23-2006, 04:32 PM   #19 (permalink)
Tired!
coach's Avatar
Feedback Score: 43 reviews
Chris, that is looking great man. Nice job on the write up to, anything added to the forum will help the many down the road.
Brent
1999 SE-L -- back to NA form
Old 01-23-2006, 04:44 PM   #20 (permalink)
agent camel toe
that de is really clean...makes me want to do the same to my det..but i have a bad history with fumes
HTML code is On
