Old 04-22-2006, 11:10 PM   #61 (permalink)
www.FAIRTAX.org
paNX2K&SE-R's Avatar
Trader Rating: 66 (100%)
You can also use the rear calipers from the P10 and the 1st Gen Altima, they are the same as the 93-94 Max SE.
91 SE-R w/DET
02 G20 Sport 5spd
94 Miata "homobile"
93 240SX Family Project
Old 05-08-2006, 09:01 PM   #62 (permalink)
El Rey de los Chingones
Isfahan's Avatar
I just got done with my mostly successful Maxima rear brake install. OK, the maxima part went great, it was the altima part that wasn't a hit. The Maxima rear brakes and JDM NX rotors bolted up without any hitch (Thanks Andreas!), we didn't even need to fiddle with the e-brake bracket. Here are a couple of pics:
Before:
http://i40.photobucket.com/albums/e2...tice/Side1.jpg
After:
http://i40.photobucket.com/albums/e2...tice/Side2.jpg
Before:
http://i40.photobucket.com/albums/e2...ice/Close1.jpg
After:
http://i40.photobucket.com/albums/e2...ice/Close3.jpg
Now the problem. The Altima ABS M/C I got from Nopi has holes for the PV's that are WAY too small for my stock M/C PV's, despite the fact that they are from the same manufacturer. Anybody else have this problem, or am I the only ABS fool trying this? Any solutions? Should I run Altima PV's? Also, one of the holes for the PV is directly on the side of the M/C, which makes us doubt that there will be enough room between the M/C and the strut tower for the PV & brake line to fit. Are all Altima M/C's like this? Here are a couple of pic's:
New M/C:
http://i40.photobucket.com/albums/e204/nenstice/MC1.jpg
Stock M/C:
http://i40.photobucket.com/albums/e204/nenstice/MC3.jpg
So I'm running the stock M/C for now. I have to press quite a ways for full engagement on the brakes, but it's not too bad. Not sure if it's going down so far as to screw up heel/toeing. I cannot wait to try them on the track. Any answers to the Altima M/C Q's would be greatly appreciated.
WE are a community
Isfahan is offline   Reply With Quote
Old 05-08-2006, 09:12 PM   #63 (permalink)
technics professional
Avshi750's Avatar
Trader Rating: 35 (100%)
the MC you got is for an ABS equiped car.
it does not look like your oem MC is for ABS.
Avshi750 is offline   Reply With Quote
Old 05-08-2006, 10:03 PM   #64 (permalink)
Isfahan's Avatar
My car is ABS. The pic I have of it isn't that great, but there are only two lines coming out of the stock M/C.
Old 05-08-2006, 10:20 PM   #65 (permalink)
Avshi750's Avatar
hmm the placement of the stock PVs compared to the Alitima one threw me off.
i would call GregV (or your local dealership if you know they are not just monkeys and could help you) and check to see what the parts situation is. i remember someone's thread that used an Altima tokico MC (non-ABS i think) and had to swap SE-R PVs. that might only work for non-ABS cars
Old 05-09-2006, 10:30 AM   #66 (permalink)
'93 drifting Egg
I think you got the wrong year MC or even the wrong car application MC. You need to recheck the place you got it from. Better if you try Napa, AutoZone, or the Dealership, where you can see the "REAL" pic, not some generic pic Nopi uses for everything. It also doesn't look like the same brand (Tociko/Nabco) from the pics. And if it is different brand from the one on your car, you got to get the matching brand PV as there threads are different between the two.
See the first page of my write up just under the pics it will list MC sizes and PVs. Also note that my MC even though it is different brands, the ports are all in the same spot. Thats why you a need a real pic of the MC you are trying to get.
1982 Toyota Starlet with Starion turbo swap STOLEN!!
1986 300ZX Turbo with 87k miles
1991 Nissan Tsuru GSR2000 with UK SR20DE IT'S BACK!!!!
1992 Eclipse GS-X 325 hp SOLD
1993 NX2000 SOLD!
NissanEgg is offline   Reply With Quote
Old 05-09-2006, 12:03 PM   #67 (permalink)
Isfahan's Avatar
Yeah, I'm going to have to do some research on this stuff. Both M/C's are the same brands, but obviously I need to do some more background checking. I'll update when I have news.
Old 05-09-2006, 12:33 PM   #68 (permalink)
broke, busted and rusted
where can you buy the different proportioning valves?
Fonque is offline   Reply With Quote
Old 05-09-2006, 03:53 PM   #69 (permalink)
SR20 Racer/Tuner,Gamer
I think im gonna do this conversion and the welwood 11 inch 4 pistons too great job thanks a lot it really helps
-->NX2000 91(race car)
-Taylor 10.4mm wires (Thanks XxToKeSxX )
-Cusco strut bar-K-sport coil-over-Whiteline LCA
-Toyo RA1 and Hankook Z2000 -SSAC header 2.5
-Custom CAI -Custom 2.5 inch exh. mandrell bend+Magnaflow 2.75
NX 2.0 is offline   Reply With Quote
Old 05-09-2006, 05:50 PM   #70 (permalink)
'93 drifting Egg
They are Dealership only parts. Better to find them on junkyard cars.
