it looks pretty cool at night. in the day time it can suck if there's light shining inside the car on the dash, you wont be able to see the display well. I just wanted to try it out, but i'm going back to the analog cluster.
__________________ Serban - EEN President/Founding Father
Was your car originaly a 1.6L with no tach? If not.....
If you can find me an online FSM for the 94 sentra I can take a look at it, the one on phatg20.net doesnt work. I am going to be doing one for the B14s as well.
[b]Now metal fabricating, welding and powder coating. PM me with your needs!
it was an ser to start out, ny freind ended up takin both fsm printouts and doing it from that, i appreciate the help. it looks awesome!
94 Aztec Red Sentra
Gtir Motor Swap with S3M Cams Love Fab Turbo Manifold
and a 3in turbo back.
Turbonetics 60-1 With a PWR Water to Air Intercooler
JWT Ecu 72lb program with Z32 MAF
Running a P11 Tranny with LSD and a JGY locking Insert
All Rolling on Drag DR20s and Ksports.
Best time of 2006 12.4 @ 111mph with a 1.87 60' only running 14psi
What about with an auto tranny? Would this be hard to do with Eggbert? Right now my analog speedo works once in a while, below 25mph. Other than that it doesnt work it just jumps and drops to nothing. I am not used to this mechanicle b13 bullsh*t...
White '92 NX2000 All Stock.
yeah it should work. what is an Eggbert, sorry if thats a stupid question.
Ok, so where do I get this instrument set? Do I have to find it at a junkyard? I think it looks way cool, but it looks like it could be a nightmare to get it working correctly in my 94 Sentra SE-R. In theory then, I would only need to get the gauge set and the pinion?
Yes junk yard or part out on this forum, you will need the cluster, clipped wiring harness and speed pinion, its not as hard as it seems.
