Old 04-04-2006, 12:44 PM   #81 (permalink)
XxToKeSxX's Avatar
Table Of Contents/Index:
Page 1: General Info on Everything I Could Think Of | Props from SR20 Forum
Page 2: Compression Theory | Physical Differences B/N Regular DE | Efficiency | Power
Page 3: Comp. Theory Cont. | OEM vs. Tubular Header | Which ECU? | Water Pump? | USDM IM w/ RR VC | Engine Break Down
Page 4: Dyno Testimony | Reg. DE & RR DE VC Compat. | Water Pump Compat. | Power Curve Diff. | Pulleys | Boost Capability
Page 5: ECU Tuning & Ign. Timing | 4CW Crank VS. 8CW Crank | Swap Complete | PCV Schematic - USDM IM | 96-99 Almera GTI
What Does That Mean?:
IM = Intake Manifold
VC = Valve Cover
RR = Roller Rocker
CW = Counterweight
B/N = Between
Compat. = Compatibility
Diff. = Difference
Ign. = Ignition
Comp. = Compression
16!?!! wow... thats crazy.
How did you get a JWT ecu to work w/ the RR? I must be mistaken but, I didn't know they could crack the code for a RR engine. Can you elaborate what restrictions/programs you had them change. And lastly, is this their ECU or your reprogrammed ECU.
Damn, 16 psi, I wonder what your numbers are...
1998 200sx SE-R | SR20DE
1991 NX-TuRBO | SR20DET
1995 240sx BaSe | ____DET
Shift_Buy Broken & Build...
Old 04-04-2006, 12:51 PM   #82 (permalink)
From Miami to New York
Impossible, im sure he has the older intake manifold or wired in a different harness (PITA)
Miss it
http://www.g20.net/gallery/data/500/medium/425Lip3.JPG
2007 Infiniti M35 Sport
Stuff for sale
MSD red wires $55 shipped, RRSR20 New 50lb Top Feed Inj $250, B13 93' MT ECU $70.00shipped
Domiken is offline   Reply With Quote
Old 04-04-2006, 01:19 PM   #83 (permalink)
Just another RollerRocker
I called JWT and told them to program for the following:
  • Z32 maf
  • 5 speed
  • 50lb injectors
  • 10 to 1 compression
  • turbo application (any turbo)
  • asked to program on their 96 ecu as I need an OBDII so I can send mine later
I did not told them it is an RR. I didn't believe they needed to know that and to my surprise they never asked what motor either. I told Ben @JWT that the motor is something other than 96 but not what type.
After installing the new ecu, I had hesitation all over. I bought new plugs, gapped them at 0.30 (same as an mr2 turbo), bought new distributor rotor, distributor wires for a 96 200sx se-r from Advanced auto parts.
So far, no problems, no hesistation, no detonation and no cold start issues.
During the whole setup, I had some serious help from a buddy of mine who is an electronics/motor guru (the word guru was used for lack of a better word!).
EDIT: Yes, the harness is an OBDII from 95 up. Same with the intake manifold
EDIT: My timing is set at 15 degrees
Just another RR
CraigS is offline   Reply With Quote
Old 04-04-2006, 01:27 PM   #84 (permalink)
Here is an older unclean embarassing picture. Before I switched to a proper z32 plug (maf is in the pic), stock boost guage return line from the actuator and distributor wires.
Old 04-07-2006, 01:31 AM   #85 (permalink)
XxToKeSxX's Avatar
4CW Crank (RR's have this) vs. 8CW Crank
http://sr20forum.com/showthread.php?t=149488
The above is a debate on which is a "better" designed crank. From reading it there are different views upon the benefit of each case. Coming from an engineering standpoint: Less rotational weight obviously means there is less energy required to rotate the mass, which results in an easier ability to rev. I really don't think that this is a main issue for N/A vehicles that are used for daily driving application, but for cars under heavy use, and high RPM (racing for long periods of time), the issue relies on the durability factor. The discussion is very interesting and their seem to be a lot of educated views upon each side.
This doesn't affect my car, I will not be using my car for racing or anything of the sort. I also will not be turboing this vehicle.
Old 04-08-2006, 10:18 PM   #86 (permalink)
XxToKeSxX's Avatar
My swap is about done, check it out here:
http://sr20forum.com/showthread.php?t=149108
Have a few things to work out, everything is fine as of now...
Old 04-13-2006, 08:37 AM   #87 (permalink)
Project All High School!!
I started working on my VC yesterday. *** gonna paint it silver for now
White 91 SE-RR
My Car My Space
Nismo_34 is offline   Reply With Quote
Old 04-17-2006, 02:30 PM   #88 (permalink)
XxToKeSxX's Avatar
Here is my Schematic for fitting the RR Valve Cover w/ the 98 Intake Manifold.
