Old 05-12-2007, 05:00 AM   #61 (permalink)
WHAT TYPE OF PULSE DOES THE SPEED SENSOR EMIT? sorry so loud...
mild2wild is offline   Reply With Quote
Old 05-12-2007, 09:05 AM   #62 (permalink)
Just Plain Classic
I have no idea,,, I was just following the thread and trying to do what had worked for others. I guess the tranny that is on the 2.0 is different that the tranny on the 1.6 (oviously) because there is no way that speed sensor will fit on my car.
Just Happy to be here
2008 SE-R SPEC V!!!!!
'95 Sentra, but has the B13 body style, Manufactured in Mexico for the Island of Guam. Weird VIN is untraceable in Nissan system. R*I*P
jakehale is offline   Reply With Quote
Old 05-12-2007, 02:01 PM   #63 (permalink)
I Keep It Unique
Trader Rating: 24 (100%)
It should work.....I have swapped speed sensors between a 1.6L and a 2.0 before...
[b]Now metal fabricating, welding and powder coating. PM me with your needs!
sinistersntra91 is offline   Reply With Quote
Old 05-12-2007, 02:58 PM   #64 (permalink)
Just Plain Classic
This is/are the pinions.
http://www.photodump.com/viewer/jakehale/100_0365.html
the blue longer one is from the NX and the short white geared one is from my 1.6
Old 05-13-2007, 02:50 PM   #65 (permalink)
I Keep It Unique
ok I think your problem is your trying to use a speed pinion from a 91 manual NX1600 into your 94 auto sentra transmission, I think you need to get a pinion from a 93 manual NX 1600 or you could also try using one from a 93-94 sentra with a manual transmission. But a 93 NX 1600 manual is your best bet.
Old 05-13-2007, 11:37 PM   #66 (permalink)
Just Plain Classic
Thanks, will be on the look out for one of those. NX's are hard to come by at the yard. but at least I have something specific to look for.
thanks for the help
Old 05-14-2007, 10:00 AM   #67 (permalink)
slave to the grind
TOOQIKK's Avatar
Trader Rating: 28 (100%)
brenan what about my speedo reading half of what my actual speed is??
1991 xe....dead(boneyard)
1994 e.....dead(parted out)
2007 hyundai accent DD for now
1987 pulsar se AWD-T
www.lubedealer.com/dkinney
for all your amsoil synthetic oils and filters
also sell ngk , mother, wix, and other products!
Old 05-14-2007, 05:01 PM   #68 (permalink)
Just Plain Classic
I might be jumping in here, TooQuikk,, but that is exactly what mine was doing. My digi was ready 30 and I was going at least 60. I did the pinion swap (pic's of the pinion above) and his recomendation followed.
Old 05-26-2007, 12:46 AM   #69 (permalink)
JDM WHORE TWIN
93sr20's Avatar
Trader Rating: 18 (100%)
how long did it take?
w10
http://picsandflicks.do-goo.net/index.htm
post anything you want
se-r commercial
http://www.youtube.com/watch?v=lgKti...ndid%3D2568109
93sr20 is offline   Reply With Quote
Old 06-26-2007, 06:50 PM   #70 (permalink)
subscribed
1992 Nissan NX/
1995 Ford Mustang GT/2002 Nissan Sentra SE-R
mrsidewayzz is offline   Reply With Quote
Old 07-06-2007, 10:06 PM   #71 (permalink)
i just got my digidash and that diagram scares the hell out of me. any tips to make it easier?
Old 07-09-2007, 12:42 PM   #72 (permalink)
Just Plain Classic
just take your time. what i did was mark all the wires and made a diagram of what I HAD..... then went through the digram here pre marking everything (yes I had allot of tape up in there) but it worked for me, not to mention when the digi didnt work like i wanted it to (my half speed problem) the diagram of what I had make it cake work to get it back to the way it was so I could get my car back out on the road. Quickley
Old 07-09-2007, 10:00 PM   #73 (permalink)
where in the hell can i find those stupid connectors?? i found a 12 pin but i cant find a 15 pin!!!
Old 07-10-2007, 08:25 AM   #74 (permalink)
Just Plain Classic
I used the one's from the cluster. I got mine from the JY so when i got it I took the connectors also. Now,,, what I also did (forgot to mention) for the mini plug, i did some splicing for those (i think) 12 wires. Know what i mean? those wires that go into the mini plug i spliced a wire into it and then ran that wire to the mini plug leaving the other wire still there so i could go back, as for the other plugs those were just a matter of poping the pins out like any other nissan plug and putting them into the NX plugs so they would fit into the digi cluster. Dont think it is pretty behind my cluster, It is ugly!! but all worked and it is safe. Now i am wishing I took a picture or two.
Old 07-10-2007, 06:35 PM   #75 (permalink)
i cant find a damn 15 pin interlocking connector. im getting upset. can i just use another 12 pin and like a 4 pin or something?
Old 07-10-2007, 07:12 PM   #76 (permalink)
1.6 3/25/06 VE 7/11/06
Trader Rating: 25 (100%)
anyone do this to their b14 yet? i know its out there just got to find the knowledge
my signature got ruined by advertisements and sell outs so i had to change it.
sr20(-)forum.com
bj200sx is offline   Reply With Quote
Old 07-11-2007, 09:17 AM   #77 (permalink)
Just Plain Classic
As long as your wires meet up and is able to plug into the cluster I would think any type of plug will work. You do have the connectors for the digi right? the ones that go to the back of that cluster? what ever you use inthe middle doesnt really matter as long as your wires meet.
Old 07-12-2007, 01:29 AM   #78 (permalink)
ok cool. now, i went and took out my speedometer and i had no idea there was a cable connected to the back of the speedo. now the sh*t doesnt work. lol. so all i have to do is take the plugs off the analog cluster, cut and splice with the digi cluster wires?
Old 07-12-2007, 02:18 AM   #79 (permalink)
SR90VETT
anyway to digi b14?
Originally Posted by Fragranttuna View Post
lol u blew up a tranny, so what do i all need to get a turbo in my car and up and running, about how long to install it? eyah how do i get to the classifieds, i think i was there once, but it didnt have a lot of turbo stuff there, and then i couldnt find the place to puchase the turbo kit i did see.
CLASSIC!!! HAHAHA
brackinassryan is offline   Reply With Quote
Old 07-12-2007, 02:21 AM   #80 (permalink)
its possible. i saw a b14 with the digi cluster.
HTML code is On