Old 09-01-2006, 12:07 PM   #71 (permalink)
Isfahan's Avatar
Originally Posted by DontaviousB13
Anybody think that if one were on a ghetto budget they could swap in the maxima 5 lug hubs and use the maxima rotors, thus you wouldnt need to get a couple of jdm rotors of have other redrilled?? I know the rear hubs will swap from 5x114.3 maxima to 4x4.5 altima.
Search around on the forum and you'll find links to places (rock auto or something like that) where you can get the standard rotors cheap. This rotor size is available at a lot of places (including napa, if I recall correctly), you just have to know what to ask for. Nevermind, I just found the post you should check out:
http://www.sr20forum.com/technical-information-library/142750-maxima-altima-brakes-b13s.html
Edit: Hum.. as I posted my reply his post disappeared. Weird. At least I have it quoted to prove I'm not going insane.
Old 05-04-2007, 04:22 AM   #72 (permalink)
Big Dreams, Small Budget
Some of this is making my head reel. I went to a junkyard today, grabbed an M/C from a 95 Max, along with both calipers/pads. However, rotors were five lug. Do I need to just return all of it and look for a 91-94 max with 4 line m/c and calipers/rotors? As for the front Fastbrakes conversion, I've searched around for parts using NX2000 as search vehicle, and haven't found anything even close to that size. Where would I find 11.75" rotors, and the calipers to fit them? I would like to get my conversion done soon. I have my SS lines and rear (95 max) calipers, and my brakes need to be bled anyway, so I might as well do the front and rear conversion all at once. Please help me out if you can, perhaps with a specific parts list that I could use?
1991 B13 SE-R JDM SR20
The little red bastard - handling and traction 1st, speed 2nd.
The good drivers are the ones that understand they may not be the best out there, but know what to do to get there.
chronic_werewol is offline   Reply With Quote
Old 05-04-2007, 05:35 AM   #73 (permalink)
Ruby Red SE-R
Nice setup. Any pics of it on the car with the wheels on?????
Once you go turbo you'll never go back!!!
1993 Ruby Red SE-R SR20DE+T RIP junked 3/06
1995 Infiniti G20
1994 Aztec Red SE-R W10DET powered
Originally Posted by capecodbuysell View Post
whats a 2 step and how does it build boost at the line
Originally Posted by GateCrasher_VI View Post
anyone have a spare muffler bearing or two? 'reason to suspect thats where my coffee can sound is coming from
scrildo is offline   Reply With Quote
Old 05-04-2007, 02:37 PM   #74 (permalink)
'93 drifting Egg
Chronic...you need to get just the rear calipers from the Maxima and ebrake bracket on the caliper too. The rear rotors will not work without having to redrill them. It is easier and better to get brand new rotors from Greg at Mossy Performance, and the fit correctly. As for the Wilwood's any brake kit they have for the B13/14 fronts will work.
Scrildo...
Old 05-04-2007, 02:58 PM   #75 (permalink)
merely a flesh wound
chriscar's Avatar
Chronic - for the larger rear rotors, try local parts houses. What you want is the 258mm rear solid rotor. Search the forum for 258mm and you'll get a ton of hits.
Old 05-14-2007, 10:22 AM   #76 (permalink)
slave to the grind
TOOQIKK's Avatar
Trader Rating: 28 (100%)
i can get them from a local wholesaler....mine were 13 bucks a piece!! for the rotors!!!hehe
got one question will the stock nx2k m/c work with this conversion? i have a 91 E and already have the nx front brakes and have the rear brakes setting in the garge gonna put on soon and s/s brakelines...what will my pedal feel like after the swap?with the stock nx2k m/c on it?
1991 xe....dead(boneyard)
1994 e.....dead(parted out)
2007 hyundai accent DD for now
1987 pulsar se AWD-T
www.lubedealer.com/dkinney
for all your amsoil synthetic oils and filters
also sell ngk , mother, wix, and other products!
Old 05-15-2007, 05:49 PM   #77 (permalink)
'93 drifting Egg
^^^Yes, as long as the brake lines match to the locale of the m/c outputs. Look at the first page of this thread just under the pics. You will see that the base model B13's have smaller m/c and use drums. Plus the brake pressures would be too high for the rear if you kept the stock E m/c. The pedal should feel as normal as a NX for your E B13 if you have discs all around using the NX m/c.
Old 05-15-2007, 10:57 PM   #78 (permalink)
slave to the grind
TOOQIKK's Avatar
yeah i have the nx brakes up front and the drums in the back and the E m/c and the brakes suck!....lol....
thats what i was hopin a near stock feel....might look into the altima m/c later on.....see how this works first especailly since i got everything so darn cheap!...lol
Old 06-18-2007, 01:15 AM   #79 (permalink)
Drive it like ya stole it
SENTRASER's Avatar
Trader Rating: 33 (100%)
So if I got the 90-92 calipers can I just swap out the ebrake bracket to fit my cables, the 93-4?
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by chriscar
Old 06-18-2007, 04:02 PM   #80 (permalink)
'93 drifting Egg
Yes, if you use the brakets from the Maxima. The B13 brakets are nothing close to what the Maxima brakets look like.