Old 04-17-2006, 02:36 PM   #89 (permalink)
Weekend Warrior
MR-4Door-SR20DE's Avatar
Trader Rating: 34 (100%)
Nice section VIEW of the PCV tubing the leaders are actually right on point. Who did this in AutoCAD for you? what version is it? I work in "06"
BEND BUT DON'T BREAK
93 SE-R
Project-4Door-B13 "Building it one paycheck at a time"
FB1 - FB2 - SR20 storage building part-out LINK
MR-4Door-SR20DE is offline   Reply With Quote
Old 04-17-2006, 02:47 PM   #90 (permalink)
XxToKeSxX's Avatar
Are you serious! I did it myself! Nothing too technical, just so people can understand the design. I work in 05/06 at work, but since I'm in school I'm only working in 04. I have a friend who has a copy of 04 Land Desktop as well.
Old 04-17-2006, 03:07 PM   #91 (permalink)
Weekend Warrior
AutoCAD////
I have a copy of "06"
Old 04-17-2006, 09:58 PM   #92 (permalink)
XxToKeSxX's Avatar
Went outside to take some measurements and came up with this! I think its pretty close to the scematic. I hope that it holds up, I will keep it in my room until the Valve Cover is painted. When I switch the Valve Cover over is when I'll do the first oil change (250-275 miles) after the swap... Here you go...
Peace,
Old 04-27-2006, 09:28 AM   #93 (permalink)
XxToKeSxX's Avatar
I think that my motor came from a late 90's n15 Nissan Almera (Gti) I have a hunch, there is no way that my motor could have come from 00-01 because of the engine code 1st page. It may have still come from a Primera, but I now have two suspects This is interesting... I will look more into it. But here is a pic of an N15 Gti Engine Bay to compare... Interesting...
Here is my current bay, post JDM RR Swap (w/ USDM IM Swapped)
Here is n15Gti's Non-Stock Almera GTI Bay... I hope he doesn't mind me using this for comparison, but they come with RR's as well... They are mainly in the UK, but I believe they are just called Pulsar's in Japan, I'm not sure if my engine is from Japan or UK? Who knows?
Here is what the JDM looked like Before Removing the JDM IM, similar to P11, and Almera GTI
Old 04-27-2006, 10:10 AM   #94 (permalink)
The P11 GT Primera also has that tapered intake.
UK-SRi is offline   Reply With Quote
Old 04-27-2006, 10:17 AM   #95 (permalink)
XxToKeSxX's Avatar
Yeah, I thought that was the only path from where this motor came from... I thought for sure it came from a P11, but I didn't know the Almera had it as well.
I want to find out for sure somehow... I need to check peoples engine codes... I need more people to sign the roller rocker roll call to find out.
Old 04-27-2006, 05:02 PM   #96 (permalink)
Also known as LOEK
Here is n15Gti's Stock Almera GTI Bay... I hope he doesn't mind me using this for comparison
That Almera is not stock: CAI, header, even S-AFC.
Primera 01 Wagon EUDM CVT DV9 2,25' SS Advanti AEM Autometer Bride Carbing CS-BABK Eibach ES Flexalite Greddy HKS K&N Koni-Sport Magnaflow Momo NGK Nismo Nissport Optima-Red PIAA Progress Raptor Remus Sachs 'SARD' Sparco SSAC Stillen Taylor Toyo Vibrant Walbro Wilwood
P11-144 is offline   Reply With Quote
Old 04-27-2006, 06:00 PM   #97 (permalink)
XxToKeSxX's Avatar
The The Almera GTI comes with a roller rocker, thats what I'm talking about...
I'm not talking about the Mods, I'm speaking of the Engine... What do you mean?
EDIT: Oh I see... I meant the GTI came with a RR engine stock, I'll correct that...I type too fast... Good Eye, Thanks!
Old 04-27-2006, 07:00 PM   #98 (permalink)
Would still use thr regular sr20 VC if u hadn't painted the RR VC and out it on??
Old 04-27-2006, 07:03 PM   #99 (permalink)
XxToKeSxX's Avatar
I guess it really depends are you trying to purchase it?
BTW, mad spelling errors... Not sure what your asking, PM me
Old 04-28-2006, 05:40 AM   #100 (permalink)
SR20 Freak
The Almera GTi (N15 GTi) came withe the roller rocker SR20 in 1996.
It`s produced from 1996 till 1999. It has the same engine as the P11 GT but the only difference is the country of manufacturing. The P11 GT engine has a UK stamp behind the distributor and de Almera engine hasn`t.
My engine is slightly tuned:
SSAC Header
PR CAI with K&N RX-3900 filter
Unorthodox Racing 2pc. Pulley Kit
2.25" Catback
Catalyser removed
Timing @ 17
Denso Irriudium Spark Plugs
Mobil 1 5W-30 oil
No S-AFC or other managment device.
Without the catback and pulley-kit it had 180.3BHP.
1996 Almera N15 GTi
N15GTI is offline   Reply With Quote
