Old 04-17-2006, 11:00 AM   #41 (permalink)
Travieso Racing
digital.
Danny GDM (HKS)
1993 PRiMERA GT
Old 05-03-2006, 09:35 AM   #42 (permalink)
Slideways
Is it necessary to use the NX1600 connector, or could I just move the pins in my 1992 B13 SE-R Connector?
Thanks
Project Jet boat continues.......
jazzguy is offline   Reply With Quote
Old 05-03-2006, 01:20 PM   #43 (permalink)
I Keep It Unique
Trader Rating: 24 (100%)
yeah it is the connectors are alot different
[b]Now metal fabricating, welding and powder coating. PM me with your needs!
sinistersntra91 is offline   Reply With Quote
Old 05-03-2006, 01:55 PM   #44 (permalink)
Speed Junkie
I just found this thread--dumb question--this cluster is from a 93 nx1600 correct?
Dosen't the nx have a mechanical spedo cable like the 91-93 ser?
I have a 94 ser with a b15 trans--will this work for me?
Do all the warning lights and other stuff work corectly?
also I was wondering about the spedo being off--do you have larger than stock wheels? that will change the reading on the spedo--all these trucks with the big ass rims have to do something to correct the spedo---just a thought.
94 SE-R Avenir de-t w/gti-r ecu, JWT S4's,
pressure plate,&stage 1 clutch, Fidenza
flywheel,B15 transmission,444cc injectors,
avenir maf,nismo fpr,Turbo xs boost controle,
Greddy BOV,MSD 6A-----SOLD
JohnnyFriend is offline   Reply With Quote
Old 05-03-2006, 09:06 PM   #45 (permalink)
Turbo Spicy Orange
ya ur speedo will be off
Avenier 4 Life
Bonesmugglar is offline   Reply With Quote
Old 06-29-2006, 10:54 PM   #46 (permalink)
Trader Rating: 4 (83%)
91-93 nx 1.6l have all the same digital clusters,and no the 1.6l nx has a digital speed sensor,and yeah it will work with ur b15 trans, but when u go get a nx digital cluster at a junkyard also cut all the wires that hook onto the back of the cluster off of the nx and yea you can make all the lights work correct if wired correctly.
01 1.8t gti-porsche 997rims,boser,projektzwo kit=daily
92se-r mods-tsuru,stillen,volks,sparco=garage queen
06 toyota prius-wifes
92se-r-digital nx cluster/u13bbdet-S0ld
12.30se-r92 is offline   Reply With Quote
Old 06-29-2006, 10:57 PM   #47 (permalink)
I Keep It Unique
Yeah what he said^
Old 12-18-2006, 07:48 PM   #48 (permalink)
so what lights up on the tach. Is it like red bars?? Or little led's?
Old 12-18-2006, 08:40 PM   #49 (permalink)
I Keep It Unique
If you look at the picture of the cluster you will see a horse shoe shape above the speed read out, if you look down by the zero you will see a little blue bar lit up, as you accelerate the number of bars increases indicating the rpms, if that makes sense
Old 12-19-2006, 03:11 PM   #50 (permalink)
El Burro
I got a 92 b13 se-r. That came with a mechanical speed sensor, correct?
If I were to do this I'd need the digital speed sensor for a 1.6L or 2.0L?
- 02 spec V - lots of crap
- 92 g20 - winter beater/future DET beast. (sold)
- 92 se-r - daily driver
www.njtuners.com
www.highpsi.org
limp_noodle is offline   Reply With Quote
Old 12-19-2006, 03:40 PM   #51 (permalink)
Get the speedo sensor from the 1.6 NX the cluster came out of. It will be the most accurate way of doing it.
Old 04-30-2007, 10:15 AM   #52 (permalink)
Just Plain Classic
Giving an old thread new life.
Got me a 91NX 1.6, cluster this weekend, So i am the one behind the power curve here and am now wanting to try this mod. I have a 94 non SE-r with electronic cluster. I am thinking I wont have the speedo problems that some here are having because I have a 1.6. is that correct thinking?
Last summer i did the tachless to tach cluster swap, basically (with help) i just followed the tracks on the back of the cluster to get it working. to do the digi swap am I going to be doing the basically the same thing?
thanks for help, and sorry I am a year behind on this mod.........
