MAF Size, Part #s And WHP Output - Page 5 - SR20 Forum
Old 06-16-2007, 07:11 AM   #81 (permalink)
Drive it like ya stole it
SENTRASER's Avatar
Feedback Score: 34 reviews
Originally Posted by TeKKiE View Post
IIRC, they are the same. U12/W10 share and U13/W11 share. Or, it could be, that all four are the same. I don't remember which...
I think the W10, U13 and U12 all use the 91-4 SE-R MAF, and the W11 uses the 54C01 MAF, which is almost identical to the 54C00 MAF. I could be slightly wrong FWIW
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by chriscar
Old 06-16-2007, 01:15 PM   #82 (permalink)
KASSANOVA!!!
Feedback Score: 47 reviews
n60 maf is the maxima maf, i think so... n62 is z32, if i got that right...
92 Dark Gray Sentra SER
92 Red Sentra SER
Old 06-17-2007, 10:08 AM   #83 (permalink)
SENTRASER's Avatar
Yes, you are correct. I would like to know the WHP output.
Old 08-15-2007, 02:37 PM   #84 (permalink)
officially a boost addict
Feedback Score: 10 reviews
so after reading all of this popcorn jumping all over the place stuff, which would be a better maf for a stock turbo with boost control, 370 injectors, and stock internals. Say I'm running about 14 lbs boost, and injectors at 4 bar...which by the way i'm still not sure exactly how that works. Lightning MAF a little overkill? or does it matter really? Just cause it's bigger doesn't mean that it will take in more air, right, that's all ecu related anyways. Just if you want the option to bring more air in you can right?
http://www.sr20-forum.com/members-ri...ebs-build.html
U13 SR20DET, Turbonetics 60-1 hi fi .63 ar, Brian Crower Stage 2's, 520cc injectors, .3 bar fuel pressure, n62 maf, log manifold, Tial 38mm wastegate (9lb spring), 3" downpipe-3" VRS Exhaust, PLX Wideband, Calum basic ecu.
Balls to the wall until you see God, wait three seconds then hit the brakes...
nsusammyeb is offline   Reply With Quote
Old 08-15-2007, 03:42 PM   #85 (permalink)
SENTRASER's Avatar
Wowee. If you need a bigger MAF a smaller one sure isn't going to cut it. You just need to get an appropriate MAF for the power levals you're shooting for, it doesn't hurt anything to have a MAF thats TOO BIG, where as if one is TOO SMALL you will max it out.
Old 08-22-2007, 12:42 PM   #86 (permalink)
needs to be tuned
geeio's Avatar
Feedback Score: 3 reviews
i have a hitachi maf the part number is afh70-16a im not sure where this maf comes from. its not a maxima maf is it ? is it the xterra ?
looks like its got a bad sun burn.
geeio is offline   Reply With Quote
Old 09-19-2007, 02:36 AM   #87 (permalink)
Originally Posted by gomba View Post
Anyone got an answer to this?
Part# 22680-79E00
U12 - 89/10 - thru
Part# 22680-54C00
U13 - 91/09 - 95/01
Part# 22680-54C01
U13 - 95/01 - thru
W10 - 95/08 - thru
W11 - 98/8 - 00/05
W11 - 00/05 - thru
UNISA JECS is offline   Reply With Quote
Old 10-06-2007, 10:05 PM   #88 (permalink)
i just did a sr20det swap into my 91 b13 and i want to swap over my stock maf to a maxima n60 maf. but on my stock maf harness there is only 3 wires but on the n60 maf it has 5 wires so i dont know how to do it. is there anyone who knows how to rewire it, thank you
dcrb13 is offline   Reply With Quote
Old 10-11-2007, 10:29 AM   #89 (permalink)
gre
Almera Turbo owner
and n15 GTi ?? almera?
gre is offline   Reply With Quote
Old 10-30-2007, 01:44 AM   #90 (permalink)
Southern Boy!
my avenir maf went bad i need a maf that will work without any tuning that is also fairly readily available to me.. i.e. and mafs that go into a 240 would be good.. like s13/s14 sr, or sohc/dohc/s14 ka mafs..
91 G20 Avenir Swap
200sxse-r is offline   Reply With Quote
Old 10-30-2007, 03:55 AM   #91 (permalink)
sr21
false ......
95 g20-touring part out
http://www.sr20forum.com/mechanical-...0-touring.html
91p10 is offline   Reply With Quote
Old 10-30-2007, 09:05 PM   #92 (permalink)
Southern Boy!
well if your using a det ecu (BB or avenir) the s13 sr maf will work and a single cam 240 maf works just fine too..
Old 01-13-2008, 10:13 AM   #93 (permalink)
Originally Posted by Will View Post
ummm, you motor leans out. If it goes too far it will of course cause serious damage.
what if you use a greddy e manage to take up where the a/f m max out
gt auto is offline   Reply With Quote
Old 07-08-2008, 11:15 AM   #94 (permalink)
can the 54c00 be bored beyond 54mm
Walker is offline   Reply With Quote
Old 11-10-2008, 02:53 AM   #95 (permalink)
i searched and i didnt see this maf part number mentioned anywhere.
Part#22680 31u05 a36-608
does anyone know what vehicle this comes from and how much HP is it capable of??
Se-R 4ME is offline   Reply With Quote
Old 01-24-2009, 02:11 PM   #96 (permalink)
This list needs to be organized!!!
Lucino Avenir SR20det
Lane is offline   Reply With Quote
Old 02-10-2009, 03:31 AM   #97 (permalink)
Im Not A Chick
Feedback Score: 5 reviews
i just read over all of this an i dont think nobody answerd the N60 maf question. also i went to the junk yard and i found a 96 maxima maf but the part number read E60 not N60 i thought thoes years they were called N60 are they the same?? how much power can the E60 flow?
B13 XE with sr20 swap(5 speed swapped)
B13 LE parts car
NX2K RIP (Aug 13 2007) parts car
NX2k soon to be parts car
NX2k my new baby!
NX PART OUT CHECK IT OUT!
http://www.sr20forum.com/mechanical-...-nx-parts.html
We are a community!
jen36 is offline   Reply With Quote
Old 02-18-2009, 07:30 PM   #98 (permalink)
miko i have a 93 cobra maf but my engine is stock what mods do i need to do to my engine so i can put the maf on my car got a b13
adog is offline   Reply With Quote
Old 02-18-2009, 07:45 PM   #99 (permalink)
Im all about the 4x4
Feedback Score: 35 reviews
your engine is stock but you want to upgrade to that maf? why would you want to do that.. youll need a safc or a programed ecu to run the maf but the stock DE Maf will flow a ok amount of power, i had a fully built high compression motor with a 75 shot of nitrous on a stock maf
Here is a List of Items I have for Sale and the Photo and Prices are in this Link Below:
http://www.sr20forum.com/florida/268...ml#post2554270
For Sale:
B14 Wheels
SAFC II - Silver
B14 Welded Transmission
SR20DET Motor
N60 MAF
specalk is offline   Reply With Quote
Old 04-21-2009, 02:46 AM   #100 (permalink)
any chance we could get the WHP on the N60
Humanblob is offline   Reply With Quote
HTML code is On
