MAF Size, Part #s And WHP Output - Page 4 - SR20 Forum
Old 03-02-2007, 06:50 PM   #61 (permalink)
KASSANOVA!!!
Feedback Score: 47 reviews
Originally Posted by Sigfod View Post
That's what I want to know!
most, if not all nissan maf's have a different plug that needs to be rewired into the stock harness plug...
92 Dark Gray Sentra SER
92 Red Sentra SER
Old 03-23-2007, 03:46 AM   #62 (permalink)
Endless Turbo Preparation
Feedback Score: 6 reviews
How is it the Avenir and GTIR MAFs can hold more hp over the SER cars being that they are both 50mm? Also would the MAF come w/an Avenir/GTIR engine if you were doing a swap?
'95 200sx SER - W10+GT2871R_15psi+S4.exe loaded successfully! (Daily Driven )
Member of the 1st Temporalist Church of KC -Zip Tie Ritual temporarily each Sunday.
“He who asks a question is a fool for five minutes; he who does not ask a question remains a fool forever” - Chinese Proverb
gomba is offline   Reply With Quote
Old 03-23-2007, 08:24 AM   #63 (permalink)
Jah Rastafari
Feedback Score: 61 reviews
The hole size of the MAF has nothing to do with it.
The sensor for the GTIR and Aveneir have a larger voltage span than the SER ones.
Old 03-23-2007, 11:31 AM   #64 (permalink)
Feedback Score: 7 reviews
So do the GTIR and Avenir actually run above 5 volts, or is there just a "wider range" (for lack of a better term) between 0 and 5v?
1993 NX2000 - D2s., ES Bushings, SSAC header, Hotshot CAI, VRS Exhaust, lots o' chassis braces.
1999 Infiniti G20T BB SR20DET
FMIC, Blitz BOV, 3" Exhaust, JIC SA-1 Coilovers. GTi-R manifold/T28, 3" DP, 3000 lbs. of entry-level luxury
SE-R_Dan is offline   Reply With Quote
Old 03-24-2007, 09:27 AM   #65 (permalink)
Sigfod's Avatar
Feedback Score: 3 reviews
I really want to know if the B15 RR SR20DE MAF is swappable for the GTi-R SR20DET MAF. I read somewhere that they both use the same setting number of 5 on a GReddy e-Manage, does this mean that I can just pull out the GTi-R and put in my B15 RR MAF?
96 SE-R Totaled in '99
2000 Sentra SE w/ GTi-R 2.0T
2011 X5 xDrive35i Sport Activity
2006 Cadillac CTS-V
Sigfod is offline   Reply With Quote
Old 03-24-2007, 10:42 AM   #66 (permalink)
Jah Rastafari
no, no and no
Old 04-01-2007, 01:11 PM   #67 (permalink)
Sigfod's Avatar
Does anyone know where to get a MAF bored for not much money?
Old 04-01-2007, 01:12 PM   #68 (permalink)
Sigfod's Avatar
Originally Posted by Andreas Miko View Post
no, no and no
So what changes need to be made to use a 00-01 RR MAF
Old 04-01-2007, 01:12 PM   #69 (permalink)
Jah Rastafari
I do them for $60 with shiping
Old 04-01-2007, 01:14 PM   #70 (permalink)
Sigfod's Avatar
So I send you my MAF and you return it bored all for $60. What is the turnaround time, and are there any other mods needed?
Old 04-02-2007, 11:09 PM   #71 (permalink)
Broke Ass
jer_760's Avatar
Feedback Score: 12 reviews
So since the Maxima and VE/pathfinder maf flow the same, could you use a Maxima maf with an ecu tuned for a VE/Pathfinder maf?
95 200sx
sr20ve
Old 04-04-2007, 12:41 AM   #72 (permalink)
L337 VVL
SO with those HP ratings it won't matter if you NA or boosted? like i will be using the DE AFM with the sr20ve for simplicity reasons there shouldn't be any problems with this?
turbofied is offline   Reply With Quote
Old 04-10-2007, 06:08 AM   #73 (permalink)
Sounds like the guy mentioning the 36mm GTIR MAF has a MAF modified for Rally Use. From what i understand Rally regulations require 36mm restrictors. If this is the case then he should remove the restrictor
AussieVE is offline   Reply With Quote
Old 04-15-2007, 03:37 PM   #74 (permalink)
vz-r driver
what about the ve maf.....if u dont have it then can the de work by plug and play or u gats to redo the ecu????
THOR is offline   Reply With Quote
Old 05-06-2007, 12:17 PM   #75 (permalink)
attesa by nismo
i have an 02 g20 engine would my maf be in the 325 range just wanted to know
2fast to catch 2slow to past
kalonji is offline   Reply With Quote
Old 05-06-2007, 03:32 PM   #76 (permalink)
BTCC VE Power
Feedback Score: 16 reviews
Originally Posted by kalonji View Post
i have an 02 g20 ingine would my maf be in the 325 range just wanted to know
its the same as the 00 de rr, 325hp
KL0 P11 Sport
Surround Sound
My VE thread
Old 05-12-2007, 12:01 PM   #77 (permalink)
attesa by nismo
hey thanks just want to hit the 300whp mark so i wont have to upgrade then
Old 05-19-2007, 02:48 PM   #78 (permalink)
Originally Posted by thinnertenor View Post
i dont see any listing of the U12/U13 (Bluebird, i think) motors.....
are they just the same as the Avenirs?
thats what i would assume, just double checking
Anyone got an answer to this?
Old 05-19-2007, 10:41 PM   #79 (permalink)
Done.
Feedback Score: 27 reviews
IIRC, they are the same. U12/W10 share and U13/W11 share. Or, it could be, that all four are the same. I don't remember which...
SR20DEEP MD
05 Armada - Tow Truck
04 Subaru WRX 'goon
Cliff is offline   Reply With Quote
Old 06-16-2007, 07:10 AM   #80 (permalink)
Drive it like ya stole it
SENTRASER's Avatar
Feedback Score: 34 reviews
Okay, so what about the N60 MAF? Miko?
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by chriscar
HTML code is On
