Battery relocation writeup - Page 4 - SR20 Forum
Old 03-09-2009, 02:54 PM   #61 (permalink)
Feedback Score: 3 reviews
Hey chris I don't mean to revive an old stickied thread like this but you said you removed the battery terminal loop under the hood that is near the distribution block. how did you interface the distribution block with the 1/0 wire?
Breaktackle25 is offline   Reply With Quote
Old 03-09-2009, 03:01 PM   #62 (permalink)
merely a flesh wound
chriscar's Avatar
Feedback Score: 109 reviews
Per the parts list in the first post -
KNF-23 KonFUSED 3 Way Distribution System (150A,30A,30A
I wouldn't recommend using that distribution block though, I wasn't happy with the way the cables attached, and the cover didn't seat very well. On subsequent battery re locations, I've retained the original fusible links, and hooked the 3 wires which originally went to the positive terminal (on the red plastic connector) to a circuit breaker in the engine bay. This is in addition to the rear breaker.
I'll try and dig up pictures.
Old 03-09-2009, 03:06 PM   #63 (permalink)
That would be awesome thank you so much! Yeah I saw you used that block then said after using it for a while you wouldn't recommend it. I'm in the process of doing this job now and just wanted to retain as many parts as possible, which it sounds like you did on subsequent relocations.
Old 03-19-2009, 06:18 PM   #64 (permalink)
Booooooooooost
Feedback Score: 5 reviews
Is there any way you could redo the pics to make them go with what you've typed? I think you might have some pics missing or something cause I can't find them on that link.
1992 Aztec Red SE-R - Boosted.
Stock Avenir motor on 9 psi, 370s at 4 bar, N60 maf, Calum ecu
1992 White SE-R - The Daily.
JDM DE swapped
SR20? is offline   Reply With Quote
Old 03-22-2009, 12:19 PM   #65 (permalink)
slave to the grind
TOOQIKK's Avatar
Feedback Score: 33 reviews
requestin pictures to be reposted.....
94-XE 4D.... boost in the near future...stay tuned....
THE WEBSITE for all your synthetic oil and filter needs...AMSOIL First in Synthetics
Old 03-22-2009, 12:55 PM   #66 (permalink)
chriscar's Avatar
I'm away for the weekend, will try and work on it this week for you guys.
Old 03-22-2009, 06:10 PM   #67 (permalink)
slave to the grind
TOOQIKK's Avatar
thank you very much sir...we will be waitin.....
Old 04-13-2009, 10:08 PM   #68 (permalink)
im about to do this to my b13...this is kind of a stupid question but why do you need to install circuit breakers?
is so just incase it shorts out it will break the circuit before damaging anything else??
oo and i would be very greatful if anyone could post pics..thank you
91 Intregra--parted out
91 Accord--totaled
92 Sentra SE-R--eating hondas
NYs92se-r is offline   Reply With Quote
Old 04-13-2009, 10:11 PM   #69 (permalink)
www.FAIRTAX.org
paNX2K&SE-R's Avatar
Feedback Score: 93 reviews
Most people would rather just spend the $30 on a breaker or fuse than see their car burn to the ground if there ever is a major short to occur somewhere in your reroute wiring.
03.5 G35 Sport 6MT
07 Forester XT Sport 5MT
94 Miata GT28RS powered
93 LS1 240SX Family Project
Old 04-14-2009, 07:28 PM   #70 (permalink)
ok..
Old 04-14-2009, 08:31 PM   #71 (permalink)
going thru life @ 1 bar
Feedback Score: 21 reviews
pics dont work?
Old 04-14-2009, 08:55 PM   #72 (permalink)
ga16*****.com
Feedback Score: 31 reviews
edit...........
1997 200SX SE-R - 280whp & 264tq
"Shut the fu*k up and sit down"
Old 04-27-2009, 03:01 PM   #73 (permalink)
Not a Newbie
The KLM 1/0 wire on the KnuKonceptz site is Copper Clad Al (CCA)
this is given as 10% Cu and 90% Aluminum.
The area is 66.8 mm2
When you work out the Cu equivalent cross section at 20 deg C I get 44.75 mm2
This is about 1 AWG Cu wire (42.4 mm2)
So if you are comparing cost compare the 1/0 CCA with 1 AWG Cu wire.
It seems to me that 2 AWG Cu would be more than adequate, since its about 0.8 V drop at 200 Amps. ( and about $1.26 per foot from welding supply site)
1997 SE-R 5 sp yea !!!
2003 Pathfinder SE 4WD
1997 Sentra GXE Sold !!
Ex- 2001 Sunny N16 RHD (N16 Nissan Bluebird Sylphy)
Ianh is offline   Reply With Quote
Old 05-18-2009, 09:21 AM   #74 (permalink)
Hey, I was just curious what circuit breaker I should use instead of the knukonceptz one. I would like to start this project before this weekend because it's the one thing holding it up.
Old 05-18-2009, 10:06 AM   #75 (permalink)
chriscar's Avatar
KnuKonceptz didn't supply the breaker, it was their distribution block that I didn't like.
Use the link below for the breaker. Put one in the engine compartment, and one back by the battery.
http://stores.ebay.com/Xstatic-BatCap-Central
Old 05-18-2009, 11:58 AM   #76 (permalink)
Thank you so much, chriscar! Ordering now :-)
Old 07-13-2009, 10:46 AM   #77 (permalink)
Alright, last post. Can someone post 2 pictures of their underhood setup please? One of the circuit breaker with the connections to it, and one of the grounding setup as well. I am more of a visual person, and I've read this thread numerous times but it would be nice to actually see it.
Old 07-13-2009, 11:03 AM   #78 (permalink)
chriscar's Avatar
Ground - for the engine bay, you can keep the stock ground wire, which goes from the block to the chassis to the battery. To clean things up, cut off the part from the chassis to battery. Optionally, make a new ground wire and replace the stock one.
There's pictures of the ground in the rear of the car on my Picasa web gallery.
http://picasaweb.google.com/cscarpul...ry_Relocation#
I don't have any pics of the circuit breaker in the engine compartment, but basically you just want to mount it on the strut tower, and use the stock battery terminal, cut the ring portion off it, remove the bolt/nut and bolt it directly on to the circuit breaker.
Old 08-14-2009, 05:36 AM   #79 (permalink)
vengeance
Feedback Score: 7 reviews
just did this to my b14, didnt like the distribution block, it works but has a flimsy feel to it...also the connections are a little strange, the way they are just screwed into to closed terminal. Used a seperated 2 gauge jumper cable instead of the 1/0 gauge cable, was cheaper. Cars starting every time and has put up with some pretty bumpy roads on stiff suspension....will follow up with pics.
its simple, start s**t, get shot.
Taurus45acp is offline   Reply With Quote
Old 08-14-2009, 10:09 AM   #80 (permalink)
chriscar's Avatar
Yep, that's why I suggested using a circuit breaker instead.
HTML code is On
