MAF Size, Part #s And WHP Output - Page 3 - SR20 Forum
Old 08-26-2006, 01:05 AM   #41 (permalink)
Sigfod's Avatar
Feedback Score: 3 reviews
Originally Posted by venom2727
thanks for the info ...helpful
Very helpful, that is why I love this forum!
96 SE-R Totaled in '99
2000 Sentra SE w/ GTi-R 2.0T
2011 X5 xDrive35i Sport Activity
2006 Cadillac CTS-V
Sigfod is offline   Reply With Quote
Old 09-10-2006, 02:20 AM   #42 (permalink)
High comp lowport
silvia1320's Avatar
Feedback Score: 19 reviews
is there any specific years for the cobra maf? is it just the 95-98, 99-03 or any cobra maf?
1997 200SX SE-R
1991 B13 SE-R Partout
silvia1320 is offline   Reply With Quote
Old 09-16-2006, 01:54 AM   #43 (permalink)
laisla's Avatar
Feedback Score: 6 reviews
i thougt the cobra maf supported more power.
laisla is offline   Reply With Quote
Old 09-16-2006, 05:27 PM   #44 (permalink)
High comp lowport
silvia1320's Avatar
anyone know what cobra maf is the correct one? there is something like 4 generations of cobra cars and im not exactly sure on which one i need.
Old 10-02-2006, 07:45 AM   #45 (permalink)
Jah Rastafari
Feedback Score: 61 reviews
Cobra, part # F1SZ-12B579-A has been put on the list.
Old 10-02-2006, 08:50 AM   #46 (permalink)
Sigfod's Avatar
How exactly do you Bore out a Pulsar GTi-R MAF?
Old 10-04-2006, 12:14 PM   #47 (permalink)
Done.
Feedback Score: 27 reviews
I'm guessing you don't have a machine shop, so you would need to take it to one. Boring out basically means they are shaving or machining the inside of the MAF to a larger dimension.
Cliff is offline   Reply With Quote
Old 10-12-2006, 09:58 PM   #48 (permalink)
banned
lifein10sec's Avatar
what about a N60 maf? how much are they good for?
lifein10sec is offline   Reply With Quote
Old 10-13-2006, 08:50 AM   #49 (permalink)
Sigfod's Avatar
I know that it is just I dind't realize that the GTi-R maf is made of metal, and I guess a 2-peice MAF. My last two SRs had plastic MAFs.
Well I have two options. I have a GTi-R in my 2000 Sentra SE. So I have a GTi-R MAF and a Sentra SE MAF. So I don't know what route to go. I think I am going to say f'it and get a Z32 MAF w/ a Greddy e-Manage Ultimate, and 555 injectors, or MSDs and a fuel rail.
Old 10-27-2006, 07:42 PM   #50 (permalink)
Feedback Score: 7 reviews
Andreas wrote:
91-94 Pulsar GTIR, part # 54C00
50mm 290 WHP-----------Bored 54mm 345 WHP
Ben @ JWT says:
The bored GTi-R MAF is only good for 280 WHP. It doesn't read any more air than an SE-R MAF.
Dan Asks:
Who is wrong? I assume it's probably Ben.
1993 NX2000 - D2s., ES Bushings, SSAC header, Hotshot CAI, VRS Exhaust, lots o' chassis braces.
1999 Infiniti G20T BB SR20DET
FMIC, Blitz BOV, 3" Exhaust, JIC SA-1 Coilovers. GTi-R manifold/T28, 3" DP, 3000 lbs. of entry-level luxury
SE-R_Dan is offline   Reply With Quote
Old 10-27-2006, 09:10 PM   #51 (permalink)
Sigfod's Avatar
I have a GTi-R going into a 2000 Sentra SE. Do I have to reprogram the ECU to use the SE (RR SR20) MAF? Or will it work?
Old 10-31-2006, 01:03 AM   #52 (permalink)
The Calibrator
I have a simple solution chuck the MAF out and use a MAP. Of course this only works with stand alone systems.
Then only the throttle body is the restriction
tunerguy is offline   Reply With Quote
Old 10-31-2006, 08:42 AM   #53 (permalink)
Sigfod's Avatar
The closest I am going to get to that is a GReddy E-Manage Ultimate.
Old 01-20-2007, 03:11 PM   #54 (permalink)
allmotorKA24DE
thinnertenor's Avatar
i dont see any listing of the U12/U13 (Bluebird, i think) motors.....
are they just the same as the Avenirs?
thats what i would assume, just double checking
B.J. Walker
1993 Aztec Red NX2000
1993 White 240sx Hatchback
thinnertenor is offline   Reply With Quote
Old 02-13-2007, 12:31 AM   #55 (permalink)
SR20 owner since 93
I have a 1993 Cobra MAF, 70mm part number F1SF-12B579-AA, How much HP can this MAF handle??
1996 Nissan 200sx SE-R ---->DD
1991 Nissan Sentra SE-R---> ALL MOST DONE
I DON'T DESERVE THAT 1 NEGATIVE FEEDBACK I SHOULD HAVE A 100% FEEDBACK RATE
8pinoy8 is offline   Reply With Quote
Old 03-02-2007, 08:26 AM   #56 (permalink)
54C
GTIR AFM Clarification
Hi Everyone, Just joined. Been driving/racing a GTIR for 4 years.
The GTIR airflow-meter is not 50mm. Aperture is 36mm. The connections may be 50mm, but it narrows down inside. This is because the hotwire is out of the path of the main aperture. It samples the flow rate through a small hole on the side. This is very different to the Z32 style where the hotwire projects into the centre of the airflow path.
Also, the GTIR AFM is made of aluminium alloy, not plastic - as mentioned back up in this thread.
Good forum. I have never seen log manifolds like that for turbo applications.
peter
pschurr is offline   Reply With Quote
Old 03-02-2007, 08:37 AM   #57 (permalink)
Jah Rastafari
Do you know how small 36mm is. That is 1.45 inches or so. A factory GTIR MAF inner bore is 50mm.
We also know it is made out of aluminum otherwize how are you going to bore it out to 54mm.
I have been boring SER and GTIR MAFs for the past 12 years so I know what the inner bore of these MAFs are.
Old 03-02-2007, 09:14 AM   #58 (permalink)
Sigfod's Avatar
What modifications need to be done to fit a B15 SR20DE MAF to a GTi-R motor? I still have my stock MAF leftover from before the swap.
Old 03-02-2007, 02:44 PM   #59 (permalink)
They're just cones!
Do all Nissan MAFs have the same plug on them or would you need a pigtail / rewire for each one?
Driven97 is offline   Reply With Quote
Old 03-02-2007, 04:19 PM   #60 (permalink)
Sigfod's Avatar
That's what I want to know!
HTML code is On