Jake
Just Happy to be here
2008 SE-R SPEC V!!!!!
'95 Sentra, but has the B13 body style, Manufactured in Mexico for the Island of Guam. Weird VIN is untraceable in Nissan system. R*I*P
jakehale is offline   Reply With Quote
Old 04-30-2007, 12:07 PM   #53 (permalink)
My car is out of storage.
Trader Rating: 20 (100%)
is it possible to put electronic speed sensor into a tranny that originally had a mechanical one with speedo cable?
Looking for peace of mind
Old 04-30-2007, 08:13 PM   #54 (permalink)
I Keep It Unique
Jake
It will work the way you plan for every plug except for the small center one. There is no indication of where all those wires connect to on the back of the cluster. Use my diagram to figure it out. As far as the speedo, you still have a chance for problems. Its best to use the one that went with the digi cluster.
Brennan
Old 04-30-2007, 08:14 PM   #55 (permalink)
I Keep It Unique
Yeah there is another write up for the analog to digital cluster in the technical information library find the link thats title analog to digital it will show you what to do.
Brennan
Old 04-30-2007, 09:05 PM   #56 (permalink)
Just Plain Classic
Brennan
Thanks, I know wire colors are different from year to year, model to model, ran into that issue when I did my Tach cluster swap. As far as the diagram goes, just two questions for right now (if you dont mind) . what is the orientation of the plugs in the diagram (looking down/up, which is top)? A couple of them have the same amount of connectors on them so it doesnt make it "as easy" to figure out what is top and bottom on the actual plug, the ones like 6 plugs one end 4 the other are simple to figure out. And the other question. Coming out of the small connector on the digi, it appears to be a splice? its the orange wire on the diagram. or does it go just from one plug to the other? I do see that the yellow wire is spliced noticed that when on the old connectors i started to remove all the tape.
thanks for the help
On more question.
I havent opend this thing up yet. Do you know if I can swap out the milage with my current cluster. or are the dials easy to set? my last swap i just swapped the whole speedo guage set into the new cluster to keep the milage correct.
and another
Trying to get the wire's out, I know how to open the other connecters to remove the pins, how in the heck do you open the small black connector? that on is eluding me a tad bit.
thanks again
Last edited by jakehale : 05-01-2007 at 07:30 PM. Reason: just a plethera more questions.
Old 04-30-2007, 10:55 PM   #57 (permalink)
slave to the grind
TOOQIKK's Avatar
Trader Rating: 28 (100%)
okay i have a manual digital dash and a manual electronic speed sensor from a 1.6 but my speedometer reads half of what my actual speed is ..i have a jdm sr20 swap in the car with a 93 nx2k wiring harness(brennan i know you know my set up you helped wire up the dash and helped with the swap)..how do i fix this??
1991 xe....dead(boneyard)
1994 e.....dead(parted out)
2007 hyundai accent DD for now
1987 pulsar se AWD-T
www.lubedealer.com/dkinney
for all your amsoil synthetic oils and filters
also sell ngk , mother, wix, and other products!
Old 05-01-2007, 07:30 PM   #58 (permalink)
Just Plain Classic
still looking, basically just for the plug orientation. whats top/bottom, left/right?
Old 05-05-2007, 09:23 PM   #59 (permalink)
Just Plain Classic
Let me just say, started this morning and am still working on it and have quit for the night. Not going well. Seat belts dont work, turn signals dont work, and a slew of other misc lights and the funny one is, the clock works if the door is closed, open the door and the clock goes out. haha. however the tach works and the speedo is working, not sure how acurate it is, just drove around the block!,, always a plus in there someplace. Is there a light for the milage/odometer?
Hopefully tomorrow will find me fixing the misc lights.
Old 05-11-2007, 11:08 PM   #60 (permalink)
Just Plain Classic
JUST SO YOU KNOW
The speed pinion from a 91 NX1600 WILL NOT fit into a 94 Sentra... Tried the swap today and it will not physically fit into the transmission. Did I do something wrong? Does someone know something different than I? Please let me know?
Thanks
Jake
