Battery relocation writeup - Page 3 - SR20 Forum
Old 07-04-2007, 12:19 AM   #41 (permalink)
"The Chubby Panda"
Feedback Score: 21 reviews
A note for those doing this:
A trick I used to avoid losing strands of wire when putting on the ring terminal is as follows:
This is a different wire, but should get the point across. (4 Gauge wire shown)
First, make sure the wire is trimmed at the top properly.
Then, measure the terminal you are crimping on.
Then cut 1/2 that distance with an exacto knife, being sure not to cut copper as best as possible. Slide that sucker off.
Then Cut the second half and slide it up the wire almost to the top.
Chase that sheathing back down the copper with the terminal.
Cut the sheathing from the base to the top, and peel it off
Slide the terminal the rest of the way, crimp, and sheathe.
I'm no electrician, but this sure made life easier for my battery relocation because wire stripper don't work on wire this big! I hope it helps you too.
My other NX....is an NX.
Canx2k is offline   Reply With Quote
Old 07-04-2007, 12:29 AM   #42 (permalink)
"The Chubby Panda"
Oh yah, and the KnuKoncepts Terminals require a ring terminal on them, so be sure to calculate that in when you're doing your ordering, and make damn sure you have a dremel or a grinder to take down the terminals to get them to fit on the circuit breakers...measure twice, grind once. I wrecked one by grinding the wrong side.
Also, the battery post terminals have more than one wire grounding spot. I'd reccommend using them all to ground. I installed mine in the trunk under the liner, making sure I took the paint off, and she seems to be running just great!
Thanks Chris!
Old 11-12-2007, 02:11 PM   #43 (permalink)
"The Chubby Panda"
for anyone who thinks this is not a good mod to do, if you have winter at all and don't want to wreck your engine from sucking up water from your cai, do what I do and swap em'! 5 mins later and it's ready for winter.
Old 11-14-2007, 01:52 PM   #44 (permalink)
hey man nice job! i have a ?
will the 22feet wire decrease the power on the battery
i did the same thing but im just guessin my battery is bad.
huggy is offline   Reply With Quote
Old 11-14-2007, 01:55 PM   #45 (permalink)
merely a flesh wound
chriscar's Avatar
Feedback Score: 109 reviews
If you use heavy gauge wire, and do all your connections properly, you won't have any appreciable drop in voltage. What gauge wire did you use?
Old 11-14-2007, 01:56 PM   #46 (permalink)
ga16*****.com
Feedback Score: 31 reviews
The longer the wire, the thicker gauge wire you need.
1997 200SX SE-R - 280whp & 264tq
"Shut the fu*k up and sit down"
Old 11-14-2007, 01:57 PM   #47 (permalink)
im not sure the gage size but it just like yours i just used my amp wire
but its thicker than the stock battery one
Old 11-14-2007, 02:02 PM   #48 (permalink)
chriscar's Avatar
The gauge is usuall printed on the wire. So what happened in your case, you have a problem?
Old 11-21-2007, 02:10 PM   #49 (permalink)
my battery kept dying on me but got the problem fixed!
i just needed to taka a long drive to charge the battery.
Old 12-02-2007, 02:57 PM   #50 (permalink)
Whut?That Ain't No Hondah
Feedback Score: 5 reviews
Please tell me you used a battery tie down Chriscar, that scares the crap out of me. The #1 reason why I don't want to relocate my battery to the trunk is if theres an accident. I don't want any chance that the battery will come loose and fly towards me.
1990 2+2 TwinTurbo 300zx
1.6 to DET Swap
Engine Removal Writeup
Crim is offline   Reply With Quote
Old 12-02-2007, 03:26 PM   #51 (permalink)
chriscar's Avatar
Most definitely.
Old 12-08-2007, 01:06 PM   #52 (permalink)
Feedback Score: 9 reviews
Chris, I've been wanting to do this mod for awhile. While cruising the local Pic and Pull this morning I noticed that the BMW 325 series mount their battery in the trunk. They use a nice heavy cable with really good end fittings and a covered box on the firewall for distribution to the engine components.
I grabbed all the parts, including the cable to the starter for $5. I'm thinking it should fit on our cars as my B13 seems to be about the same size as the 325. Others may want to check this out as an option.
N97746 is offline   Reply With Quote
Old 12-08-2007, 01:08 PM   #53 (permalink)
chriscar's Avatar
Cool. Looking forward to seeing how it works for you.
Old 12-24-2007, 04:38 PM   #54 (permalink)
"The Chubby Panda"
hey chris, I've been noticing a power drop in my car when my car stereo is on, and I think I attribute it to the piss poor job I did crimping...yet I did my best with my pliers...what did you use to crimp those bigass terminals on there?
Old 12-24-2007, 06:08 PM   #55 (permalink)
chriscar's Avatar
I hate to admit it, but I used a combination of a BFH, vice grips, and a bench vice.
Old 02-05-2008, 08:12 PM   #56 (permalink)
24/7 Baller!
What ever happened to the B14 wire up?
'99 SE-L - Autocross Beater
'92 SE-R - Sold!
'04 WRX - Daily
xCONWRATHx is offline   Reply With Quote
Old 02-05-2008, 11:47 PM   #57 (permalink)
chriscar's Avatar
Which B14 writeup?
Old 02-07-2008, 12:07 AM   #58 (permalink)
24/7 Baller!
Originally Posted by chriscar View Post
I'm going to do this on a B14 probably this week, and will document it with pics. I'm using KnuKonceptz wire, the stock battery tray, and 2 circuit breakers.
That B14?
Old 02-07-2008, 12:07 AM   #59 (permalink)
ga16*****.com
edit...
Old 09-05-2008, 11:16 PM   #60 (permalink)
G204life now
Feedback Score: 3 reviews
i did this a few days ago to privide effecient space in my engine bay. i already had 4 gauge running to my bass. just cut and soldered it to the terminal i took off the battery and same. grounded out to the strutt after paint was removed. did it for 0$ mainly because i already had the 4 gauge. i had the same idea with the stock battery brackets and housing, just self tapped them into the trunk. works great!!! for solder i used some 63-47 (best, no melting point, reffer ICP-A-610 doccument ) solder with a medium flux and a blowtorch, awesome setup! no problems this far.
sentra4life is offline   Reply With Quote
HTML code is On
